Ga door naar hoofdinhoud
iPod Nano 4th Generation Outer Case Replacement
Wat je nodig hebt
  1. iPod Nano 4th Generation Outer Case Replacement, Glass Panel: stap 1, afbeelding 1 van 2 iPod Nano 4th Generation Outer Case Replacement, Glass Panel: stap 1, afbeelding 2 van 2
    • Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
    • Pry the top bezel off the adhesive securing it to the display retainer.
    • At this point the hold switch slider is free and may fall. Be careful not to lose it.
    Be sure to use the smaller iPod opening tool and press it in FIRMLY in order to get enough leverage to get under the bezel and pry it off. Adhesive is very strong, so don't be afraid to use a little bit of force.
    captcarl13 - Antwoord
    Tool broke before I could get the cover off !!! So I’m done before I even started !!
    linda45p - Antwoord
    I have a Apple iPod Nano 4th gen(Green) and I only have 7 tech pieces to the iPod and I may/might have the small philips screws and I am not sure how to fix the iPod nano
    Nick Davies - Antwoord
    I also had Problems to remove the bezel. The solution was to start with a very small screw driver from the hole of the switch. There I could lift it a bit and get the plastic tool in between. Than it was easy.
    Michal Niewiadomski - Antwoord
    After replacing the battery, the old glue would lump up too thick, and also become too weak to fix the panel back to the outer case. I have scraped all the old glue off using a small flat head screw driver, and affixed a double sided adhesive tape cut into small strips, which was successful in both aspects.
    diytradjazz - Antwoord
    TIP: Use a plastic tool and pull it out through the hold switch. This may break the top bezel, but this was the only way to get it off.
    Caleb Murphy - Antwoord
  2. iPod Nano 4th Generation Outer Case Replacement: stap 2, afbeelding 1 van 1
    • Remove the hold switch slider from the top of the Nano.
  3. iPod Nano 4th Generation Outer Case Replacement: stap 3, afbeelding 1 van 1
    • Remove the two angled Phillips screws from the two corners of the display retainer.
    • These screw heads are extremely small and easily stripped.
    Be sure to use a good phillips #00 screwdriver here, or you run the risk of stripping the very small screws.
    iTronics Repair - Antwoord
    The screws were covered with the adhesive. They were very difficult to remove.
    I RUINED the hold switch! I accidentally broke the cord. 0_o The directions were kind of unclear.
    bodieg - Antwoord
    Citaat van bodieg:
    Step 12 is misleading as it does not show to remove the screen from the metal frame.
    bodieg - Antwoord
    Sorry guys, but the explanations are really bad. Go onto youtube and watch it. This site misses heaps of steps. I just broke my iPod :(
    S Mile - Antwoord
    Like others have noted, screws are covered in adhesive and difficult to remove. Take extreme care to not strip the heads. I'd suggest using a very small flathead to scrape some of the adhesive off before attempting to remove the screws.
    a 1mm slotted screwdriver will work in a pinch, but be carefull and make sure you get the angle just right
    andrew - Antwoord
    The tools list doesn't say you need an iPod opener to, nor does the parts list day you'll need a new click wheel, though this is called ”...click wheel REPLACEMENT​”. I don't get the feeling these are very trustworthy instructions, ESPECIALLY after having read other comments. I'd say BEWARE, and look at a variety of resources to get a much more comprehensive picture.
    Skyfire - Antwoord
    Actually, the screws are not aligned with the edges of the iPod, which means that you must not try to unscrew them vertically. If you do there is a good chance that you damage the head of the screws. Thus look carefully with a torch to see at what angle you have to unscrew them.
    Fabrice Sarelli - Antwoord
    Actually, the screws are not aligned with the edges of the iPod. That means that if you try to unscrew them vertically, there is a good chance that you damage the head of the screws. Thus, look carefully with a torch to see exactly at what angle you need to unscrew them safelly.
