Ga door naar hoofdinhoud
iPhone 8 Plus Top Left Antenna Replacement
Wat je nodig hebt
  1. iPhone 8 Plus Top Left Antenna Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    what do I do about super stripped screws?
    Ean Palacios - Antwoord
    I’m sorry, your comment slipped past my radar earlier. For future fixers that might see this and ask the same question, you can check out our stripped screw guide for some detailed advice.
    Adam O'Camb -
    Do you need a toolkit like the essential toolkit
    Adam Palmer - Antwoord
    Hi Adam. Having a tool kit with all of the listed parts above is best. The screw heads are very small and each set of screws needs a very specific type of driver to remove them without stripping any of them.
    Kyle Luksa -
  2. iPhone 8 Plus Top Left Antenna Replacement, Mark your opening picks: stap 2, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement, Mark your opening picks: stap 2, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement, Mark your opening picks: stap 2, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
    Got to step 2 and realized the fix kit doesn't include an opening pick! Looks like a guitar pick, and I have those lying around. Is that expected? Looks like the pick is used in many steps below. There's a little blue crowbar that isn't mentioned in the instructions. Perhaps that replaces the opening pick?
    Sloan Looney - Antwoord
    Hi! I can't see which guide you were using when writing this comment. Can you reply here with which guide and fix kit you used?
    Clay Eickemeyer -
    I see you posted this in Meta. I hope it's resolved soon! In the meantime, a guitar pick may work well enough for your repair.
    Clay Eickemeyer -
    what fix kit?
    Meow Purr -
    My fix kit didn't include an opening pick either
    WILLIAM HARRIS - Antwoord
    Make sure you check inside the black boxes after emptying them. My pick was stuck inside one of the boxes.
    AndyF - Antwoord
    My AliExpress refurbished screen came with a pick that has a coin-like circle that pops out, so no modification was necessary
    Gijs Leegwater - Antwoord
  3. iPhone 8 Plus Top Left Antenna Replacement, Tape over any cracks: stap 3, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement, Tape over any cracks: stap 3, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement, Tape over any cracks: stap 3, afbeelding 3 van 3
    • If your iPhone has a cracked screen, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's screen until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If you can't get the suction cup to stick in the next few steps, fold a strong piece of tape (such as duct tape) into a handle and lift the screen with that instead.
    • If all else fails, you can superglue the suction cup to the screen.
  4. iPhone 8 Plus Top Left Antenna Replacement, Anti-Clamp instructions: stap 4, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement, Anti-Clamp instructions: stap 4, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement, Anti-Clamp instructions: stap 4, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  5. iPhone 8 Plus Top Left Antenna Replacement: stap 5, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 5, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 5, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  6. iPhone 8 Plus Top Left Antenna Replacement: stap 6, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 6, afbeelding 2 van 2
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer, heat gun, or hot plate—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the iPhone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  7. iPhone 8 Plus Top Left Antenna Replacement: stap 7, afbeelding 1 van 1
    • The next three steps show how to separate the screen using a suction cup.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
    6/14/23 I did this repair but used a heat gun on low for 60 seconds. This allowed me to open the case as the instructions say, but in the end the Home button failed. I probably over heated it. I used this "go around" for a virtual Home button. I don't care about touch ID:
    https://www.youtube.com/watch?v=LbTlUm4p...
    laryball - Antwoord
  8. iPhone 8 Plus Top Left Antenna Replacement: stap 8, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 8, afbeelding 2 van 2
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    Warning ! If you pull too hard (reheat the underside of the display again), you create an gap of air between the glass and the lcd display !
    When you replace the display assembly you end up with gray stains on the display.
    Result: you have to buy a new display (assembly).
    Arnoud - Antwoord
    Using just the single suction cup that is included in the battery replacement kit probably wouldn’t open the device. An iOpener and an iSlack should be the recommended method. However, you can get it open with just the single suction cup and iOpener, but does take a lot of time.
    Get an iOpener and iSlack with the battery replacement kit.
