Ga door naar hoofdinhoud
iPod Classic Click Wheel Replacement
Wat je nodig hebt
  1. iPod Classic Click Wheel Replacement, Hard Drive: stap 1, afbeelding 1 van 1
    • Apple designed their new iPods to be very difficult to take apart without destroying major components. Because of the metal faceplate, the metal backing, and the 13 (yes, 13) metal clips holding the case together, this is one of the toughest iPods to disassemble.
    • Proceed with caution and the warning that you may significantly damage your iPod beyond its present condition. Also, you may want a few extra pairs of plastic opening tools during installation, as they are easy to ruin when opening the iPod. Have fun!
    • Before opening your iPod, ensure that the hold switch is in the locked position.
    If you're meticulous, the job can perfectly be done, without any of the recommended tools. I hadn't the time to order them, so I opened my iPod with the large blade of my Victorinox swiss army knife. By just following the instruction I succeeded in releasing all of the metal tabs all around the iPod, and didn't damage any of them. You can clearly hear them "declipsing". I think the blade of the Victorinox is thiner than the putty knife, the only thing you have to take care of, is not to cut the black or silver painting of the front of the case, but if you are used to cut with a knife, you should succeed. Just be aware that it is however a difficult job !
    jcfsystems - Antwoord
    Thank you for these instructions - my dead iPod classic (that died whilst attached to an ipod dock during a heavy thunderstorm which took out the dock too) is now working again. Opening the case took me 40 minutes and 7 plastic case openers not to mention very sore hands but the rest of the process worked fine. thanks again
    Stuart Hutchesson - Antwoord
    Opened it up with MANY super thin nylon guitar picks in less than a minute starting from the two tabs on the bottom - I used the putty knife in my shop for wood filler and patching walls :)
    cmguitar - Antwoord
    Appreciated the earlier comment about using guitar picks. It is waaaaaay easier to open the iPod with guitar picks. It still requires patience sometimes, but no noticeable damage to the iPod. Went to the local music store, they stocked Fender picks. Fender "Thin" work best for me for starters, but sometimes Fender "Medium" are needed. (Go to your local music store-- very cheap!) I have opened (and repaired successfully!) four different iPods just using guitar picks.
    Novice iPod Repair Guy - Antwoord
  2. iPod Classic Click Wheel Replacement: stap 2, afbeelding 1 van 1
    • Opening this iPod is challenging. Don't get discouraged if it takes you a few tries before the iPod is opened. One thing to notice is the angle of the plastic opening tool's tip while inserting it into the iPod. Ideally, the angle should be as vertical as possible while still clearing the edge of the rear panel.
    • Insert a plastic opening tool into the seam between the front and back of the iPod.
    I have with luck (several times) used the metal spudger to create a small initial gap.
    But be careful, it's easy to severely scratch the iPod.
    rousp - Antwoord
    right here, you should insert a picture of the little clips on the rails inside the back of the ipod, so that we can visualise what we're trying to undo, & get a better idea of which way to bend, which way NOT to bend the tools.
    duncanrmi - Antwoord
    Good point! There is such a picture showing the location of at least four (4) clips on each side of the case here:
    https://d3nevzfk7ii3be.cloudfront.net/ig...
    in the Step 4 of the “iPod Classic Teardown”: iPod Classic Teardown
    As mentioned below by Kevin M there are 3 more (1 on top and 2 on the bottom sides).
    LDS -
    Actually it’s a wayyyyyyy easier using the iFlash opening tool and following the pdf of this guy (youtube link)
    Bastien Arata - Antwoord
    Actually it’s wayyyyyy easier using this tool as mentioned by this awesome guy on his video.
    That video is excellent. He has a PDF you print which is the same size as the iPod so you know exactly where the 11 clips are (1 on top, 2 on bottom, and 4 more along each side).
    Kevin Moorman - Antwoord
    Appreciated the earlier comment about using guitar picks. It is very easy to open the iPod with guitar picks. It still requires patience sometimes, but no noticeable damage to the iPod. Went to the local music store, they stocked Fender picks. Fender "Thin" work best for me for starters, but sometimes Fender "Medium" are needed. (Go to your local music store-- very cheap!) I have opened (and repaired successfully!) four different iPods just using guitar picks.
  3. iPod Classic Click Wheel Replacement: stap 3, afbeelding 1 van 1
    • Insert another plastic opening tool into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools.
  4. iPod Classic Click Wheel Replacement: stap 4, afbeelding 1 van 1
    • At an angle, carefully insert a putty knife about 1/8 inch into the seam between the two opening tools.
    • There are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
    • Once the putty knife has cleared the lip of the rear panel, pivot the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the gap between the opening tools.
    I tried this on the first iPod I was trying to fix. This method really messes up the sides of the iPod. Go back and read earlier comments about using guitar picks or other tools!