    Everything was good up to this point. I could barely see the screws and ended up stripping them. Just gave up at this point and threw the
    Ipod on the ground and stomped on it.
    gonzalo gonzalez - Antwoord
    I agree with several other contributors here, that a properly sized flat screwdriver *that is not worn* held at the correct angle is a better option than a phillips because the screw head is filled in with adhesive tape. BEWARE: The screws on the top and bottom outer edges are not parallel to the case. They are offset by 25 or 30 degrees, with the tips of the screws pointing out towards the outer edge of the case with respect to where the heads are. Use something to get magnification so you can really see how your screwdriver fits, and whether it’s engaged. An undamaged and properly sized standard screwdriver held in the appropriate orientation will readily remove the top and bottom side screws without stripping and with very little force. Feel for engagement — press the screwdriver in just enough to get past the adhesive. Not much torque or pressure is required — just a good fit. You must have the right tools to do this job successfully, and look under high magnification. Align your screwdriver!
    Barry L. Kramer - Antwoord
    In accordance with another source, I have bought online and used a Phillips #0000 screw driver, which worked pretty well here. It costed me only $2 .
    Screws are inserted under an angle. Would suggest to use a jeweler’s magnifying glass to check the angle before sticking any screw driver in there.
    aramis - Antwoord
  4. iPod Nano 4th Generation Outer Case Replacement: stap 4, afbeelding 1 van 1
    • Insert an iPod opening tool between the outer case and the display retainer.
    • Use the tool to slide the display assembly out of the case slightly.
    • Do not rotate the display retainer about the top edge of the display, as it is attached to a thin steel bracket that is easily broken.
    • Do not forcefully remove the display retainer, as the hold switch cable is liable to snap.
    I found I had to gently pry the retainer open with a craft knife (xacto knife?) as the plastic opener tool was too blunt or soft to get any purchase...
    aaaidan - Antwoord
    My nano had a "swollen" battery which wedged the LCD between battery and front glass. As a result, this step didn't work, I couldn't pull out the TFT and botched case, TFT and TFT frame until it came out. Telltale sign was a display that looked like there is a water between glass and LCD. The other nanos I've opened didnt have this problem and came out effortlessly, so if yours is stuck, don't feel bad, there's not much you can do!
    oliver - Antwoord
    What to do if the upper metal base (which is fixed to the circuit with 2 screws) came off when extracted?
    Which side can I anchor to force the display to exit?
    Francesco Taliercio - Antwoord
  5. iPod Nano 4th Generation Outer Case Replacement: stap 5, afbeelding 1 van 1
    • Slide the display out of the Nano. It will move about .5" until the display data cable limits its travel.
    • Do not put unnecessary tension on the very thin display data cable.
    I have several problems in taking it out. I don't know if it is dued to the glue that the iPod has inside. Could you help me. Thanks
    Hector - Antwoord
    instructions say 5" (inches) it really means 5mm
    pedalsandpicks - Antwoord
    Citaat van pedalsandpicks:
    If you're gonna repair the way you read it will get you nowhere: the text reads .(as point)5 inch. Which is about 12mm.
    Frank veenis - Antwoord
    The glass panel can be very difficult to get moving requiring a lot of downward force. I have found good old fashioned spit to be very useful here.Just lick both thumbs and rub on fingers until just sticky enough.
    This willl move the glass.
    Pete Green - Antwoord
  6. iPod Nano 4th Generation Outer Case Replacement: stap 6, afbeelding 1 van 2 iPod Nano 4th Generation Outer Case Replacement: stap 6, afbeelding 2 van 2
    • With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
    • Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
    I found the adhesive (or fit) quite strong. Pushing on the bottom part of the glass created a small gap at the top, which I could fit a craft knife (xacto blade) into. This made it easier to carefully lever the glass out for me.
    aaaidan - Antwoord
    I slipped and broke the LCD. So !#^&@@ off. What an absolute bastard of a job!
    lf - Antwoord
    What is the "rear edge" of the nano? Can this be a bit clearer please? Maybe a video of this step would be a good idea. Then again, since Apple owns this site, I guess that's not gonna happen, is it?
    lf - Antwoord
    I don't see "rear edge" anywhere in the instructions. I do see "lower edge" a few times and it looks pretty clear to me. I did this repair a couple years ago without much trouble.
