Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the following three screws near the top edge of the logic board:
One 2.0 mm Phillips screw
Two 2.3 mm Phillips screws
Use the edge of an iPod opening tool to gently pry, but not remove, the rear-facing camera away from the rear case.
Use an iPod opening tool to slightly lift the edge of the logic board next to the battery enough to grab it with your other hand.
Be very careful not to lift too much as the volume control ribbon cable is still connected and will tear very easily.
While gently lifting the logic board with one hand, use an iPod opening tool to lift the logic board near the copper tape at the logic board's top edge.
The logic board will be lifted adequately when the last display assembly connector has cleared the top edge of the rear case.
Één andere persoon heeft deze handleiding voltooid.
