Ga door naar hoofdinhoud
iRobot Braava 320 Battery Replacement
Wat je nodig hebt
  1. iRobot Braava 320 Battery  Replacement, Battery: stap 1, afbeelding 1 van 1
    • Flip your device over and locate the battery cover.
    • The battery cover is located in the center of the device in between both wheels.
  2. iRobot Braava 320 Battery  Replacement: stap 2, afbeelding 1 van 1
    • Using a Flathead #4 screwdriver, gently turn the 12mm screw that holds the battery cover in.
    • The screw does not remove, it stays attached to the cover.
  3. iRobot Braava 320 Battery  Replacement: stap 3, afbeelding 1 van 2 iRobot Braava 320 Battery  Replacement: stap 3, afbeelding 2 van 2
    • Gently remove the battery from the tray and disconnect the battery cable.
    • To remove the battery, pull it straight up. To disconnect the cable, gently pull it straight out of the connector.
    • To reinstall the cable, hold it near the end and gently push it in the connector.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
bradley boardwine
222 Reputatie
2 handleidingen geschreven
USF Tampa, Team S1-G3, Nance Spring 2017 Lid van USF Tampa, Team S1-G3, Nance Spring 2017
USFT-NANCE-S17S1G3
4 Leden
10 handleidingen geschreven
Één opmerking
where do I get a new battery from?
j.svetlova - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 15
Altijd: 4,745