    Rene Jeddore -
    You could do all these steps and really mess up your nano. Instead of disassembling the iPod, carefully remove the remnants of the old glass which I assumed you have cracked. With the new glass in hand CAREFULLY sand one edge of the glass evenly. I used my fine grinder on my dremel tool. After assuring a snug fit I removed the adhesive and installed the glass. Looks great and functional and I didn't ruin my iPod in the process. And when I said sand one edge I mean one of the edges that has a "lip" on it. The other lip you can slide right in and push gently down for a nice fit. Do not remove the adhesive until you are sure of a good fit. This is a quick fix for those who are too queezy to take apart their device.
    Jim - Antwoord
    My battery had expanded and pushed out the glass enough for me to peel the glue out like a battery pull tab on a phone so it was pretty easy to remove, but the screen is giving me some trouble. The expanded battery is holding the screen to the frame making it more difficult to remove.
    Elijah - Antwoord
    Absolut falsch beschrieben, die Anleitung ist
    Herbert - Antwoord
    Grottenschlecht
    Herbert - Antwoord
    Lieber Herbert,
    schade, dass dir die Anleitung bisher nicht geholfen hat. Stand heute haben bereits 35 andere Nutzer ihr Gerät damit erfolgreich repariert, deshalb wäre es gut zu wissen, was genau bei dir nicht geklappt hat und wo es hakt?
    Unsere Anleitungen werden nach dem Wikipedia-Prinzip geschrieben, das heißt du kannst auch selbst jederzeit noch zusätzliche Punkte hinzufügen oder Änderungen vornehmen, die besser beschreiben, was hilft, damit für diejenigen, die nach dir diese Reparatur versuchen, eine noch umfassendere Dokumentation zur Verfügung steht.
    Sandra Hiller -
  7. iPod Nano 4th Generation Outer Case Replacement: stap 7, afbeelding 1 van 1
    • Lift the glass panel out of the Nano.
    • Before reinstalling the glass panel, be sure to clean the face of the display and the inside of the panel as any dust or fingerprints will be annoyingly visible when the Nano is turned on.
  8. iPod Nano 4th Generation Outer Case Replacement, Display: stap 8, afbeelding 1 van 1
    • Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
    • The hold switch ribbon cable is extremely fragile and easily broken. Work gently.
    Be extremely careful while doing anything around the screen. The slightest bit of pressure in the wrong direction and you will be replacing the screen along with the battery. I speak from experience.
    Brian Campbell - Antwoord
    I was extremely careful… and, I broke the display! ~ Gah! ~ $18 for a new one on Ebay (half the price if I wanna wait 3-4x as long to purchase from overseas, twice the price if I buy it from this site!) ~ What a bummer! ~ The goal was to fix this for a customer, and instead I created a longer wait & obviously have to pay for the screen I broke. LISTEN TO BRIAN! BE CAREFUL! THE SCREEN _WANTS_ YOU TO BREAK IT! DON’T FALL FOR IT!
    cybrosis catharsis -
    Does anyone know where I could get the power button flex cable replacement? I was too extremely careful but the screen has a very precise fit. I is fine when you push the screen into the case but !&&* of a work to pull it out.
    [deleted] - Antwoord
  9. iPod Nano 4th Generation Outer Case Replacement: stap 9, afbeelding 1 van 1
    • Peel back the Kapton tape covering the display data cable socket.
  10. iPod Nano 4th Generation Outer Case Replacement: stap 10, afbeelding 1 van 1
    • While holding the light colored socket down with one finger, use the tip of a spudger to flip the ZIF cable lock up toward the bottom of the Nano.
    Continue to carefully hold the socket down while doing the next step. If the cable come off at the wrong angle it can pull the connector away from the board at the base of the screen.
  11. iPod Nano 4th Generation Outer Case Replacement: stap 11, afbeelding 1 van 1
    • Use an iPod opening tool to peel the display data cable off the thin metal plate attached to the display.
    • Be careful not to rip the display data cable.
    Some of the ribbon is inside the white housing with the lock on, it needs to slide out of the housing. I didn't notice this because everything is so small - be sure not to slide your pry tool right through it.
    Martin Mccaffrey - Antwoord
    The display can actually be pulled out slightly further than it initially seems. When you gently pull it up, you'll experience some resistance, which I initially thought indicated it was as far as it could go. But an extra bit of (still very gentle) force can pull it up a few more millimetres, which means the opening tool can fit.
