Ga door naar hoofdinhoud
Inleiding
Use this guide to remove or replace a faulty logic board in your iPhone 7 Plus.
It's important to note that each iPhone's logic board and Touch ID fingerprint sensor are paired at the factory, so replacing the logic board will disable Touch ID unless you also install a replacement home button that has been properly paired to your new logic board.
  1. Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
    The recommendation of discharging the battery is completely unnecessary. Even a 25% charged battery can explode. Completely ridiculous suggestion.
    pargoff - Antwoord
    The risk of thermal runaway on these batteries decreases with the battery's SOC (state of charge). Below 50% charge the risk is fairly low, and at 25% charge the risk of a thermal event is near zero. If I recall correctly, the same suggestion appears in Apple's official (non-public) service manuals for the iPhone.
    Jeff Suovanen -
    @jeffsu Yes, that is correct. Apple does require all certified staff to discharge the battery below 25%. This is an industry standard for all LiION batteries. If you don’t want to do this, just make sure to not puncture the battery and disconnect it first thing.
    Ben Meinhart - Antwoord
    Hang on a second here, doesn’t the Ifixit part I ordered come with the seals? The display assembly? It doesn’t. Now I have to wait another week?!
    Vanessa Pinter - Antwoord
    How do you turn off if the screen isn’t responding to touch?
    adam - Antwoord
    The replacement battery came with the seal—but how do you put it on???
    lkollar - Antwoord
  2. Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
    How long should I use a hairdryer for?
    Warren Binder - Antwoord
    I used it until it was hot to the touch but not too hot where you burn yourself.
    gczarny -
    Hey, I just took apart my first iPhone 7 plus today, and it was easier for me to use guitar picks and a magic glass tool. I did tear the home flex on the screen—now I know to be more careful of that on disassembly—-~Katrina of iPad Rehab Microsoldering
    jessabethany - Antwoord
    First I tried to remove the screen with the hot iOpener, but it doesn’t worked, the day after I putted the Iphone in the sun for a while and then used the hot iOpener, then the screen was easy to remove :-)
    Marc Boon - Antwoord
    Get a T-shirt add heat to a lil corner of it, with either a hair straighter or an Iron , touch the T-shirt if it’s seems hot but doesn’t burn u hold that lil hot piece of T-shirt against the edge ur trying to pry open , if it’s still not opening add a I’ll more heat,
    www.tertlegerl - Antwoord
  3. Apply a suction cup to the lower half  of the front panel, just above the home button. Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • Apply a suction cup to the lower half of the front panel, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
  4. Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Insert the flat end of a spudger into the gap. The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong; creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
    • While pulling up on the suction cup, twist the spudger to widen the opening between the screen and rear case.
  5. Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone. Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place. Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    • Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
    • Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
    • Do not try to pry the top edge of the display away from the rear case, as it is held in place by plastic clips that may break.
    looking for an iphone 7 plus logic board
    Point Xero Zambia - Antwoord
  6. Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner. Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
    • Remove the spudger from the left side of the phone and insert the flat end into the bottom right corner.
    • Slide the spudger up the right edge of the phone to the top corner, breaking up the adhesive holding the display in place.
  7. Pull up on the suction cup to lift up the display and open the iPhone. Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10º as there are delicate ribbon cables along the right edge of the device connecting the display to the logic board.
  8. Pull up on the small nub on the suction cup to remove it from the front panel. Pull up on the small nub on the suction cup to remove it from the front panel.
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  9. Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive. Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
    • Slide an opening pick underneath the display along the top edge of the phone to loosen the last of the adhesive.
  10. Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case. Open the iPhone by swinging the display up from the left side, like the back cover of a book. Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  11. Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
    • Three 1.2 mm screws
    • One 2.6 mm screw
    Is it really safe to lay the device fully open like a book? The cable leading to the LCD gets stretched across the sharp edge of the aluminum edge of the back cover.
    u204863 - Antwoord
    Generally I'd say no, it's not safe. In reality I've seen a bit of variance in the cable length, and sometimes it'll be fine—but mostly I'd be prepared to prop the display up or hold it in place at a slight angle so it doesn't put too much stress on the cables. On prior iPhones it was easy to rubberband the display to a box or a can of soda, and something like that would probably work well here too. Use your own judgment.
