Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Inleiding
Is your SIM card getting stuck in your phone? Use this guide to replace, or reseat a faulty SIM eject lever in your iPhone SE.
  1. Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
  2. If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping the glass. Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered. This will keep glass shards contained and provide structural integrity when prying and lifting the display.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  3. In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips. Regardless of the tool you use, you need to be sure you pull up the entire display. If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone that we recommend for anyone doing more than one repair. If you aren't using the iSclack, skip the next two steps.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  4. Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case. The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the home button cable.
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage the home button cable.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on Step 9.
  5. If you don't have an iSclack, use a single suction cup to lift the front panel:
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
  6. The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
    • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
    • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
    • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
    • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
  7. Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them. Pull the plastic nub to release the vacuum seal on the suction cup.
    • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the screen.
  8. Open the phone just enough to reveal the metal bracket covering the home button cable. Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched taut, that's too far. Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
    • Open the phone just enough to reveal the metal bracket covering the home button cable.
    • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched taut, that's too far.
    • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
    • Use the tip of a spudger to push the bracket free and remove it with tweezers.
    • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
  9. During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector. Slide the top of the bracket over the Touch ID cable connector from left to right.
    • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
    • Slide the top of the bracket over the Touch ID cable connector from left to right.
  10. During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector. If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
    • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
    • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
  11. Use the tip of a spudger to pry the home button cable connector up out of its socket. Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
    • Use the tip of a spudger to pry the home button cable connector up out of its socket.
    • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
  12. Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  13. Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  14. Remove the metal battery connector bracket from the iPhone.
    • Remove the metal battery connector bracket from the iPhone.
  15. Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board. Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
    • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  16. Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • One 1.7 mm Phillips #000 screw
    • One 1.2 mm Phillips #000 screw
    • One 1.3 mm Phillips #000 screw
    • One more 1.7 mm Phillips #000 screw
    • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
  17. Remove the front panel assembly cable bracket from the logic board.
    • Remove the front panel assembly cable bracket from the logic board.
  18. Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable. Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
  19. Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Disconnect the LCD cable connector.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the LCD cable connector.
    • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  20. Finally, disconnect the digitizer cable connector. Finally, disconnect the digitizer cable connector.
    • Finally, disconnect the digitizer cable connector.
  21. Remove the front panel assembly from the rear case.
    • Remove the front panel assembly from the rear case.
  22. Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray. Press to eject the tray. This may require a significant amount of force.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray. This may require a significant amount of force.
  23. Remove the SIM Card tray assembly from the iPhone.
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  24. Remove the 2.1 mm Phillips #00 securing the SIM eject lever.
    • Remove the 2.1 mm Phillips #00 securing the SIM eject lever.
  25. Remove the SIM eject lever from the iPhone. Note the orientation for reassembly; the wider end should line up with the SIM eject hole.
    • Remove the SIM eject lever from the iPhone.
    • Note the orientation for reassembly; the wider end should line up with the SIM eject hole.
Conclusie
9 andere personen hebben deze handleiding voltooid.
Sam Goldheart
433.486 Reputatie
547 handleidingen geschreven
iFixit Lid van iFixit
Community
134 Leden
14.648 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 127
Altijd: 4,526
