Inleiding
Follow the steps in this guide to replace the loudspeaker in an iPhone 7. This guide includes instructions for removing the speaker assembly, and peeling off the Wi-Fi diversity antenna which needs to be transferred to your new loudspeaker.
Video overzicht
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Remove four tri-point Y000 screws securing the lower connector bracket, of the following lengths:
Three 1.2 mm screws
One 2.4 mm screw
Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the two 1.9 mm Phillips screws securing the barometric vent to the rear case.
Use the flat end of a spudger to disconnect the Taptic Engine connector from its socket on the logic board.
Remove the Phillips screw securing the Wi-Fi diversity antenna to the rear case:
One 3.2 mm screw
54 andere personen hebben deze handleiding voltooid.
8 Opmerkingen
My right speaker is currently not working, and I think I will probably be doing his soon on my device. Thank you.
Hi there
My iPhone 7 has static when calling and the person im calling cannot hear me. Can someone help me or tell me what is the problem? Is it the earpiece speaker or the speaker at the bottom of the iPhone? Please somebody. Thanks.
Hi. I’ve the same problem. Have you fix with changing?
