Inleiding
The iPhone 7 Plus earpiece speaker also performs double duty as a loudspeaker, providing stereo sound. If your earpiece speaker is acting up, follow this guide to remove and replace it.
Gereedschap
Power off your iPhone before beginning disassembly.
Remove the two 3.4 mm pentalobe screws at the bottom edge of the iPhone.
Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
Insert the flat end of the spudger between the front panel and the rear case at the lower left edge of the iPhone.
Slide the spudger up the left edge of the phone starting at the lower edge and moving towards the volume control buttons and silent switch, breaking up the adhesive holding the display in place.
Remove the following four tri-point Y000 screws securing the lower display cable bracket to the logic board:
Three 1.2 mm screws
One 2.6 mm screw
Use the flat end of a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
Remove the five Phillips screws securing the earpiece speaker bracket:
Two 1.8 mm screws
One 2.3 mm screw
One 2.4 mm screw
One 2.8 mm screw
Repair didn’t go as planned? Try some basic troubleshooting, or search our Answers forum for help.
59 andere personen hebben deze handleiding voltooid.
