Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
iPhone 7 Earpiece Speaker Replacement
Wat je nodig hebt
Video overzicht
  1. iPhone 7 Earpiece Speaker Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before you begin, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm pentalobe screws on the bottom edge of the iPhone.
    • Opening the iPhone's display will compromise its waterproof seals. Have replacement seals ready before you proceed past this step, or take care to avoid liquid exposure if you reassemble your iPhone without replacing the seals.
  2. iPhone 7 Earpiece Speaker Replacement, iPhone 7 Opening Procedure: stap 2, afbeelding 1 van 1
    • Heating the lower edge of the iPhone will help soften the adhesive securing the display, making it easier to open.
    • Use a hairdryer or prepare an iOpener and apply it to the lower edge of the iPhone for about a minute in order to soften up the adhesive underneath.
  3. iPhone 7 Earpiece Speaker Replacement: stap 3, afbeelding 1 van 2 iPhone 7 Earpiece Speaker Replacement: stap 3, afbeelding 2 van 2
    • Attach a suction cup to the lower half of the display assembly, just above the home button.
    • Be sure the suction cup does not overlap with the home button, as this will prevent a seal from forming between the suction cup and front glass.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. iPhone 7 Earpiece Speaker Replacement: stap 4, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 4, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 4, afbeelding 3 van 3
    • Pull up on the suction cup to create a small gap between the display assembly and the rear case.
    • Insert the flat end of a spudger into the gap.
    • The watertight adhesive holding the display in place is very strong, and creating this initial gap takes a significant amount of force. If you're having a hard time opening a gap, rock the screen up and down to weaken the adhesive until you can fit a spudger inside.
  5. iPhone 7 Earpiece Speaker Replacement: stap 5, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 5, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 5, afbeelding 3 van 3
    • Slide the spudger to the left along the lower edge of the iPhone.
    • Twist the spudger to widen the gap between the display and rear case.
  6. iPhone 7 Earpiece Speaker Replacement: stap 6, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 6, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 6, afbeelding 3 van 3
    • Slide the spudger up the left side of the iPhone, starting at the lower edge and moving towards the volume control buttons and silent switch.
    • Do not pry along the top edge of the phone, you risk damaging the plastic clips securing the display.
  7. iPhone 7 Earpiece Speaker Replacement: stap 7, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 7, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 7, afbeelding 3 van 3
    • Insert the flat edge of a spudger into the bottom right corner of the device.
    • Twist the spudger to widen the gap between the display assembly and the rear case.
    • Slide the flat end of the spudger up the right side of the phone to break up the adhesive holding the display in place.
    • Do not insert the spudger further than the adhesive to avoid damaging delicate ribbon cables along the right edge.
  8. iPhone 7 Earpiece Speaker Replacement: stap 8, afbeelding 1 van 2 iPhone 7 Earpiece Speaker Replacement: stap 8, afbeelding 2 van 2
    • Pull up on the suction cup to lift up the display and open the iPhone.
    • Do not raise the display more than 10Âş as there are ribbon cables along the right edge of the device connecting the display to the logic board.
  9. iPhone 7 Earpiece Speaker Replacement: stap 9, afbeelding 1 van 1
    • Pull up on the small nub on the suction cup to remove it from the front panel.
  10. iPhone 7 Earpiece Speaker Replacement: stap 10, afbeelding 1 van 2 iPhone 7 Earpiece Speaker Replacement: stap 10, afbeelding 2 van 2
    • Slide an opening pick along the top edge of the iPhone, between the rear case and front panel, to break up the remaining adhesive holding the screen in place.
    • Be careful not to damage the plastic clips on the top edge of the phone.
  11. iPhone 7 Earpiece Speaker Replacement: stap 11, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 11, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 11, afbeelding 3 van 3
    • Pull the display assembly slightly away from the top edge of the phone to disengage the clips holding it to the rear case.
    • Open the iPhone by swinging the display up from the left side, like the back cover of a book.
