Ga door naar hoofdinhoud
iPhone Camera Repair
Wat je nodig hebt
Video overzicht
  1. iPhone Camera Repair, main camera: stap 1, afbeelding 1 van 2 iPhone Camera Repair, main camera: stap 1, afbeelding 2 van 2
    • Today, REWA LAB will share with you a repair case of an iPhone camera and walk you through some knowledge of iPhone camera repair.
    • Open the phone camera. When taking photos with the wide-angle camera, cracks appear. The ultra-wide camera works fine. We can judge that the optical filter of the wide-angle camera is damaged.
  2. iPhone Camera Repair: stap 2, afbeelding 1 van 3 iPhone Camera Repair: stap 2, afbeelding 2 van 3 iPhone Camera Repair: stap 2, afbeelding 3 van 3
    • We can judge that the optical filter of the wide-angle camera is damaged. Then we disassemble the phone and try to repair the camera. First of all, put the camera on the specialized Heating Platform at 100 °C.
    • When the temperature reaches 100 °C, remove black adhesive around the camera with a Sculpture Knife. Then pry up the wide-angle camera.
    • Attach the camera to the specialized holder. Before repair, apply protection tape to the camera.
  3. iPhone Camera Repair: stap 3, afbeelding 1 van 3 iPhone Camera Repair: stap 3, afbeelding 2 van 3 iPhone Camera Repair: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    • Separate the camera edges with a Sculpture Knife. Next, remove the metal cover with Hot Air Gun at 120 °C.
    • Keep heating with Hot Air Gun at 120 °C. Remove black adhesive with Tweezers. Apply some Paste Flux.
    • Separate the motor from the CMOS with ultrathin Soldering Iron at 380 °C
  4. iPhone Camera Repair: stap 4, afbeelding 1 van 2 iPhone Camera Repair: stap 4, afbeelding 2 van 2
    • It can be seen that the optical filter is broken while the motor and blue lens are good. If the motor is damaged, the camera will fail to focus or shake. A motor replacement can help you solve the problem.
    • The middle part of the motor is the blue lens. If the blue lens is damaged, the camera will become blurry. The solution is to replace the blue lens.
    • Then we replace the cracked optical filter with a new one.
  5. iPhone Camera Repair: stap 5, afbeelding 1 van 3 iPhone Camera Repair: stap 5, afbeelding 2 van 3 iPhone Camera Repair: stap 5, afbeelding 3 van 3
    • Apply some UV adhesive to the broken optical filter.
    • Put the new optical filter in position.
    • Solidify with a UV Lamp.
  6. iPhone Camera Repair: stap 6, afbeelding 1 van 3 iPhone Camera Repair: stap 6, afbeelding 2 van 3 iPhone Camera Repair: stap 6, afbeelding 3 van 3
    • Remove side adhesive with Hot Air Gun.
    • Then push the cracked optical filter out with the specialized holder.
    • Remove residual shards and black adhesive with Hot Air Gun.
  7. iPhone Camera Repair: stap 7, afbeelding 1 van 3 iPhone Camera Repair: stap 7, afbeelding 2 van 3 iPhone Camera Repair: stap 7, afbeelding 3 van 3
    • Then remove dust spots with a specialized swab. Please be extremely careful not to damage the CMOS during operation. If the CMOS is damaged, the camera will be unrepairable.
    • Then apply some UV adhesive and a new optical filter. Solidify with UV Lamp.
  8. iPhone Camera Repair: stap 8, afbeelding 1 van 3 iPhone Camera Repair: stap 8, afbeelding 2 van 3 iPhone Camera Repair: stap 8, afbeelding 3 van 3
    • Then we assemble the camera. Apply some Paste Flux around the motor. Solder the motor with the CMOS with Soldering Iron. Clean the camera with alcohol.
    • Next, we install the wide-angle camera for testing. The camera works fine. Apply B7000 to fix the wide-angle camera. That’s all for the optical filter replacement of iPhone camera.
Conclusie
7 andere personen hebben deze handleiding voltooid.
REWA
16.556 Reputatie
55 handleidingen geschreven
2 opmerkingen
Good job! But, the cost of labor and material is not economical. It is still wise to buy the whole camera module as a replacement. Easier and more practical.
On the other hand, if the viewer opted to do the filter replacement, this is a great reference since Rewa is a reputable company. Thank you for sharing this useful guide.
Jojo - Antwoord
Incrível! Parabéns!!
Daan.ll - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 123
Afgelopen 30 dagen: 466
Altijd: 21,822
