Ga door naar hoofdinhoud
iPod Shuffle 2nd Generation Logic Board Assembly Replacement
Wat je nodig hebt
  1. iPod Shuffle 2nd Generation Logic Board Assembly Replacement, Logic Board Assembly: stap 1, afbeelding 1 van 1
    • Before beginning, be sure your Shuffle is turned off as shown.
  2. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 2, afbeelding 1 van 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 2, afbeelding 2 van 2
    • Use the edge of an iPod opening tool to pry the plastic cover off the headphone jack side of the Shuffle.
    • Remove the plastic cover and set it aside.
    Make sure to insert the tool right between the plastic cover and the steel cover. If you go too deep, you will pry the steel cover and bend it. The plastic cover is taped to the steel one with some low force glue.
    Tug - Antwoord
  3. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 3, afbeelding 1 van 1
    • Remove the two Phillips screws from the headphone jack side of the Shuffle.
  4. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 4, afbeelding 1 van 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 4, afbeelding 2 van 2
    • Use the edge of an iPod opening tool to remove the steel cover from the headphone jack side of the Shuffle.
  5. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 5, afbeelding 1 van 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 5, afbeelding 2 van 2
    • Use the edge of an iPod opening tool to pry the plastic cover off the controls side of the Shuffle.
    The On-Off switch here is turn around. Usually it is green when the iPod is turned on.
    Nils Kober - Antwoord
    The plastic cover has small clips at either edge in the middle and alongside the button. Put the iPod opening tool in about a third of the way in from either end to avoid breaking the clips.
    Daniel Foster - Antwoord
  6. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 6, afbeelding 1 van 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 6, afbeelding 2 van 2
    • Use a pair of tweezers to remove the hold and shuffle sliders from the Shuffle.
    Thanks for this great instruction. Little note: Not important for the function, but contrary to the images the green side of the on/off-slider originally must point in the opposite (inner) direction.
    Martin - Antwoord
  7. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 7, afbeelding 1 van 1
    • Remove the two Phillips screws on the controls side of the Shuffle.
  8. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 8, afbeelding 1 van 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 8, afbeelding 2 van 2
    • Use the edge of an iPod opening tool to remove the steel plate from the controls side of the Shuffle.
  9. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 9, afbeelding 1 van 1
    • Use the edge of an iPod opening tool to slightly pry the steel plate on the headphone jack side of the Shuffle away from the lip cut into the outer case.
  10. iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 10, afbeelding 1 van 2 iPod Shuffle 2nd Generation Logic Board Assembly Replacement: stap 10, afbeelding 2 van 2
    • Use your iPod opening tool to push the logic board assembly out of the outer case enough to grab the logic board by its edges.
    • Pull the logic board assembly out of the outer case.
Conclusie
21 andere personen hebben deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 32
Altijd: 18,976