    Jeff Suovanen -
    The tri wing screws are so hard to remove. What's the trick?
    shannon caldwell - Antwoord
    At first I think I was being too careful and was getting no where. I got better results by pressing down on the screwdriver with more pressure while turning and those little screws came right out.
    LadyTech - Antwoord
    I cannot remove one of the corner screws in this step and i have used the tweezers and the y000 tri tip and i am afraid that it is stripping it. is there a work around for this step?
    Katherine Monday - Antwoord
    @katmonday1 No workaround unfortunately. Make sure the driver tip is in good condition and fits the screw correctly. Seat it in the screw, hold the driver perfectly vertical, press down hard (and maintain it), and turn. It’ll come out. If it’s really stripped you’ll have to get more aggressive—try one or more of the techniques in this guide or get some help. Good luck!
    Jeff Suovanen -
  12. Remove the lower display cable bracket. Remove the lower display cable bracket.
    • Remove the lower display cable bracket.
    I am confused, please help. LOL the bracket, the very first one being removed. I see it has three screws the same size and one a different size? I've been trying to fix my daughter's phone and ordered a 0.6 mm Tri Wing screwdriver for iPhone 7 plus /Apple watch. It seems to fit the screws and it seems to be turning them although I can't see that well but they're not coming out. However when I used it on a smaller bracket with two screws they came right out so I'm thinking I don't have the right screwdriver I am at my Wit's End!! I have been working on this phone or attempting to for a while now. I cannot find a list anywhere of the exact size screwdrivers needed to Take apart an iPhone 7 plus. Any help would be greatly appreciated.
    chris west - Antwoord
    If your tri-wing screwdriver worked for other tri-point screws in the phone, then it should work for the screws you are struggling with! If it feels like the screws are spinning but not coming out, try to use tweezers to pull them out. I often struggle with tri-point screws, and need to apply some downward pressure to remove them. This can be risky though, as you do not want to strip the screw or damage components underneath the bracket. If you continue to struggle, you can give this driver and this bit a try.
    Scott Havard - Antwoord
    Also be aware that the battery connector might stick to the bottom of the steel bracket. This part had me a bit puzzled at first. lol
    Just gently pry the connector off the steel bracket to release it and be sure the connector isn’t allowed to accidentally reconnect to the board.
    jeffrey griffith - Antwoord
    I had to use a fingernail to dislodge the bracket. As Jeffrey said, it was apparently stuck to the connector.
    lkollar - Antwoord
  13. Use the point of a spudger to lift the battery connector out of its socket on the logic board. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone. Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to  the phone.
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  14. Make sure the battery is disconnected before you disconnect or reconnect the cables in this step. Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board. To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To re-attach press connectors, press down on one end until it clicks into place, then repeat on the other end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
    The note about the danger of pressing on the connector incorrectly is very legitimate. Though I find it more practical to use a wide (1.5 cm) case opener tool to press it down all at once. Minimizes risk of bending the connector.
    Talon - Antwoord
    What can happen if the battery is not disconnected before the two lower display connectors?
    Alextay - Antwoord
    Hello, by my expierence and what i have learned iphone repair videos you can ‘blow up’ capacitors which one in logic board, screen is sensetive with voltages and etc….
    Darius Varanavičius -
    what are my options if the display connector broke? can it be replaced or do I need to get a whole new screen?
    matomach - Antwoord
  15. Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector: One 1.3 mm screw Two 1.0 mm screws
    • Remove the three tri-point Y000 screws securing the bracket over the front panel sensor assembly connector:
    • One 1.3 mm screw
    • Two 1.0 mm screws
    • Remove the bracket.
