Ga door naar hoofdinhoud
iPhone 7 Display Assembly Replacement
Alleen vereisten
Deze handleiding is alleen bedoeld als vereiste voor andere handleidingen. Het staat niet op zichzelf.
Wat je nodig hebt
  1. iPhone 7 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 1 van 3 iPhone 7 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 2 van 3 iPhone 7 Display Assembly Replacement, Display Assembly: stap 1, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a spudger or a fingernail to disconnect the two lower display connectors by prying them straight up from their sockets on the logic board.
    • To reconnect these cables, press down on one end until it clicks into place, then repeat on the opposite end. Do not press down on the middle. If the connector is even slightly misaligned, the connector can bend, causing permanent damage.
    • If you have a blank screen, white lines on the display, or partial or complete lack of touch response after reassembling your phone, try disconnecting and carefully reconnecting both of these cables and make sure they are fully seated.
  2. iPhone 7 Display Assembly Replacement: stap 2, afbeelding 1 van 3 iPhone 7 Display Assembly Replacement: stap 2, afbeelding 2 van 3 iPhone 7 Display Assembly Replacement: stap 2, afbeelding 3 van 3
    • Remove the two 1.3 mm Phillips screws securing the bracket over the front panel sensor assembly connector.
    • Remove the bracket.
  3. iPhone 7 Display Assembly Replacement: stap 3, afbeelding 1 van 2 iPhone 7 Display Assembly Replacement: stap 3, afbeelding 2 van 2
    • Disconnect the front panel sensor assembly connector from its socket on the logic board.
    • This press connector should also be reconnected one end at a time to minimize the risk of bending.
  4. iPhone 7 Display Assembly Replacement: stap 4, afbeelding 1 van 1
Conclusie
4 andere personen hebben deze handleiding voltooid.
Evan Noronha
223.232 Reputatie
168 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,651