    Chris - Antwoord
    I used a flat x-acto (#18) blade knife tool to gently pry back the screen enough to allow me to insert the pick near the bottom corner. I then worked the pick under the screen as mentioned in steps 5 & 6 below then. This worked really well for me.
    Kyle Luksa - Antwoord
    I used the suction cup without heating the phone - the adhesive came away quite easily without applying any heat. Maybe due to age of phone (nearly 4 years old). Worth trying.
    Ben Vinnerd - Antwoord
    I can’t get the single suction cup to work. Hate being stuck on the simplest step!
    Donny - Antwoord
    My screen was very shattered, and was quite hard to get suction, as my tape was very low quality. However, after pulling it up a little bit, I was able to insert a regular razor blade into the very small gap and used that as a lever.
    Michael Scroop - Antwoord
    Oh my goodness! Don't do that again. You can definitely damage something in the phone if you use a sharp metal razor blade..
    cytur -
  9. iPhone 8 Plus Top Left Antenna Replacement: stap 9, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 9, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 9, afbeelding 3 van 3
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert an opening pick or other thin pry tool a few millimeters into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, apply more heat, and gently rock the screen up and down to weaken the adhesive until you create enough of a gap to insert your tool.
    After multiple tries and using a very hot iOpener, it will not open.
    Kenneth Ewald, Sr. - Antwoord
    In sheer frustration, I pulled out my trusty pocket knife and managed to lift the bottom of the screen slightly, but in the process, cracked the glass from the bottom to the home button. The case is open now.
    this was by far the most difficult part. be diligent and follow the “firm and constant pressure” guide... the “gap” will be extremely “slight”. you will be able to slide a corner of the pry tool even if you cannot see the gap.
    Colleen V - Antwoord
    This needs a TON of strength and most likely a partner. Your strong partner will pull up the screen with the suction cup and you will put the pick into the small gap that appears.
    cytur - Antwoord
  10. iPhone 8 Plus Top Left Antenna Replacement: stap 10, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 10, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 10, afbeelding 3 van 3
    • Slide your pick around the corner and up the left edge of the phone, moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Stop near the top left corner of the display.
    Do not go over the top otherwise you can crack the screen. Sadly happened to me :(
    The instruction should be:
    “Stop near BUT BEFORE REACHING the top left corner of the display”
    Leonardo Piga - Antwoord
  11. iPhone 8 Plus Top Left Antenna Replacement, Screen information: stap 11, afbeelding 1 van 1
    • There's a delicate cable along the right edge of your iPhone. Don't insert your pick here, as you may damage the cable.
  12. iPhone 8 Plus Top Left Antenna Replacement: stap 12, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 12, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 12, afbeelding 3 van 3
    • Re-insert your tool at the lower right corner of the iPhone, and slide it around the corner and up the right side of the phone to separate the adhesive.
    • Don't insert your pick more than 3 mm, as you may damage the display cables.
    I had really good luck using a hairdryer on some of the more stubborn portions of adhesive.
    Jessica Kirsh - Antwoord
  13. iPhone 8 Plus Top Left Antenna Replacement: stap 13, afbeelding 1 van 1
    • Gently pull up on the suction cup to lift up the bottom edge of the display.
    • Do not raise the display more than 15º or you'll risk straining or tearing the ribbon cables connecting the display.
  14. iPhone 8 Plus Top Left Antenna Replacement: stap 14, afbeelding 1 van 1
    • Pull on the small nub on the suction cup to remove it from the front panel.
  15. iPhone 8 Plus Top Left Antenna Replacement: stap 15, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 15, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 15, afbeelding 3 van 3
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
    Be very careful at this step. The glass at the top will break very easy when the display is lifted too much.
    Gerdschi D - Antwoord
  16. iPhone 8 Plus Top Left Antenna Replacement: stap 16, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 16, afbeelding 2 van 2
    • Slide the display assembly slightly down (away from the top edge of the phone) to disengage the clips holding it to the rear case.