    Posted a comment above on the first step. The screwdriver that I ordered Works taking out these two screens shown in the picture. However it does not work on the first bracket that needs to be removed. It seems that all screw sizes are somewhat different but I'm not finding a list showing different screwdriver sizes needed. Does this make sense? Could anybody please give me some advice on this thank you much.
    I know your comment was posted a long time ago but just in case someone else has the same problem, the only difference in the screws are the lengths. The ends are the same.
    mcr4u2 - Antwoord
    What happens if you break “tear in half” the black tape stuff?
    assweeetasyou - Antwoord
    Unfortunately if you tear the black cable you will need to replace it !!!
    Wayne Lyell -
    Chris West the screwdriver that probably came with the kit was pentalobe to get the first two screws out to open the case. you need a .6mm Y tip driver for internal. its deceptively Phillips looking but is not it only has three blades in a Y, not 4 in a +
    Jeremiah Kjensmo - Antwoord
    Hello is it if I put wrong screw can damage the board?
    alicenine84 - Antwoord
  16. Disconnect the front panel sensor assembly connector from its socket on the logic board. This press connector should also be reconnected one end at a time to minimize the risk of bending.
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
    Make sure that the orientation of the cable when you attach is correct! See the picture for the correct orientation. If it gets installed 180 degrees out(i.e., the ribbon goes up instead of down, then the earphone, front camera, and Home button will be inoperative. Ask me how I know!?! Worked great when installed correctly!
    Kevin Reilly - Antwoord
  17. Remove the display assembly.
  18. Remove three Phillips screws securing the antenna component:
    • Remove three Phillips screws securing the antenna component:
    • Two 1.3 mm screws
    • One 1.2 mm screw
    It is not necessary to remove the logic board. remove the three standoff screws and the simcard holder and push back the sim ejector pin and you can lift the logic board up about 7mm. with isopropyl to loosen the adhesive, slide a spudger under the old charge port cable you can easily slide it out. Makes the job a lot easier and quicker.
    Jack - Antwoord
  19. Remove the 1.3 mm Phillips screw securing the antenna component to the top edge of the rear case.
    • Remove the 1.3 mm Phillips screw securing the antenna component to the top edge of the rear case.
  20. The screw boss at the top of the antenna component is tucked into a small recess in the top edge of the iPhone. Tilt the antenna component up towards the top of the phone. Slide the screw boss down and out of its recess.
    • The screw boss at the top of the antenna component is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna component up towards the top of the phone.
    • Slide the screw boss down and out of its recess.
  21. Remove the top left antenna component.
    • Remove the top left antenna component.
  22. Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray. Press firmly to eject the tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press firmly to eject the tray.
  23. Remove the SIM card tray from the iPhone. The SIM card will fall out of the tray easily. When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • Remove the SIM card tray from the iPhone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
    • A thin rubber gasket around the SIM tray provides water and dust protection. If this gasket is damaged or missing, replace the gasket to protect your iPhone's internal components.
  24. Use an iFixit opening tool or a fingernail to disconnect the dual camera cable connectors by prying them straight up from their sockets. Use an iFixit opening tool or a fingernail to disconnect the dual camera cable connectors by prying them straight up from their sockets. Use an iFixit opening tool or a fingernail to disconnect the dual camera cable connectors by prying them straight up from their sockets.
    • Use an iFixit opening tool or a fingernail to disconnect the dual camera cable connectors by prying them straight up from their sockets.
  25. Remove the two screws securing the rear-facing camera bracket:
    • Remove the two screws securing the rear-facing camera bracket:
    • One 1.6 mm Phillips screw
    • One 2.2 mm standoff screw
    • Standoff screws are best removed using an iPhone Standoff Screwdriver Bit and driver handle.
    • In a pinch, a small flathead screwdriver will do the job—but use extra caution to ensure it doesn't slip and damage surrounding components.
    Why is there a standoff screw here? No other screw goes into it so why not have a Phillips?
    Trevor Smith - Antwoord
    More to the point, why doesn’t the Ifixit tool kit for this job come with the bit required?
