Inleiding
If the iRobot Looj 120 has stopped working and all the motors are okay and the battery is charged, then there may be a problem with the circuit board within the handle. This guide will show you how to replace the circuitry in the remote handle.
Wat je nodig hebt
Remove the four exterior screws located under controller and on the handle.
Remove the five screws shown, and then carefully remove top plate. Electrical components are attached to top plate.
Disconnect circuit board from power leads, and install new circuit board.
Één opmerking
Where can you get the replacement circuit board for the remote control?