    Also, it seemed to me to actually be helpful to lever the cable out of its port before removing the ribbon from the adhesive on the plate, since this allowed better access to the adhesive with the opening tool.
    aaaidan - Antwoord
    As commenter Brian Campbell wrote on the previous step, it is important to hold down the white cable socket while carefully working the cable loose from the adhesive. Even a small amount of upward force on the display data cable while it is still inside the socket could be enough to tear the socket off the board. Try not to pry up - use a thin, new (undamaged) opening tool to get under the ribbon cable and keep it parallel and as close to the metal plate as possible. It needs to be worked *under* the data cable, not to pry, as the cable just slides straight out the bottom of the white socket.
  12. iPod Nano 4th Generation Outer Case Replacement: stap 12, afbeelding 1 van 1
    • Pull the display out of the Nano, minding the hold switch cable that may get caught.
    • As you pull the display out of the case, be careful not to break the hold switch cable.
    WATCH THE HOLD SWITCH!! Be *sure* it is disconnected before pulling out the screen! (I've made that mistake too many times :P)
    disconnected from what?
    I never saw where it was connected to!
    Fred Rodolf -
    By "caught" do you mean glued to the case? Mine was, and I cant tell how I could possibly have removed the screen without it breaking. Luckily my Ipod was already broken, but now its even more broke because of this guide.
    swd311000 - Antwoord
    Oops!!!…..I managed to break the little ribbon cable going to the hold switch…lots of very “colourful“ words aimed at myself are in my head now.
    Simon Kormendy - Antwoord
  13. iPod Nano 4th Generation Outer Case Replacement, Logic Board Assembly: stap 13, afbeelding 1 van 2 iPod Nano 4th Generation Outer Case Replacement, Logic Board Assembly: stap 13, afbeelding 2 van 2
    • Insert an iPod opening tool between the bottom bezel and the dock connector.
    • Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
    Follow this picture exactly, inserting the tool in the dock port to pry off the bottom plastic piece-- if you pry on the edges you may bend or break this plastic piece.
  14. iPod Nano 4th Generation Outer Case Replacement: stap 14, afbeelding 1 van 1
    • Remove the three Phillips screws along the bottom of the Nano.
    • The slightly longer of the three screws belongs in the middle.
    In my case, the screw on the left was impossible to remove, it looked like it was unscrewing but was not ... I could not proceed any further.
    Any advice?
    Gauthier Scavée - Antwoord
    If a screw is stripped, you need to somehow get another under the head to apply pressure to unscrew it (while unscrewing it). It’s an unpleasant operation where you have to apply pressure to keep the screwdriver pressed into the head while prying outward so the threads back out. Try not to strip the head, and try not to strip the threads, while helping the threads to catch.
    If this happens, you’ll need to replace the screw. It’s not a good idea to reinstall a stripped screw.
    우선 하판을 들어내면 나사에 접착제가 있을거에요 핀셋같은걸로 충분히 제거하고나서 나사를 푸시는게좋을듯
    jongjun307 - Antwoord
  15. iPod Nano 4th Generation Outer Case Replacement: stap 15, afbeelding 1 van 2 iPod Nano 4th Generation Outer Case Replacement: stap 15, afbeelding 2 van 2
    • Use an iPod opening tool to pry the aluminum dock bezel out of the Nano.
    • The dock bezel is very thin cast aluminum. To avoid breaking it, do not excessively flex it during removal.
    I found using the opening tool to wedge up (toward the case) from between the metal bit (which is a plate) and the dock socket was the easiest way to do this.
    aaaidan - Antwoord
  16. iPod Nano 4th Generation Outer Case Replacement: stap 16, afbeelding 1 van 3 iPod Nano 4th Generation Outer Case Replacement: stap 16, afbeelding 2 van 3 iPod Nano 4th Generation Outer Case Replacement: stap 16, afbeelding 3 van 3
    • Use the flat end of a spudger to separate the battery from the adhesive securing it to the outer case.
    • The lithium polymer battery used in the Nano is very flexible. Try not to deform it excessively while separating it from the outer case.
