Ga door naar hoofdinhoud
Wat je nodig hebt
  1. iPhone SE Lightning Connector Replacement, Removing the Pentalobe screws: stap 1, afbeelding 1 van 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.9 mm Pentalobe screws from either side of Lightning connector.
  2. iPhone SE Lightning Connector Replacement, Taping the display glass: stap 2, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement, Taping the display glass: stap 2, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement, Taping the display glass: stap 2, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  3. iPhone SE Lightning Connector Replacement, Display separation prevention: stap 3, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement, Display separation prevention: stap 3, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement, Display separation prevention: stap 3, afbeelding 3 van 3
    • In the following steps you will be pulling the display up out of the phone body. The display is composed of a glass screen and a plastic bezel with metal clips.
    • Regardless of the tool you use, you need to be sure you pull up the entire display.
    • If the glass begins to separate from the plastic, as shown in the first image, slide a plastic opening tool between the plastic frame and the metal phone body to pry the metal clips out of the case.
    • If you are reassembling a phone with a separated display bezel, you may want to place a thin strip of adhesive between the plastic bezel and the glass to keep the phone closed.
  4. iPhone SE Lightning Connector Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down two steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle towards the hinge to disengage opening mode.
    • Position the suction cups just above the home button on the screen—one on the front, and one on the back.
    • Push down on the cups to apply suction to the desired area.
    • If you find that the surface of your device is too slippery for the Anti-Clamp to hold onto, you can use packing tape to create a grippier surface.
  5. iPhone SE Lightning Connector Replacement: stap 5, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement: stap 5, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement: stap 5, afbeelding 3 van 3
    • Push the blue handle away from the hinge to engage opening mode.
    • Turn the handle clockwise until you see the cups start to stretch.
    • Make sure the suction cups remain aligned to each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Wait one minute to give the adhesive a chance to release and for the bottom of the screen to open.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  6. iPhone SE Lightning Connector Replacement, Manual Opening Procedure: stap 6, afbeelding 1 van 1
    • If you don't have an iSclack, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
  7. iPhone SE Lightning Connector Replacement, Start lifting the front panel assembly: stap 7, afbeelding 1 van 1
    • The front panel is attached with clips, and there are several ribbon cables connecting it to the rest of the phone. Your goal here is to release the clips and open the phone only enough to disconnect the cables. Go slowly and carefully to avoid damage.
    • Make sure the suction cup is firmly attached to the front panel assembly near the home button.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the home button end of the front panel from the rear case.
    • With a plastic opening tool, gently pry the edges of the rear case down, away from the front panel assembly, while you pull up with the suction cup.
    • Take your time and apply firm, constant force. The front panel assembly is a much tighter fit than on most other devices.
  8. iPhone SE Lightning Connector Replacement: stap 8, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 8, afbeelding 2 van 2
    • Do not try to completely remove the front panel assembly from the rear case, as there are several delicate ribbon cables connecting them.
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the screen.
  9. iPhone SE Lightning Connector Replacement, Removing the Touch ID cable bracket: stap 9, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement, Removing the Touch ID cable bracket: stap 9, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement, Removing the Touch ID cable bracket: stap 9, afbeelding 3 van 3
    • Open the phone just enough to reveal the metal bracket covering the home button cable.
    • Do not open the phone too far or you risk damaging the home button cable, or the socket it plugs into. Keep the cable loose—if it is stretched taut, that's too far.
    • Only the phone's original home button assembly will be capable of using the Touch ID functionality. If you rip the cable, installing a new home button will only restore ordinary home button functions, not the Touch ID features.
    • Use the tip of a spudger to push the bracket free and remove it with tweezers.
    • The next two steps apply to reassembly. Skip them and continue to Step 12 until reassembly.
  10. iPhone SE Lightning Connector Replacement: stap 10, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 10, afbeelding 2 van 2
    • During reassembly, you will need to reinstall the Touch ID cable bracket. The top of the bracket needs to slide between the battery and Touch ID cable connector, in front of the metal tab. The bottom must latch down over the connector.
    • Slide the top of the bracket over the Touch ID cable connector from left to right.
  11. iPhone SE Lightning Connector Replacement: stap 11, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 11, afbeelding 2 van 2
    • During reassembly, use the flat end of a spudger to snap the front portion of the Touch ID cable bracket down over the cable connector.
    • If the bracket does not snap down flush, you may need to remove the bracket and slide it over the cable connector again for a better fit.
  12. iPhone SE Lightning Connector Replacement, Disconnecting the home button cable connector: stap 12, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement, Disconnecting the home button cable connector: stap 12, afbeelding 2 van 2
    • Use the tip of a spudger to pry the home button cable connector up out of its socket.
    • Be sure you're separating the cable connector from its socket, and not prying the entire socket up. The socket is on its own glued-down cable that can be pried up if you aren't careful.
  13. iPhone SE Lightning Connector Replacement, Opening up the phone: stap 13, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement, Opening up the phone: stap 13, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement, Opening up the phone: stap 13, afbeelding 3 van 3
    • Once the connector has been released, pull the home button end of the assembly away from the rear case, using the top of the phone as a hinge.
    • Open the display to about a 90Âş angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  14. iPhone SE Lightning Connector Replacement: stap 14, afbeelding 1 van 1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  15. iPhone SE Lightning Connector Replacement: stap 15, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
  16. iPhone SE Lightning Connector Replacement: stap 16, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 16, afbeelding 2 van 2
    • Use the flat end of a spudger to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  17. iPhone SE Lightning Connector Replacement: stap 17, afbeelding 1 van 1
    • Remove the following screws securing the front panel assembly cable bracket to the logic board:
    • One 1.7 mm Phillips #000 screw
    • One 1.2 mm Phillips #000 screw
    • One 1.3 mm Phillips #000 screw
    • One more 1.7 mm Phillips #000 screw
    • This 1.7 mm screw tends to not be attracted to a magnetized screwdriver. Take care not to lose it when removing.
