Inleiding
Replacing the VGA camera on the 5th generation iPod Nano.
Wat je nodig hebt
Insert an iPod opening tool between the outer case and top bezel near the screen.
Lifting up on the iPod opening tool, gently pry the top panel off of the device.
Use a heat gun to soften the adhesive underneath the plastic bezel at the bottom of the iPod.
Use a plastic opening tool to pry the bezel from the case of the iPod and remove it.
Use a heat gun to soften the adhesive underneath the camera/microphone cover.
Pry the camera/microphone cover off the case with a metal spudger and remove it.
Use a hot glue gun to apply a bead of glue across the cover.
Move the nozzle in the glue for 20 seconds to heat the lens adhesive holding the lens in place.
Press a spudger into the hot glue and hold it in place until the glue cools and hardens.
Pull on the spudger with firm steady force, while using a fingernail to pry on the cover edge.
Peel back the orange tape covering the camera ribbon cable up off the logic board.
6 andere personen hebben deze handleiding voltooid.
