Ga door naar hoofdinhoud
iRobot Braava 320 Deck Plate Assembly Replacement
Wat je nodig hebt
  1. iRobot Braava 320 Deck Plate Assembly  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Deck Plate Assembly  Replacement: stap 2, afbeelding 1 van 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Deck Plate Assembly  Replacement: stap 3, afbeelding 1 van 2 iRobot Braava 320 Deck Plate Assembly  Replacement: stap 3, afbeelding 2 van 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
  4. iRobot Braava 320 Deck Plate Assembly  Replacement, Body Shell and Control Panel: stap 4, afbeelding 1 van 1
    • With the battery removed, rotate your device so the front of it is facing you.
    • Remove the four 10mm Phillips #2 screws that attach the shell.
  5. iRobot Braava 320 Deck Plate Assembly  Replacement: stap 5, afbeelding 1 van 2 iRobot Braava 320 Deck Plate Assembly  Replacement: stap 5, afbeelding 2 van 2
    • Using both hands, hold the device together while you flip it over.
    • Starting from the front, gently lift up the shell and slowly tilt back until it is fully removed.
  6. iRobot Braava 320 Deck Plate Assembly  Replacement, Deck Plate Assembly: stap 6, afbeelding 1 van 1
    • With the shell off, flip the iRobot over and remove the four 10mm Phillips #0 screws holding the deck plate assembly on.
  7. iRobot Braava 320 Deck Plate Assembly  Replacement: stap 7, afbeelding 1 van 3 iRobot Braava 320 Deck Plate Assembly  Replacement: stap 7, afbeelding 2 van 3 iRobot Braava 320 Deck Plate Assembly  Replacement: stap 7, afbeelding 3 van 3
    • Remove the two 12mm Phillips #0 screws that hold the two springs onto the deck plate assembly.
    • Remove the two springs by gently lifting them up.
  8. iRobot Braava 320 Deck Plate Assembly  Replacement: stap 8, afbeelding 1 van 1
    • Flip the device over and remove the deck plate assembly cover by lifting it up.
  9. iRobot Braava 320 Deck Plate Assembly  Replacement: stap 9, afbeelding 1 van 1
    • Pull the arms together by lifting them up and to the center.
    • With the arms together. slide the deck plate up and over the arms until it is fully removed.
Conclusie
bradley boardwine
222 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G3, Nance Spring 2017 Lid van USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 7
Altijd: 583