    • Don't try to fully separate the display yet, as several fragile ribbon cables still connect it to the iPhone's logic board.
  12. iPhone 7 Earpiece Speaker Replacement, Battery Disconnection: stap 12, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    Tri-point Y000 Screwdriver
    $5.99
    Koop
  13. iPhone 7 Earpiece Speaker Replacement: stap 13, afbeelding 1 van 1
    • Remove the lower connector bracket.
  14. iPhone 7 Earpiece Speaker Replacement: stap 14, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 14, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 14, afbeelding 3 van 3
    • Use the point of a spudger to lift the battery connector out of its socket on the logic board.
    • Bend the connector cable up slightly to prevent it from making contact with the socket and providing power to the phone.
  15. iPhone 7 Earpiece Speaker Replacement, Display Assembly: stap 15, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement, Display Assembly: stap 15, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement, Display Assembly: stap 15, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  16. iPhone 7 Earpiece Speaker Replacement: stap 16, afbeelding 1 van 3 iPhone 7 Earpiece Speaker Replacement: stap 16, afbeelding 2 van 3 iPhone 7 Earpiece Speaker Replacement: stap 16, afbeelding 3 van 3
    • Remove the two 1.3 mm Phillips #000 screws securing the bracket over the front panel sensor assembly connector.
    • Some phones could be Y000. Apple started using Y000 for these at some point in the middle of the product's lifecycle.
  17. iPhone 7 Earpiece Speaker Replacement: stap 17, afbeelding 1 van 2 iPhone 7 Earpiece Speaker Replacement: stap 17, afbeelding 2 van 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  18. iPhone 7 Earpiece Speaker Replacement: stap 18, afbeelding 1 van 1
  19. iPhone 7 Earpiece Speaker Replacement, Earpiece Speaker: stap 19, afbeelding 1 van 1
    • Remove the three Phillips screws securing the earpiece bracket to the front panel:
    • Two 2.6 mm screws
    • One 1.7 mm screw
  20. iPhone 7 Earpiece Speaker Replacement: stap 20, afbeelding 1 van 1
    • Remove the earpiece speaker bracket.
  21. iPhone 7 Earpiece Speaker Replacement: stap 21, afbeelding 1 van 2 iPhone 7 Earpiece Speaker Replacement: stap 21, afbeelding 2 van 2
    • Lift the front facing camera out of the way to access the earpiece speaker.
  22. iPhone 7 Earpiece Speaker Replacement: stap 22, afbeelding 1 van 1
    • Remove the following three Phillips screws securing the earpiece speaker to the front panel:
    • One 1.9 mm screw
    • One 2.5 mm screw
    • One 1.2 mm screw
  23. iPhone 7 Earpiece Speaker Replacement: stap 23, afbeelding 1 van 1
    • Remove the earpiece speaker.
Conclusie
148 andere personen hebben deze handleiding voltooid.
Evan Noronha
223.466 Reputatie
168 handleidingen geschreven
11 opmerkingen
how to remove sensor
Sharath kumar - Antwoord
I successfully replaced the earpiece but after completing everything the iphone stopped charging ,what could be the reason?
please help.
Thanks in advance:)
Rishabh Madaan - Antwoord
Check your battery cable. Make sure it is seated properly to the motherboard.
jiggy0215 -
Hello,
instructions were great and easy to follow. I have managed to replace my ear speaker which i bought from your store, but the problem with distorted sound still exists.
Is there maybe some kind of failure on my motherboard on device or something else?
Luka Liker - Antwoord
Hi I have a question- what is the speaker attached to that is making it work? From the video it looks like it isn’t attached to any wires that connect to the rest of the phone, but maybe I am not looking closely. I am wondering because I broke the front camera ribbon and would like to know if that should affect my speaker?
Thanks
Sam Norton - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 145
Afgelopen 30 dagen: 558
Altijd: 136,543
