Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Apple's got a routine going with the nano. Never fail, come September, we get a new one.
1G - September 7, 2005
2G - September 12, 2006
3G - September 5, 2007
4G - September 9, 2008
5G - September 9, 2009
This is the first time Apple's had a similar exterior design two releases in a row. The rear-mounted video camera is the only clear sign that we have a new device in our hands.
Notice the white wrapper around the packaging. Not even Apple employees got to sneak a peek at this one.
Shiny!
Many of the new features include a pedometer, voice recorder, voiceover, a genius mix feature, FM radio, a speaker, oh, and a little thing called a VIDEO CAMERA!
The one thing the nano didn't receive this release is a capacity upgrade. Like the 4th Gen, this nano comes in 8 and 16 GB capacities.
You can [www.twitter.com/ifixit|follow us on twitter] to get all the latest updates as we're doing the teardown!
A video camera finally comes to the iPod line. Surprisingly, it's in the nano, and not the touch.
According to Apple, the video camera offers:
H.264 VGA video
640 by 480 pixels
Up to 30 frames per second
AAC audio
A Plastic Opening Tool makes quick work of the plastic bezel surrounding the dock connector.
There's not much to see here yet. We're working on getting to the good stuff...
So far, there's a lot in common with the 4th Gen nano.
No surprises here. This design is identical to the 4th Gen nano. Even though the exterior hold switch is near the edge of the iPod, the internal hold switch is actually in the center of the iPod.
Unlike some earlier iPods, the hold switch isn't directly attached to the logic board.
That's a really thin ribbon cable. Then again, there's not a lot of data that needs to go through it.
The camera bezel appears to be keeping the iPod's insides from coming out.
Eine Deutsche Rasierklinge should fix that...
The microphone by the camera ensures you get sound with your VGA moving pictures.
Use a pin to remove the small white retainer from between the camera and microphone holes. This keeps the components from sliding toward the bottom of the nano.
Gereedschap gebruikt in deze stap:Spudger$3.99-
Apple has redesigned the click wheel on this nano. Instead of being (fairly permanently) affixed to the case, we were able to rotate and lift the click wheel.
You can use a spudger to completely remove the click wheel without taking the rest of the iPod apart.
There's a thick slab of glass covering the LCD. Unlike the iPhone, we haven't seen issues with broken glass on the nanos.
If you want your screen to look nice, don't touch it. Fingerprints are quite noticeable on the glass.
Removing the internals... It's a tight squeeze, but we got them out. Getting this iPod open wasn't easy. We don't recommend trying this at home. Take great care not to scratch the screen on the sharp recess for the click wheel, bend up slightly if necessary.
This iPod employs copious amounts of glue and adhesive to hold everything together. That makes it easy for Apple to put together, but hard to take apart.
iPod, sans casing.
The tolerances on this iPod are incredibly tight, there's no wasted space inside.
The new nano features a larger display (2.2" and 240x376). This is the same width as the 4th Generation nano, but 56 pixels taller. On a pixel basis, that's 17.5% more screen real estate.
Apple keeps putting bigger screens in the same size devices. The footprint of the iPod nano has stayed the same over the last four years, but this display has four times the pixels of the original nano.
The battery. Apple warns you right from the get-go that your iPod may melt and/or spontaneously combust: "Potential for fire or buring." We assume they mean burning. It is assembled in China, so we'll give them a little slack.
Supposedly if you burn this battery, it will burn.
Here's the speaker. Like the Touch 2nd Gen, the audio simply comes out the bottom of the iPod.
For something only about a millimeter thick, it's not really fair to complain about audio quality.
Removing the connector that connects the microphone, speaker, hold switch, and headphone jack to the logic board.
Removing the camera.
It's nice to see that the camera's a separate module and not integrated into the board.
The camera, in all its VGA resolution glory. The camera itself is less than 3 mm thick.
Space may have been a factor in not including a better camera. Excluding its mount, the camera in the iPhone 3G is about 6 mm thick. The 5th Gen nano is 6.2 mm thick at its thickest point.
Unlike the nano, the touch, at 8.5 mm thick, could conceivably support an iPhone-sized camera, although it would certainly be an engineering challenge.
In our iPod, Toshiba is the source for the 8 GB of flash memory. On the chip:
TH58NVG6D2ELA49
ID8038
TAIWAN
09299AE
It looks like this was made in Taiwan in week 29 of 2009 (mid-July).
Also visible to the right of the Toshiba chip is the rubber mounting fixture for the camera, assumedly to dampen vibrations.
The front of the logic board.
The main ARM processor dwarfs everything else on the board. Similar to previous iPods, we expect this is an Apple-branded Samsung processor.
Here's the markings from the processor:
339S0081 ARM
K4X51323PG-UGC6
EDE168AG 0928
APL0378A00
N1X2XW 0931
The shiny chip is visible from this angle:
338S0559
ATWV0926
SGP
~ The End ~
Credits:
Pictures and hardware analysis: iFixit
Flying to Pennsylvania to take apart the new iPod nano for you: iFixit's summer intern.
Want a programming job with us? We're hiring.
15 opmerkingen
Citaat van stevev1:
where's the FM radio?
It uses the head phone wire because all u need is the right programming and a 2 foot wire to get radio
