Ga door naar hoofdinhoud
iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement
Wat je nodig hebt
  1. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Rear Case: stap 1, afbeelding 1 van 1
    • Widen the small gap between the front and rear case by inserting a metal spudger into the gap near the top of the iPod.
    • Be careful when using a metal spudger, as you may scratch the outer case.
  2. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 2, afbeelding 1 van 2 iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 2, afbeelding 2 van 2
    • Insert an iPod opening tool into the newly widened gap, and pry the rear case up and away from the front case.
  3. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 3, afbeelding 1 van 1
    • Insert the iPod Shuffle opening tool into the gap between the front and rear case on the same side, at the bottom corner of the iPod.
    • Pry the rear case away from the front case.
  4. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 4, afbeelding 1 van 1
    • Lift the bottom of the rear case and remove it from the rest of the iPod.
  5. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Logic Board: stap 5, afbeelding 1 van 1
    • Disconnect the headphone jack and shuffle switch connector by prying it off the logic board with a spudger.
  6. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 6, afbeelding 1 van 1
    • Remove the single Phillips screw securing the logic board to the front case.
  7. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 7, afbeelding 1 van 1
    • Peel the battery up from the front case with an iPod opening tool.
    • Remove the logic board and battery from the iPod.
  8. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement, Headphone Jack & Shuffle Switch: stap 8, afbeelding 1 van 1
    • Pry the headphone jack from the front case with an iPod opening tool.
    • Don't attempt to remove the headphone jack yet, it is connected to the shuffle switch.
  9. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 9, afbeelding 1 van 1
    • Using the pointed tip of a spudger, push the shuffle switch in to separate it from the front case.
  10. iPod Shuffle 3rd Generation Headphone Jack & Shuffle Switch Replacement: stap 10, afbeelding 1 van 1
    • Remove the headphone jack and shuffle switch from the front case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Matthew Newsom
39.685 Reputatie
67 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 12,032
