Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
This guide shows how to replace the front panel assembly on the 1st Generation iPod Touch.
Wat je nodig hebt
Insert the small plastic opening tool into the seam in between plastic display panel and the metal back panel. The angled edge should point towards the metal back panel.
Hold the tool in place once it is wedged inside and the two panels are separated.
Flip the iPod 180 degrees so it matches the orientation in the picture.
Carefully insert the spudger in between the battery and the display. There are routing cables underneath, so make sure you slowly pry the battery loose.
Use a spudger (or your fingernails) to remove the gold antenna. The antenna bends easily, so make sure not to apply too much pressure. When re-assembling, put the gold antenna in place before inserting the antenna circuit boards.
Use the spudger to remove the connector on the left side.
Remove two Phillips screws.
The antenna loop board needs to be pried up (it is glued down). Gently use a plastic opening tool or spudger, to dislodge the antenna loop board. The board is connected to the antenna electronics by a small ribbon cable. This two-board assembly is very frail.
The two small antenna circuit boards can now be lifted up together, and their orange cable can be peeled from the display.
Peel the orange tape up covering the sixteen Phillips screws on the back of the display.
Use a #00 Phillips screwdriver to remove the sixteen screws.
You now need to transfer the metal spacing into the new front panel. This allows the home button to get in contact with the logic board.
This spacing is glued to the front panel. Carefully insert a spudger below it and pry it out.
13 andere personen hebben deze handleiding voltooid.