    • Use the flat end of a spudger to push the logic board assembly and battery slightly out of the bottom of the Nano. Stop once it pops out a little bit.
  17. iPod Nano 4th Generation Outer Case Replacement: stap 17, afbeelding 1 van 1
    • Use the edge of an iPod opening tool to peel the click wheel ribbon cable and its ZIF socket off the dock connector.
    No, don’t do step 17 without reading step 18 and 19 first! Step 17 is very misleading read on its own, you will break the connector. You need to read setps 17, 18 and 19 before starting step 17.
    John beGood - Antwoord
    Pay heed to the word “peel”. Don’t pry. Work the tool slowly under the connector, keeping it as close to the board as possible. Don’t pry. The unit I repaired also had a small piece of Kapton tape, the corner of which can be lifted with tweezers.
    Looks like I may have broken the little ribbon cable for the click-wheel, so, I might have to call it quits and spend another Au$260.00 on a new iPod Nano.
  18. iPod Nano 4th Generation Outer Case Replacement: stap 18, afbeelding 1 van 2 iPod Nano 4th Generation Outer Case Replacement: stap 18, afbeelding 2 van 2
    • Use the edge of an iPod opening tool to flip the ZIF cable lock up toward the headphone jack.
    you might want to put a note for the delicacy of this cable on Step 16... because the cable can break as you slide the logic board assembly out :o(
    juliforsyth - Antwoord
  19. iPod Nano 4th Generation Outer Case Replacement: stap 19, afbeelding 1 van 1
    • Use a pair of tweezers to slide the click wheel ribbon cable out of its socket.
    • Before proceeding, be sure that both the click wheel ribbon cable socket and its cable are freed from the adhesive securing them to the dock connector and logic board.
    • Peel back the cable on both ends!
    You forgot to mention that the click wheel ribbon cable needs to be detached from the adhesive holding it to the main board. Now my ipod is really broken. Please review your instructions to include all the steps!
    Mike - Antwoord
    Citaat van Mike:
    You forgot to mention that the click wheel ribbon cable needs to be detached from the adhesive holding it to the main board. Now my iPod is really broken. Please review your instructions to include all the steps!
    Mine too, but the iPod was already toast :D, so now i have a stylish 8GB External SSD
    Chris Green - Antwoord
    There has got to be a trick to it, or something I am missing when putting it back together. I can't get the click wheel ribbon to go back in properly. It keeps getting bunched up and sticking out the end. It is long enough to stick out so you can detach it from the other ribbon, so is it supposed to fold up inside when you push it in?
    reedc1 - Antwoord
    Does anyone know of a source of mainboards for this Nano. Preferably in the European Community or China? Every other part seems to be available but this one.
    I've even found dud mainboards for sale on the U.S. Ebay site. What on earth would anyone do with a faulty Maiboard?
    TOOLS: I've ben reading a few commments regarding difficulty wth the screws. I was also told the Phillips screwdriver isn't a true Phillips but has an offset leg. Not having seen one I can't comment with any certainty.
    However,being an improvisor,I've been doing very well with a couple of watchmakers screwdrivers.The flat blades are about 1mm across and made of hard blued steel. The sharp corners dig into the screw and push any glue out of the way. A phillips won't push though glue. I used to buy these in a small plastic box - usuallly on street markets.
    Well... beware, this part is tricky ! the click-wheel ribbon stuck and get cut when pulling the battery+motherboard out. Too bad :(
    Anyway it was "last chance" for my 7-years old blue nano, battery wasn't providing more than 15 minutes autonomy.
    Too bad, it was my fist iPod and I liked it much than my new 7th gen'.
    Playoff - Antwoord
    Your photos are showing the wrong cable being removed from the zip lock connector and freed, you are not showing that the cable coming from the click wheel is disconnected and freed. Your photo is showing that the cable from the logic board is disconnected and freed. This means that when the logic board is removed, the cable to the click wheel breaks. Your text and warnings are correct, but your photos are misleading. Very bad compared to the rest of the instructions in steps 1 - 16, which are excellent and better than anything else I found. A shame to spoil it with this step. It is not sufficient to warn in the text that “both ends of the cable need to be freed”, you have to add a photo showing the click wheel cable has been disconnected and freed (and what do you mean by both ends of the cable need to be freed - there are TWO cables, one to the logic board, one to the click wheel and you are showing the wrong cable to the logic board as being freed.