  17. iPhone 8 Plus Top Left Antenna Replacement: stap 17, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 17, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 17, afbeelding 3 van 3
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Lean the display against something to keep it propped up while you're working on the phone.
    Das “links” ist auf dem Foto rechts.
    Matze Diamond - Antwoord
    Das ist falsch. Wenn man auf das iPhone sieht, ist der Home Button unten. Auf dem Photo ist deutlich sichtbar, dass die linke Seite angehoben wird.
    Hans - Antwoord
  18. iPhone 8 Plus Top Left Antenna Replacement, Battery Disconnection: stap 18, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement, Battery Disconnection: stap 18, afbeelding 2 van 2
    Magnetic Project Mat
    $19.95
    Koop
    • Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
    • Two 1.3 mm screws
    • One 1.4 mm screw
    • One 2.7 mm screw
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
    The Phillips screwdriver bit is the PH000. The measurement refers to the screw length.
    Jack Harry - Antwoord
  19. iPhone 8 Plus Top Left Antenna Replacement: stap 19, afbeelding 1 van 1
    • Remove the lower display cable bracket.
  20. iPhone 8 Plus Top Left Antenna Replacement: stap 20, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 20, afbeelding 2 van 2
    • Use the point of a spudger to pry the battery connector up from its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from accidentally making contact with the socket and providing power to the phone during your repair.
    When I reassembled the iPhone 8 Plus, I had to plug it into a Lightning cable to wake it up (just pushing power button wasn’t sufficient).
    browniestarmite - Antwoord
  21. iPhone 8 Plus Top Left Antenna Replacement, Display Assembly: stap 21, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement, Display Assembly: stap 21, afbeelding 2 van 2
    • Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
    • To re-attach press connectors like this one, press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    I got hold of a iPhone 8 Plus with cracked screen that I am planning to fix.
    Here is my problem:
    When I tried to take out the screen from my phone, (step 15-18) I was curious about the new screen, so I tried to connect it. It was completely dead! Then I tried the old cracked one, and suddenly that was dead to! This is a phone that some fool has been inside earlier and changed battery, but I suspect he has done some more really stupid things. The Taptic Engine is living its own life and vibrating every time I slightly touch the home button. (I have a new Taptic Engine) The phone is also full of dust and small particles that does not belong there. One tri-point Y000 screw (step 18) is even missing! Now the biggest problem is that both screens are black! I know the phone is on, because I hear voice command speak when I turn on the power. The screen worked before I tried to change it? And one last thing: My new LCD screen came with new flex cables. Is it possible to switch over, so I can use the old ones?
    smikalsen - Antwoord
    Hi,
    Is your problem solved?
    Daniel Leprince -
    Be careful of damaging MOSFETs by the LH side of the large lower display cable. After replacing the battery and turning the device on, the phone showed low charge and didn't have a charging symbol even after plugging into multiple cables and chargers. Turns out I had damaged the logic board attempting to disconnect the connector.
    Chris Cerrudo - Antwoord
  22. iPhone 8 Plus Top Left Antenna Replacement: stap 22, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 22, afbeelding 2 van 2
    • Disconnect the second lower display cable connector, directly behind the one you disconnected in the previous step.
    I used the other end of the spudger on this connector and it seemed to work a little better for me. I came in from underneath the top-right edge instead of the bottom right.
  23. iPhone 8 Plus Top Left Antenna Replacement: stap 23, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 23, afbeelding 2 van 2
    • Remove the two tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.0 mm screw
    • One 1.2 mm screw
    una vite da 1mm e due viti da 1.2 mm???
    Matteo Carachino - Antwoord
    Ciao Matteo! Grazie per l’osservazione. Ho appena modificato il testo :) La traduzione è aperta a tutti. Hai quindi la possibilità di fare le tue suggestione direttamente nel testo e sei il benvenuto se vuoi usare di questa possibilità nel futuro. Grazie ancora per la vigilanza! Saluti, Claire
    Claire Miesch -
    The tool kit does include a 1.0 or1.2mm screwdriver! How am I supposed to remove those screws?
    peter frommer - Antwoord
    Bought the screwdriver that supposedly fits these screws and it still doesn’t work.
    hypercarduser - Antwoord
    My bracket looks different. Can’t get these screws out.
