Ga door naar hoofdinhoud
iPod Shuffle 3rd Generation Rear Case Replacement
Wat je nodig hebt
  1. iPod Shuffle 3rd Generation Rear Case Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Rear Case Replacement: stap 2, afbeelding 1 van 2 iPod Shuffle 3rd Generation Rear Case Replacement: stap 2, afbeelding 2 van 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Rear Case Replacement: stap 3, afbeelding 1 van 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Rear Case Replacement: stap 4, afbeelding 1 van 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Newsom
39.500 Reputatie
67 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 16
Altijd: 8,090