  20. iPod Nano 4th Generation Outer Case Replacement: stap 20, afbeelding 1 van 1
    • Pull the logic board assembly out of the outer case, minding the hold switch and click wheel cables that may get caught.
    • When reassembling, ensure the click wheel cable is toward the front of the Nano and not in the grooves on the side. If it is in the groove you will probably cut it while sliding the logic board into place.
    My click wheel cable got sliced reinserting the logic board, so make sure your click wheel cable is on the front (like the instructions say), and not on the side. It would help if there were explicit reassembly instructions and not just "do these in the reverse order", so that special reassembly notes stand out more.
    Randall Theobald - Antwoord
    Instead of pulling it out, I found it easier to use the display hole to push on the top part of the battery straight down toward the bottom of the unit. This gives you far greater control of the battery/mainboard removal operation; you can push it out (down) in tiny increments and confirm no cables are caught as you do it. Pulling can cause a sudden, catastrophic release and if something is caught, it’s destroyed.
    Das Problem ist, das sich der alte Akku aufbläht wenn er kaputt geht bzw. sehr alt ist und das Gerät so gut wie nicht zu zerlegen ist. Bei mir ging das Display und das Kabel des HOLD Schiebers kaputt weil alles so dicht gepackt war. Empfehle den Ärger niemanden bzw. vor der Akku Bestellung zu überprüfen, ob sich der Ipod prinzipiell zerlegen lässt.
    G911CX - Antwoord
    Ein einziger Mist diese Anleitung es wird nicht hingewiesen dass man den Ipod Weg werfen kann wenn der Akku aufgebläht ist was meistens der Fall ist.
    Herbert - Antwoord
    Bei einem aufgeblähten Akku muss man tatsächlich sehr vorsichtig sein. Ob das immer gleich heißen muss, dass man das Gerät wegwerfen muss, wage ich zu bezweifeln, ich würde zunächst einmal schauen, welche anderen Teile eventuell in Mitleidenschaft gezogen worden sind und ob die ebenfalls austauschbar sind. Falls du dich wirklich gezwungen siehst, das Gerät wegwerfen zu müssen, haben wir hier einige relevante Informationen zum Recycling von Elektroschrott zusammengestellt: How to Recycle End-of-Life Electronics.
    Sandra Hiller -
  21. iPod Nano 4th Generation Outer Case Replacement, Click Wheel: stap 21, afbeelding 1 van 2 iPod Nano 4th Generation Outer Case Replacement, Click Wheel: stap 21, afbeelding 2 van 2
    • Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case.
    • This requires a good amount of force. Work slowly.
    • It may be helpful to use an edged tool to separate the adhesive from the click wheel on the inside of the Nano while pressing it down from the outside.
    • Remove the click wheel from the inside of the Nano.
    • Be careful not to let the click-wheel slide on the metal plate supporting it, as it will break the flat cable. Apply force perpendicular to the click-wheel.
    it's a good idea to use a spudger inside to loosen it, but make sure not to slip too far or you may scrape the outside of the clickwheel.
    Jorge Barquinha - Antwoord
    How is this a guide to replacing the click wheel? Everything you want to know about how to get it out, but not a word about how you "reverse the process" to get it back in again, especially what adhesive to use or how to make sure the metal plate ends up in the right place and doesn't inhibit the motion of the click wheel itself. If anyone has actually done this repair successfully, please post something!
    Walter Dean - Antwoord
  22. iPod Nano 4th Generation Outer Case Replacement, Outer Case: stap 22, afbeelding 1 van 1
    • Outer case remains.
Conclusie
12 andere personen hebben deze handleiding voltooid.
3 opmerkingen
Interesting
Where can I buy those outer cases?
Jay - Antwoord
What I have found is most are on eBay. I have been looking for a orange shell and can only find some cases.
Ad123re -
@jay9016 ebay ifixits store Amazon really all online shops
Appleiphone - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 47
Altijd: 29,104