    Ray Rushing - Antwoord
    kit came with wrong bit. i received 2x P02 (penta tips) and no tri point y000.
    Christopher Shane Gripp - Antwoord
    There is no such thing as a trigger point y000 screwdriver. Why couldn't they use Philips like the rest of the screws.Nobody knows what these trips point y000 even look like. this is a scam to force you to buy a new phone.
    Al tb - Antwoord
    y000 tri-point screw driver comes with the iFixit repair kit at minimal cost
    godo - Antwoord
  24. iPhone 8 Plus Top Left Antenna Replacement: stap 24, afbeelding 1 van 1
    • Remove the bracket covering the front panel sensor assembly connector.
  25. iPhone 8 Plus Top Left Antenna Replacement: stap 25, afbeelding 1 van 2 iPhone 8 Plus Top Left Antenna Replacement: stap 25, afbeelding 2 van 2
    • Use the tip of a spudger or a fingernail to disconnect the front panel sensor assembly connector from its socket.
    What happens is this strip is torn and how does one fix it
    Mijinyawa Dauda - Antwoord
  26. iPhone 8 Plus Top Left Antenna Replacement: stap 26, afbeelding 1 van 1
    Should there be a step somewhere in here to point out when to remove the blue plastic from the new iFixit screen?
    Paul Santora - Antwoord
  27. iPhone 8 Plus Top Left Antenna Replacement, Top Left Antenna: stap 27, afbeelding 1 van 1
    • Remove three Phillips screws securing the upper left antenna component:
    • Two 1.3 mm screws
    • One 3.1 mm screw
  28. iPhone 8 Plus Top Left Antenna Replacement: stap 28, afbeelding 1 van 1
    • Remove the 1.3 mm Phillips screw securing the antenna component to the top edge of the rear case.
    This screw is stuck and will not come out. I'm using the same head I used for the previous one which is the same size. I've even tried them all. I can get any other screw fine but this one will not come out. Just wasted my time undoing everything up to then and this stupid screw is stopping me from finishing.
    Jalen Pace - Antwoord
  29. iPhone 8 Plus Top Left Antenna Replacement: stap 29, afbeelding 1 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 29, afbeelding 2 van 3 iPhone 8 Plus Top Left Antenna Replacement: stap 29, afbeelding 3 van 3
    • The screw boss at the top of the antenna component is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna component up towards the top of the phone.
    • Slide the screw boss down and out of its recess.
    I accidently ripped the screw boss of the antenna component. Is that very bad? Do I need to replace the antenna component, or could I try to solder it back on, or does it even matter? Thanks in advance.
    Johannes Jüptner - Antwoord
  30. iPhone 8 Plus Top Left Antenna Replacement: stap 30, afbeelding 1 van 1
    • Remove the top left antenna component.
Conclusie
14 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
427.796 Reputatie
259 handleidingen geschreven
iFixit Lid van iFixit
Staff
135 Leden
16.718 handleidingen geschreven
7 opmerkingen
Hey guys
Whats the difference between the antennas in an iphone and which is to be replaced incase of wifi problems ?
Hamza Abdikadir - Antwoord
Pun intended? XD
Ben Capehart -
but why you have to replace this antenna ? what is does ?
no information
Ben Ben - Antwoord
as per every other comment: WHAT DOES IT DO?
bearzac - Antwoord
That's the telephone service connector
Raphael Guppy -
Lol I didn’t learn anything
vif_00 - Antwoord
Die WLAN Antenne befindet sich links neben der Kamera und nicht in der linken Ecke des Telefons.
Außerdem: was nützt es, wenn lediglich die Abdeckkappe getauscht wird?
Wilfried Sommer - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 18
Afgelopen 7 dagen: 89
Afgelopen 30 dagen: 465
Altijd: 42,585
