Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Click. Click. Pfft. Has your home button stopped clicking? Use this guide to replace it. This guide is for replacing the plastic home button cover. If you need to replace the functional home button switch, go to this guide.
Wat je nodig hebt
With the heat gun set on "low", begin heating the lower portion of the Touch near the home button.
69 andere personen hebben deze handleiding voltooid.
11 opmerkingen
"To reassemble your device, follow these instructions in reverse order."
So Nice. Its Fully help
can you make professional step by step tutorial on how to put the touch back together like the one you made to take it apart ?
If you follow the guide from the bottom to the top, you can reassemble the device. If you disassembled the phone farther than the Home Button guide shows, go back to the device page and follow the guide that matches your device.