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 1.3 mm screw or one of the 1.7 mm screws in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws, and don't force them. If they don't fit easily when you are securing them, they may be the wrong size.
  18. iPhone SE Lightning Connector Replacement: stap 18, afbeelding 1 van 1
    • Remove the front panel assembly cable bracket from the logic board.
  19. iPhone SE Lightning Connector Replacement: stap 19, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 19, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable.
  20. iPhone SE Lightning Connector Replacement: stap 20, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 20, afbeelding 2 van 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the LCD cable connector.
    • When reassembling your phone, the LCD cable may pop off the connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  21. iPhone SE Lightning Connector Replacement: stap 21, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 21, afbeelding 2 van 2
    • Finally, disconnect the digitizer cable connector.
  22. iPhone SE Lightning Connector Replacement: stap 22, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
  23. iPhone SE Lightning Connector Replacement, Speaker: stap 23, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement, Speaker: stap 23, afbeelding 2 van 2
    • Use the tip of a spudger to pry the antenna cable up from its socket on the logic board.
    • To reconnect the cable, use tweezers to position it directly over its socket, then push it straight down with the flat edge of your spudger.
  24. iPhone SE Lightning Connector Replacement: stap 24, afbeelding 1 van 1
    • Remove the following Phillips #000 screws:
    • One 2.9 mm screw
    • One 1.5 mm screw
    • One 3.6 mm screw
  25. iPhone SE Lightning Connector Replacement: stap 25, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 25, afbeelding 2 van 2
    • Use the point of a spudger to gently pry between the speaker and the rear case, lifting the speaker enough to grab with your fingers.
    • Do not attempt to pry the speaker entirely out of the case, you may break plastic tabs holding the speaker in place.
  26. iPhone SE Lightning Connector Replacement: stap 26, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement: stap 26, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement: stap 26, afbeelding 3 van 3
    • Swivel the speaker downwards and toward the left of the phone to free the upper tab from underneath the logic board.
    • Slide the speaker up and to the right to free the left-hand tab from under the home button cable connector.
    • Remove the speaker from the iPhone.
  27. iPhone SE Lightning Connector Replacement, Lightning Connector: stap 27, afbeelding 1 van 1
    • Remove the following four Phillips #000 screws:
    • One 3.1 mm screw
    • One 2.9 mm screw
    • One 1.5 mm screw
    • One 3.4 mm screw
  28. iPhone SE Lightning Connector Replacement: stap 28, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 28, afbeelding 2 van 2
    • Use a spudger to pry the Lightning connector cable up from its socket on the logic board.
  29. iPhone SE Lightning Connector Replacement: stap 29, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 29, afbeelding 2 van 2
    • The Lightning connector data cable is held to the logic board and rear case with mild adhesive.
    • Use an opening pick to slowly separate the cable from the logic board.
  30. iPhone SE Lightning Connector Replacement: stap 30, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement: stap 30, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement: stap 30, afbeelding 3 van 3
    • Continue prying with the flat end of a spudger.
  31. iPhone SE Lightning Connector Replacement: stap 31, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement: stap 31, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement: stap 31, afbeelding 3 van 3
    • Continue prying with an opening pick to separate the Lightning connector assembly from the rear case.
    • Be sure to separate all parts of the assembly from the rear case, including the Lightning connector, headphone jack and home button cable socket.
  32. iPhone SE Lightning Connector Replacement: stap 32, afbeelding 1 van 2 iPhone SE Lightning Connector Replacement: stap 32, afbeelding 2 van 2
    • Remove the Lightning connector assembly.
    • Examine your replacement part, and your original cable carefully to be sure they match. Your replacement Lightning connector assembly may be missing certain components that need to be transferred from the original.
    • Components that commonly need to be transferred include a clip routed along the left and top edges of the headphone jack, the rubber microphone cover, and the bracket for the Touch ID cable connector.
  33. iPhone SE Lightning Connector Replacement: stap 33, afbeelding 1 van 3 iPhone SE Lightning Connector Replacement: stap 33, afbeelding 2 van 3 iPhone SE Lightning Connector Replacement: stap 33, afbeelding 3 van 3
    • There are several spacers loosely placed on screw posts under the Lightning connector assembly. While not essential to phone function, you should replace these washers where you found them when reassembling the phone. Spacers may vary between devices, this unit has spacers as follows:
    • One bracket
    • One C washer
    • Two small washers
    • If you are removing more components, take these pieces out and set them aside for safe keeping.
Conclusie
135 andere personen hebben deze handleiding voltooid.
Sam Goldheart
455.927 Reputatie
548 handleidingen geschreven
iFixit Lid van iFixit
Community
141 Leden
15.839 handleidingen geschreven
21 opmerkingen
Just so everyone knows, this flex cable is not the same at the iPhone 5s flex cable.
Eddie - Antwoord
I tried replacing this part after my phone constantly was searching for signal. After replacing now I only have 1x signal. Wifi, BT still work. Any idea what went wrong? iPhone SE Sprint.
Aaron - Antwoord
Thanks for all the awesome guides!!
jamieoyakawa - Antwoord
After replacing my screen it is now just a black screen can't see any thing on it! What could it b?
Aleha Overcast - Antwoord
Changed and the headphone still doesn’t work any ideas?
austin barney - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 51
Afgelopen 7 dagen: 283
Afgelopen 30 dagen: 1,222
Altijd: 111,943
