Inleiding
Use this guide to replace a worn anodized aluminum outer case.
Wat je nodig hebt
Insert the edge of an iPod opening tool into the gap between the outer case and the top bezel.
Pry the top bezel off the adhesive securing it to the display retainer.
With the display pulled out of the case as much as possible, gently press on the lower edge of the glass panel until it pops in slightly (~1 mm).
Use your thumbs on the lower edge of the glass panel to slide the glass down and into the case until the top edge pops up out of the case.
Use the edge of an iPod opening tool to separate the hold switch from the adhesive securing it to the top edge of the display.
Insert an iPod opening tool between the bottom bezel and the dock connector.
Separate the bottom bezel from the adhesive securing it to the Nano and set it aside.
Press down firmly around the perimeter of the click wheel to separate it from the adhesive securing it to the outer case.
Remove the click wheel from the inside of the Nano.
12 andere personen hebben deze handleiding voltooid.