    John Tinsley - Antwoord
    Second that, sitting here trying to figure out how to get it out.
    Jeffrey Wilhelm -
    iFixit kits do come with all the required bits, but sometimes specialty bits like this one are packed into a different part of the box. Unpack the entire kit and you should find it. In the unlikely event that it really is missing due to a packing error, contact customer support and they’ll send you the missing bit ASAP.
    Jeff Suovanen -
    I strongly urge Ifixit to change this comment “In a pinch, a flathead screwdriver will do the job” - maybe ok for REMOVAL ONLY, but for REASSEMBLY - it is very dangerous - i used a flathead while fixing my daughters phone and they kept going crooked - easily causing me 1-2 hours of frustration and STRIPPING THE THREADS IN THE ALUMINUM BACK FRAME BODY !!!!
    I had to hot glue a couple spots and skip several screws on reassembly to do the jankiest, most embarrasing repair job - BUY THE RIGHT SPECIAL TOOL FOR THE STANDOFF SCREWS OR YOU’LL REGRET IT!!!
    treadmillfix - Antwoord
  26. Remove the bracket covering the rear-facing camera.
    • Remove the bracket covering the rear-facing camera.
  27. Remove the two 1.3 mm Phillips screws securing the upper cable bracket.
    • Remove the two 1.3 mm Phillips screws securing the upper cable bracket.
  28. Remove the upper cable bracket.
    • Remove the upper cable bracket.
  29. Remove the two 1.3 mm Phillips screws securing the grounding clip at the top left edge of the logic board.
    • Remove the two 1.3 mm Phillips screws securing the grounding clip at the top left edge of the logic board.
  30. Remove the grounding clip.
    • Remove the grounding clip.
  31. Remove the 1.3 mm Phillips screw securing the antenna flex cable to the top edge of the iPhone's rear case.
    • Remove the 1.3 mm Phillips screw securing the antenna flex cable to the top edge of the iPhone's rear case.
  32. Use a fingernail or the sharp end of an iFixit opening tool to pry up and disconnect the antenna flex cable connector from the logic board. Use a fingernail or the sharp end of an iFixit opening tool to pry up and disconnect the antenna flex cable connector from the logic board.
    • Use a fingernail or the sharp end of an iFixit opening tool to pry up and disconnect the antenna flex cable connector from the logic board.
  33. Slide the flat edge of a spudger underneath the antenna flex cable to separate the adhesive holding it in place. Slide the flat edge of a spudger underneath the antenna flex cable to separate the adhesive holding it in place.
    • Slide the flat edge of a spudger underneath the antenna flex cable to separate the adhesive holding it in place.
  34. The screw boss at the top of the antenna flex cable is tucked into a small recess in the top edge of the iPhone. Tilt the antenna flex cable  up toward the top of the iPhone. Slide the screw boss down and out of its recess.
    • The screw boss at the top of the antenna flex cable is tucked into a small recess in the top edge of the iPhone.
    • Tilt the antenna flex cable up toward the top of the iPhone.
    • Remove the antenna flex cable.
  35. Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board. During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place. During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
    • Use a thin pry tool or tweezers to carefully pry up and disconnect the two coaxial cable connectors from the logic board.
    • During reassembly, these can be tricky to reconnect. One at a time, hold each connector in place over its socket and press down with the flat of your spudger. The connector should snap into place.
    What purpose do these coax cables have?
    Eddie Orantes - Antwoord
    Note… the top coax (nearest the battery connector) leads to the WiFi Diversity Antenna on the speaker assembly. The other coax is for the secondary cell antenna, part of the lightning assembly. Be sure to reassemble them to the right sockets!
    Ronald Stamper - Antwoord
    Thanks so much for this helpful comment! I have just spent a few hours trying to find that information and here it is.
    thalley -
    Ronald Stamper, is this the same for the 7?