  5. iPod Classic Click Wheel Replacement: stap 5, afbeelding 1 van 1
    • Push with your fingers on the rear panel behind the putty knife to minimize bending. Slowly flex the putty knife, as shown in the picture, to ensure that most of the metal tabs on this side of the iPod are disengaged.
    • The theory behind this method is, rather than attempting to not bend the rear panel at all, to bend it in a favorable manner that allows you to easily restore it later. Therefore, any bend in the sides of the rear panel should be drawing the lip of the rear panel away from the iPod, rather than pushing out on the curved surface. This method also disengages as many of the side clips as possible.
  6. iPod Classic Click Wheel Replacement: stap 6, afbeelding 1 van 1
    • Remove the putty knife from the iPod and reinsert it closer to the corner of the iPod, using the same wiggle method as before.
    • If at all possible, do not bend the corner of the rear panel.
  7. iPod Classic Click Wheel Replacement: stap 7, afbeelding 1 van 1
    • Near the headphone jack, insert a plastic opening tool into the seam between the front and back of the iPod.
    • You may find it easier to carefully flex the putty knife downward in order to create more of a gap for the opening tool, but be sure not to bend the corner of the rear panel!
  8. iPod Classic Click Wheel Replacement: stap 8, afbeelding 1 van 1
    • Near the center of the display, carefully insert a metal spudger into the gap created by the plastic opening tool.
    • It is easy to create a noticeable bump in the rear panel here that is difficult to repair. When prying the tab free, try to have the metal spudger pivot on the edge of the rear panel rather than bending the rear panel outward.
    • Using the metal spudger, disengage the single clip on the top of the iPod.
  9. iPod Classic Click Wheel Replacement: stap 9, afbeelding 1 van 1
    • Near the other top corner, insert a plastic opening tool into the seam between the front and back of the iPod
  10. iPod Classic Click Wheel Replacement: stap 10, afbeelding 1 van 1
    • On the other side, insert a plastic opening tool into the seam between the front and back of the iPod.
    • You may find it easier to angle the opening tool stuck in the top corner in order to create a sufficient gap.
  11. iPod Classic Click Wheel Replacement: stap 11, afbeelding 1 van 1
    • Remove the opening tool from the top corner and insert it into the seam between the front and back of the iPod, leaving at least 1.5 inches of space between the two tools (as done on the other side).
  12. iPod Classic Click Wheel Replacement: stap 12, afbeelding 1 van 1
    • Again, there are thin metal rails running along the inside of the rear panel, so take great care when inserting the putty knife.
    • Once the putty knife has cleared the lip of the rear panel, angle the putty knife so that it is vertical, and carefully (but firmly) wiggle it straight down into the iPod via the gap between the plastic opening tools.
    • Push with your fingers on the rear panel behind the putty knife to minimize bending. Ever so slightly flex the putty knife to ensure that most of the metal tabs on this side of the iPod are disengaged.
  13. iPod Classic Click Wheel Replacement: stap 13, afbeelding 1 van 1
    • The metal clips near the corners are notorious for tenaciously gripping the front panel. It is necessary to disengage these clips in order to open the iPod.
    • Carefully insert a metal spudger into the area near the stubborn metal clip.
  14. iPod Classic Click Wheel Replacement: stap 14, afbeelding 1 van 1
    • Gently wiggle the metal spudger down so that it is all the way in the rear panel.
  15. iPod Classic Click Wheel Replacement: stap 15, afbeelding 1 van 1
    • Gently begin to disengage the clip from the front panel.
  16. iPod Classic Click Wheel Replacement: stap 16, afbeelding 1 van 1
    • Continue to push up on the front panel with the metal spudger until the metal clip releases.
  17. iPod Classic Click Wheel Replacement: stap 17, afbeelding 1 van 1
    • There are two ribbon cables connecting the rear panel to the rest of the iPod. In the following step, be careful not to damage these ribbon cables.
    • Grasp the front panel assembly with one hand and the rear panel with the other.
    • Take a deep breath!
    • Gently (GENTLY) disengage the remaining clips on the rear panel by pulling the tops of the front and rear panels away from each other (think of the bottom of the iPod as a hinge), taking great care not to damage the ribbon cables holding the two halves together.
  18. iPod Classic Click Wheel Replacement: stap 18, afbeelding 1 van 1
    • Use a spudger to slide up the connector holding the orange battery ribbon in place. You only need to lift the locking bar up about 2 mm to free the cable.
    • Slide the orange battery ribbon out of its connector.
    If the small battery black/white connector pumps out of the ipod when you are trying to unplug the cable...REMEMBER the "U" black shape is meant to be just in the same direction as the blue plastic "U" beside it. If you plug it back in the wrong way it will display "Charging please wait..." forever!.
    riverate - Antwoord
    How did you get the black battery piece to stay in after it popped out?
