Ga door naar hoofdinhoud
iPhone 8 Back Glass Replacement
Video overzicht
  1. iPhone 8 Back Glass Replacement, iPhone 8 Back Glass Replacement: stap 1, afbeelding 1 van 1
    • Wire up the Back Glass Separator. Connect the Back Glass Separator with Air Compressor via an air pipe. Switch on the Air Compressor. Open the air compressor valve.
    • Switch on the Back Glass Separator. Rotate the pressure regulating valve and set the value as 0.4Mpa.
  2. iPhone 8 Back Glass Replacement: stap 2, afbeelding 1 van 2 iPhone 8 Back Glass Replacement: stap 2, afbeelding 2 van 2
    • Place iPhone 8 back glass assembly into the corresponding mold. Press ‘Up’. With the temperature rising to 240℃, press ‘Start’. The back glass assembly is clamped tightly by the mold.
    • After 200 seconds of heating, mandril of the machine starts to work.
  3. iPhone 8 Back Glass Replacement: stap 3, afbeelding 1 van 1
    • Remove the back glass after 18 seconds. Remove glue residue on the back glass thoroughly.
    • iPhone 8 back glass separating has been completed successfully.
    • Attach a new back glass to the midframe in the end.
Eindstreep
15 andere personen hebben deze handleiding voltooid.
Phryne
21.468 Reputatie
18 handleidingen geschreven
1Gids Commentaar
Where does it show the replacement I only see the removal?
ManDeen - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 308
Altijd: 58,839