    Keah Smith - Antwoord
  36. Disconnect the two remaining ribbon cables from the logic board: Disconnect the upper cable connector by prying from the top Disconnect the Lightning port connector by prying along the outer edge
    • Disconnect the two remaining ribbon cables from the logic board:
    • Disconnect the upper cable connector by prying from the top
    • Disconnect the Lightning port connector by prying along the outer edge
  37. Remove the seven screws securing the logic board:
    • Remove the seven screws securing the logic board:
    • One 1.3 mm Phillips screw
    • Two 2.1 mm standoff screws
    • Two 2.0 mm standoff screws
    • Two 2.2 mm standoff screws
  38. Use the point of a spudger to push the SIM card eject plunger out of the logic board's way. Use the point of a spudger to push the SIM card eject plunger out of the logic board's way.
    • Use the point of a spudger to push the SIM card eject plunger out of the logic board's way.
  39. Use the point of a spudger to carefully de-route the two coaxial cables  from the small metal clip holding them to the logic board.
    • Use the point of a spudger to carefully de-route the two coaxial cables from the small metal clip holding them to the logic board.
  40. Lift the logic board from the bottom edges and slide it toward the bottom of the iPhone to remove it. Be careful not to snag the logic board on any cables. During reassembly, note the position of the black grounding clip at the top right edge of the logic board, near the rear cameras. The logic board should slide underneath the clip.
    • Lift the logic board from the bottom edges and slide it toward the bottom of the iPhone to remove it.
    • Be careful not to snag the logic board on any cables.
    • During reassembly, note the position of the black grounding clip at the top right edge of the logic board, near the rear cameras. The logic board should slide underneath the clip.
Conclusie
55 andere personen hebben deze handleiding voltooid.
Jeff Suovanen
256.229 Reputatie
216 handleidingen geschreven
iFixit Lid van iFixit
Community
107 Leden
9.549 handleidingen geschreven
Helo! Where can I buy motherboard for iPhone 7+ that can be activated? Price?
Dario - Antwoord
Can we use iphone 7+ 32gb board to a iphone 7+ 128 GB
Ali Mirsa -
It's really tough to install Board component but this guideline really helpful..
Flica Hussey - Antwoord
how can you determine the different stand of screws
joe kelly - Antwoord
Is there a reason why I swapped the motherboard of a Verizon iPhone 7 plus onto a Sprint iPhone 7 plus but now boot ups take 5+ minutes and the phone displays “accessory may not be supported” when connected to a charger?
Pablo villacis - Antwoord
The reason might be because you haven’t connect finger print (home button) into the motherboard.
kabore -
I am trying to find the correct motherboard for my iPhone 7 Plus (256GB) with finger print ID.  Does anyone know where to find the proper/correct motherboard?  Thank you!
Antoine - Antwoord
I am trying to find the correct motherboard to purchase for my 256GB iPhone 7 Plus  (with finger print ID).  does anyone know where to get the correct one?  Thanks!
Antoine - Antwoord
Hi, I need the board for the iPhone 7+ 256GB with the fingertouch (which are paired).
Where did you get yours? can you help me? Did you buy yours?
Can you write directly to raul@miodo.com.ar
Thanks,
R
Raul Miodownik -
and the touch id its work or not ?
D E V - Antwoord
If the flash is not working on the iPhone 7 plus, from which I want to get the logic board out, will it work on the “new” iPhone where I want to put it in, or are these errors connected to the motherboard?
christophw88 - Antwoord
I have the board, showing red (water damage); however, the battery warms up. If charge, noting else. If need to replace the motherboard, will i lose all the data inside? I’ve also order battery and digitizer, hoping that will do. The top part just above the white dot which turns red (motherboard) near antenna, looks burnt. Help
Levianathis - Antwoord
Thanks,
R
Raul Miodownik -
peut on mettre la carte mère d’un iphone 7 sur un 7 plus?
Fanny Caillaud - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 77
Afgelopen 7 dagen: 535
Afgelopen 30 dagen: 2,513
Altijd: 79,517