    Katrina Frantz -
    I knocked this little bit out too! Any tips to get it back in? Soldering?
    David Ewing -
    This step is what ultimately destroyed my iPod. A caution to be very careful would be good.
    I got the whole black white thing disconnected from the pins. After a lot of struggle I was able to get it back in, but I couldn’t get the black locking part to go up on its own. after many tries and some tries to get it in when the black thing is closed, i tore out the pins that were connected to the panel. can’t get it back on so it isn’t connected to the battery…
    Now i have a perfect iPod with a new harddrive but I can’t use it.
    Please add a red caution sentence because I’m pretty sure that if i had known what I had to do I would’ve been more careful and I would now have a functioning iPod.
    Nonetheless, great guide! without this I wouldn’t even have tried and the harddisk came from another broken down iPod classic so it’s not that I lost money.
    stef.kuypers - Antwoord
    I got the whole battery clamp connector (black and white) all out too… So angry about it! I thought that the white part should be disconnected too, like former iPod models. Be careful, you only have to release the BLACK locking bar! One more photo with a zoom on the battery connector could have been useful… Great guide anyway :-)!
    kabalbuzard - Antwoord
    Hello! Trying to identify the problem on my Ipod. I think I'm not qualified to open it and do the fixing. Do you know a shop or someone in Paris that would try it? Apple says they are not qualified anymore.
    Thanks in advance!
    Baudu Camille - Antwoord
    OK, you have to be really careful with this step! If you pry too hard, the little plastic clamp that holds the cable will come up too far and break, and then you are ****ed. It only needs to be raised millimeter or two, but at first, it doesn't move at aIl, so it is easy to pry upwards too hard. I have found that using angled tweezers while VERY GENTLY prying upwards on both sides works best. But still, BE VERY CAREFUL AND GENTLE! It's also easy not to even know that it is up all the way! So every now and then try gently lifting the ribbon cable to see if it is already released.
  19. iPod Classic Click Wheel Replacement: stap 19, afbeelding 1 van 1
    • Place the rear panel next to the iPod, being careful not to strain the orange headphone jack cable.
  20. iPod Classic Click Wheel Replacement: stap 20, afbeelding 1 van 1
    • Lift the hard drive up with one hand so you can access the headphone jack ribbon beneath.
    • Use a spudger to flip up the plastic tab holding the headphone jack ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
    • Slide the orange headphone jack ribbon out of its connector.
    • The rear panel is now free from the iPod.
    I broke off the plastic tab I lost it any suggestions. How could I replace the plastic tab?
    Fabio a - Antwoord
  21. iPod Classic Click Wheel Replacement: stap 21, afbeelding 1 van 1
    • Now to repair the damage caused by liberating the internal parts of the iPod Classic! It is highly likely that at least one of the metal clips in the lower case has been bent upward. These clips must all be pointing downward in order to reinstall the rear panel.
  22. iPod Classic Click Wheel Replacement: stap 22, afbeelding 1 van 1
    • Take the broad, flat side of the metal spudger and push the clip down, taking care not to tear the thin metal rail from the rear panel.
    • Be careful not to damage any of the headphone jack parts while shaping these clips!
  23. iPod Classic Click Wheel Replacement: stap 23, afbeelding 1 van 1
    • On a clean, hard surface, lay the rear panel on its side. Carefully but firmly push down on it, rolling the entire lip side back into its proper spot.
    • It may be necessary to do this multiple times in order to achieve optimal straightness on the sides. It is better to have the edges of the case pushed in slightly too far rather than not far enough, because the reseating of the front panel will bend the rear panel into its correct alignment.
    • Now that the rear panel is back to a beautiful condition, you can move on to repairing the iPod!
  24. iPod Classic Click Wheel Replacement: stap 24, afbeelding 1 van 1
    • Rotate the hard drive out of the framework and place it so that the connector is facing up.
    • Use a spudger to flip up the small black locking tab holding the orange hard drive ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
    To be clear, the plastic tab to be flipped up is the SMALL BLACK piece shown vertically in the photo above. The spudger is pointing directly to it. The tab flips TOWARDS the ribbon. While the picture is correct, this wasn’t obvious to me.
    Linda and Brian Henning - Antwoord
    Thanks for the feedback! I will adjust the wording to clarify this.
    Arthur Shi -
  25. iPod Classic Click Wheel Replacement: stap 25, afbeelding 1 van 1
    • Slide the orange hard drive ribbon cable directly out of its connector.
    • If you are replacing the hard drive in your iPod and it did not come with the rubber mounting brackets and foam padding, transfer these items from your old drive to the replacement drive.
