Inleiding
This is a prerequisite only guide. It disconnects most of the connectors and removes most of the screws to take the motherboard out. The shots are taken such that you can’t see whether the Taptic Engine is out or not.
Note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
Opening the iPhone 8 will damage the waterproof seals on the display. If you do not replace the adhesive seals, your phone will function normally, but will no longer be water-resistant.
Wat je nodig hebt
Use the flat end of a spudger to disconnect the camera cable connector by prying it straight up from its socket.
Remove the three Phillips 1.3 mm screws securing the top left antenna component.
Remove the two Phillips screws securing the grounding clip at the top left edge of the logic board:
One 1.5 mm Phillips screw
One 2.6 mm Phillips screw
Remove the three screws securing the motherboard:
One 1.8 mm Phillips screw
One 2.5 mm standoff screw
One 2.2 mm standoff screw
