Inleiding
Learn how to replace your iPhone 8 Plus screen. This part comes with the front facing camera, earpiece speaker, and EMI shield already installed, making for an easier repair. If your screen did not come with those things pre-installed, follow this guide instead.
All you need to do is remove the old screen and transfer the home button to the new screen, in order for Touch ID to function.
Note: If your iPhone’s auto brightness feature does not work properly after your screen repair, make sure your iPhone is updated to iOS 12. True Tone functionality is disabled after a screen replacement, even when using an original Apple screen.
Gereedschap
Video overzicht
Power off your iPhone before beginning disassembly.
Remove the two 3.5 mm pentalobe screws from the bottom edge of the iPhone.
If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about 90 seconds in order to soften up the adhesive underneath.
Remove four Phillips (JIS) screws securing the lower display cable bracket to the logic board, of the following lengths:
Two 1.3 mm screws
One 1.4 mm screw
One 2.7 mm screw
Use the tip of a spudger or a fingernail to disconnect the large lower display connector by prying it straight up from its socket.
Remove the four Y000 screws securing the bracket over the home/Touch ID sensor:
One 1.2 mm screw
Three 1.3 mm screws
Flip the display assembly over. Use a hairdryer or prepare an iOpener and apply it to the lower edge of the display for about 90 seconds in order to soften up the adhesive underneath.
272 andere personen hebben deze handleiding voltooid.
34 Opmerkingen
Very useful information…
Has anyone found out any info about replacing the Apple iPhone 8 Front glass. Last I checked Apple had made it that if you install a non OEM screen and updates their phone, it will brick there phone. I have not been fixing any iPhone 8’s or iPhone x’s due to this. I So if someone knows if this has been resolved or if this still holds true can you please let me know. Also, Fixing back glass. From what I have seen they use some crazy glue. Does anyone have any methods on a easy way to replace back glass on the iPhone 8’s ? do you still basically have to gut the phone ? what kind of glue is used to glue it back on? Any help with these issues would greatly be appreciated I have been repairing phones for over 8 years + and turning away customers because apple is so dumb with these things upsets me greatly. I loved repairing iPhone up until this point. Help please.
Replacing the screen will not Brick the iPhone, although the 8/8Plus & iPhone X all have an issue with the Ambient Sensor when a new screen is fitted. Although a way around this is to use a EEPROM device to copy the firmware from the original screen. It is also rumored that Apple are fixing the Ambient Sensor issue in iOS 12.
Donald -
Anyone know if the ambient sensor is fixed?
Hi. My iphone 8 plus screen is broken. I purchased it from USA, I’m in Turkey, Istanbul right know. When I took it to the apple store over there, they told me I need a code to replace the screen, and every country has different code. In order for me to replace the screen, I need that code.
Would some one please tell me what to do. I really appreciate it.
Thanks.
