Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Inleiding
Use this guide to correctly apply replacement battery adhesive strips in many late-model iPhones. Any time you remove the battery, these strips must be replaced. The strips are easily damaged if not applied correctly, so you may want to have a spare set of strips on hand if following this guide for the first time.
The larger iPhone "Plus" models use three strips instead of two, but the procedure is the same.
Before you begin, you should have removed the battery by following a guide like the ones linked below. Note: iPhone 5 and earlier models do not use any adhesive strips.
- iPhone 6 Battery Replacement
- iPhone 6 Plus Battery Replacement
- iPhone 6s Battery Replacement
- iPhone 6s Plus Battery Replacement
- iPhone 7 Battery Replacement
- iPhone 7 Plus Battery Replacement
To replace the battery adhesive strips in a different model iPhone, use one of the following guides:
Wat je nodig hebt
Video overzicht
If your new battery came with adhesive strips already stuck on, skip to Step 7.
Otherwise: If present, remove the small plastic film(s) covering the flat ends of the adhesive strips.
Place the battery face down on a flat surface.
Starting at the pointed end of the adhesive strips, peel off the large blue film covering the strips.
If this happens to you and you got your strips from iFixit, contact us here and we'll send you a replacement on the double.
In the meantime, you can temporarily reassemble your iPhone with a bit of double-sided tape to hold the battery.
To reassemble your iPhone, return to the guide you used to remove the battery and follow the steps in reverse order.
Remember to take your old battery to an R2 or e-Stewards certified recycler.
1618 andere personen hebben deze handleiding voltooid.
68 opmerkingen
I had to read these directions thoroughly three times before proceeding as I didn't want to screw it up on the adhesive. Went slow and it worked just fine
I would say jus watch out as you go from step 4 to step 5 - the white adhesive can become slightly detached from the backing as you push it onto the edge of the battery and then around to the back side. Extreme care here! Very good guide and equipment. Galaxy class!
All was good, aside from the adhesive bunched up when I removed the blue backing and it started to separate from the pink backing. I had to just gingerly make sure it was all straight and kept steady like a heart surgeon until I had it smoothed down as best as possible. It all went well, but I was worried I'd end up with a big stuck ball of white adhesive in the middle of the battery plate, making it all uneven and stupid looking.
What happens if I use a different adhesive than this one?
The iPhone adhesive strips we sell (and the original Apple ones) are special since they have very strong adhesion, but they can be removed easily by pulling on the tabs on the lower edge of the battery. People have had success with our 3M double-sided sticky tape (aka sticker tape), but standard plastic double-sided tape may not have enough strength to hold the battery in place. If you want the strongest adhesive possible, you should use iPhone adhesive strips mentioned above, but if your phone isn't subject to lots of movement, you could get by with some sticker tape.