  26. iPod Classic Click Wheel Replacement, Front Panel: stap 26, afbeelding 1 van 1
    • Remove the three Phillips screws securing the front panel to the metal framework.
  27. iPod Classic Click Wheel Replacement: stap 27, afbeelding 1 van 1
    • Rotate the iPod 180 degrees and remove the three Phillips screws securing the front panel to the metal framework on the other side.
  28. iPod Classic Click Wheel Replacement: stap 28, afbeelding 1 van 1
    • Carefully work around the edges of the iPod to separate the front panel from the gray metal framework.
    • You may meet some resistance, as there is a mild adhesive used to help hold the two pieces together.
    I would suggest prying with a tool on one of the lips that holds the front place on, but do NOT pry on one near the LCD screen or you may damage the screen. Also, don't forget there is an extra small latch on the top of the LCD that has to be loosened too.
    iTronics Repair - Antwoord
    I pressed gently on the click wheel on the play botton side first to help unlock the glue. Keep away from the screen side best you can.
    Stephen Sherry - Antwoord
    After reading all your warnings and how risky it is to damage my IPOD I don’t dare to replace the display which got out of light and I no longer see the text. I planned to send for a new but it seems like the possibility to succeed without damaging the IPOD is less than succeeding. It is really a pity since I love it snd have so much good music saved to it. I usually fix my damaged apparatus but this seems more orf ess impossible after reading the text. I am really sad/devastated!! :
    JaneGBG - Antwoord
  29. iPod Classic Click Wheel Replacement: stap 29, afbeelding 1 van 1
    • Lift the framework (including the attached screen, logic board, and click wheel) away from the front panel.
    • Make sure that the click wheel button is in place before reinstalling the framework in the front panel.
  30. iPod Classic Click Wheel Replacement: stap 30, afbeelding 1 van 1
    • The front panel is now free from the iPod.
  31. iPod Classic Click Wheel Replacement, Click Wheel: stap 31, afbeelding 1 van 1
    • Use a spudger to flip up the plastic tab holding the orange display ribbon in place. The tab will rotate up 90 degrees towards the display, releasing the ribbon cable.
  32. iPod Classic Click Wheel Replacement: stap 32, afbeelding 1 van 1
    • Slide the orange display ribbon cable directly out of its connector.
  33. iPod Classic Click Wheel Replacement: stap 33, afbeelding 1 van 1
    • Lift the framework assembly up, and slide the display and LCD metal backplate out of the framework assembly.
  34. iPod Classic Click Wheel Replacement: stap 34, afbeelding 1 van 1
    • Remove the two Phillips screws securing the logic board to the framework.
  35. iPod Classic Click Wheel Replacement: stap 35, afbeelding 1 van 1
    • Carefully push the logic board away from the metal framework.
    • The logic board is secured to the framework with mild adhesive. Be careful not to bend the logic board by pushing too much in any one spot.
  36. iPod Classic Click Wheel Replacement: stap 36, afbeelding 1 van 1
    • Move the click wheel from beneath the logic board so that the icons on the click wheel are visible.
    • Use a spudger to flip up the plastic tab holding the orange click wheel ribbon in place. The tab will rotate up 90 degrees, releasing the ribbon cable.
  37. iPod Classic Click Wheel Replacement: stap 37, afbeelding 1 van 1
    • Use a spudger to lift the click wheel cable off the logic board. Be careful not to bend the cable too much, or the electronics on the cable could be damaged.
    • When reinstalling the clickwheel, make sure that the click wheel cable is pushed all the way into its connector.
  38. iPod Classic Click Wheel Replacement: stap 38, afbeelding 1 van 1
    • Slide the click wheel cable out of its connector.
    • Lift the click wheel assembly away from the logic board.
    • Don't forget the click wheel button when putting your iPod back together.
Conclusie
Before you snap the case shut, be sure to test the device to ensure that it's working properly.
53 andere personen hebben deze handleiding voltooid.
iRobot
1 Reputatie
636 handleidingen geschreven
6 opmerkingen
It was a lot easier than it looks only took 45min thanks ifixit for the guide. Cheers
ridin68 - Antwoord
Thanks ifixit.com
Mohamed Nazrin - Antwoord
Excellent guide. I got lucky and did this is 30 mins and replaced the battery while it was apart. It was 9.00 online. Great to have my 160GB iPod 5th gen video clickwheel back in action!!
Faslane - Antwoord
Waiting on parts. Will update when finished.
yat7yas892 - Antwoord
I replaced the clickwheel and now it isnt responding when i click or try to use the clickwheel.
Lord of Ender1 - Antwoord
Did you ever figure out why? Mine is doing the same thing. Thanks!
Caleb Christel -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 11
Afgelopen 7 dagen: 63
Afgelopen 30 dagen: 383
Altijd: 101,283
