Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Upgrade your storage with a new hard drive.
Wat je nodig hebt
Insert an opening pick as far as possible into the seam between the plastic front and the metal rear panel, on the right edge of the iPod.
Use the opening pick to pry up against the plastic front panel and release five retaining tabs (seen in the third photo).
Slide the pick along the edge of the iPod and continue prying to release the rest of the retaining tabs.
After all five tabs along the right side are free, the case should easily open.
Grasp the hard drive with one hand and carefully disconnect the orange ribbon cable from the hard drive using your other hand.
132 andere personen hebben deze handleiding voltooid.
16 opmerkingen
Just to let anyone wondering know: today I replaced the HDD with a 60 GB SSD - works like a charm. Maybe I can use this pod for another 8 years! :-)
Hi Stefan,
Iam very interested in replace my ipod photo HDD with a 60 GB SSD . What kind of SSD did you use?
Thank you
Luiz Bandeira
Brazil
I have a 4th generation iPod color 20GB. I tried to replace the hard drive with KingSpec 32GB SSD it didn't work it had formatting issues. I then did what most people do and bought a compact flash (CF) to 50 pin 1.8” IDE adapter. The adapter I bought came with a case the adapter's circuit board is red and has a master/slave switch on it. The case looks like a hard drive so the padding and bumpers on the Ipod's original hard drive can be reused with ease. Some people have had success with the KingSpec's SSD it is a nice option because it doesn't need an adapter. I have seen talk on the internet about iPod logic board versions and drive compatibility so maybe this is why the SSD didn't work for me. The key to converting to solid state is having a good adapter with the right brand and model of CF. I used a Kingston Ultimate 32GB CF it was indicated on Tarkan's website to be compatible with all iPods. Everything works perfectly now after installing the CF card with adapter.
