Ga door naar hoofdinhoud
Inleiding
Use this guide to remove, clean, or replace a faulty rear-facing iSight camera in your iPhone 6s.
You can also use this guide to replace the rear camera bracket.
  1. Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, next to the Lightning connector.
  2. Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  4. Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  5. There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open. Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  6. Twist the spudger to widen the gap between the front panel assembly and the rest of the phone. Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  7. Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case. Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  8. Remove the spudger and reinsert it on the bottom edge, where you pried the phone open. Slide the spudger to the right, along the bottom edge of the phone.
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  9. Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone. Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  10. Use the suction cup to open the display, breaking the last of the adhesive. Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  11. Pull up on the nub on the top side of the suction cup to remove it from the front panel. Pull up on the nub on the top side of the suction cup to remove it from the front panel.
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  12. Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  13. Remove the battery connector bracket from the iPhone. Remove the battery connector bracket from the iPhone.
    • Remove the battery connector bracket from the iPhone.
  14. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  15. Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work. Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  16. Remove the following four Phillips screws securing the display cable bracket:
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  17. Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  18. Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board. Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  19. Disconnect the digitizer cable by prying it straight up from its socket on the logic board. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  20. Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Disconnect the display cable by prying it straight up from its socket on the logic board.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  21. Remove the display assembly.
  22. Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board. Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
    • Use the flat end of a spudger to disconnect the rear camera from its socket on the logic board.
  23. Remove the following two Phillips screws over the rear camera bracket:
    • Remove the following two Phillips screws over the rear camera bracket:
    • One 1.6 mm screw
    • One 2.0 mm screw
  24. Remove the camera bracket. Remove the camera bracket.
    • Remove the camera bracket.
  25. Insert a spudger to the side of the camera, between the rear case and the camera module. Gently pry up on the camera to nudge it out from its housing.
    • Insert a spudger to the side of the camera, between the rear case and the camera module.
    • Gently pry up on the camera to nudge it out from its housing.
  26. Remove the camera. Remove the camera.
    • Remove the camera.
Conclusie
80 andere personen hebben deze handleiding voltooid.
Evan Noronha
208.588 Reputatie
178 handleidingen geschreven
iFixit Lid van iFixit
Community
136 Leden
16.675 handleidingen geschreven
10 Opmerkingen
After camera replacement my iSight camera does not focus close up its blurry but when I take it out of the housing it seems to work but when I pop it back in its housing it goes blurry? Any ideas
Arran - Antwoord
Clean the lens with a qtip.
Gigabit87898 -
Hello, I was wondering if the camera they sell in here is also the same quality as the original one, thank you
Pablo Reyes - Antwoord
I replaced the rear facing camera. The sapphire filter is shattered and must be replaced. Did not come with new camera. No instructions on how to replace it. iphone is disassembled , so I am with out a phone I need a replacement filter and instructions of the steps ASAP Please help!!!!!!!!!!
Don Carroll
dc@conceptimages.com
Donald Carroll - Antwoord
It's true, the lens cover is a separate part and is fixed to the rear case. Another user posted a guide for replacing the cover on the iPhone 6—you might be able to reference that to figure out how to replace the lens cover on your 6s. Good luck!
Jeff Suovanen -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 58
Afgelopen 30 dagen: 311
Altijd: 58,595
