Ga door naar hoofdinhoud
iPod Nano 2nd Generation Top Bezel Replacement
Wat je nodig hebt
  1. iPod Nano 2nd Generation Top Bezel Replacement, Top Bezel: stap 1, afbeelding 1 van 1
    • Before opening your iPod, ensure that the hold switch is in the locked position.
  2. iPod Nano 2nd Generation Top Bezel Replacement: stap 2, afbeelding 1 van 1
    • Carefully insert an iPod opening tool in the seam between the metal casing and white plastic top.
    • Lift the top bezel off the iPod. It's glued on using a mild adhesive, so some force may be required.
Conclusie
12 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
2 opmerkingen
But how do I install it on? Do I just push it back? I want to fix mine but it doesn't even have the top part anymore, or the hold switch
luis - Antwoord
I would recommend that you put some new adhesive on there. All you have to do is put the switch in its place and put on a new top and push it down.
Ad123re -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 24
Altijd: 18,959
