Ga door naar hoofdinhoud
  1. Deze stap is niet vertaald. Help het te vertalen
    Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board. Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
    • Use the point of a spudger to pry up and disconnect the antenna cable from the bottom of the logic board.
  2. Deze stap is niet vertaald. Help het te vertalen
    Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board. Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
    • Use the point of a spudger to pry up and disconnect the Lightning connector cable from the logic board.
  3. Deze stap is niet vertaald. Help het te vertalen
    Remove the three Phillips screws securing the Lightning connector bracket: Two 3.5 mm screws
    • Remove the three Phillips screws securing the Lightning connector bracket:
    • Two 3.5 mm screws
    • One 2.7 mm screw
    • Remove the bracket.
  4. Deze stap is niet vertaald. Help het te vertalen
    Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly. Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
    • Use the point of a spudger to pry up and disconnect the antenna cable from the Lightning connector assembly.
  5. Deze stap is niet vertaald. Help het te vertalen
    Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board. Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
    • Use the point of a spudger to pry up and disconnect the antenna cable from the top of the logic board.
  6. Deze stap is niet vertaald. Help het te vertalen
    Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips. If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room. Be sure to re-tighten this screw during re-installation.
    • Carefully lift the antenna cable and de-route it from the edge of the phone. Use the point of a spudger to help lift the cable free it from the retaining clips.
    • If the cable does not have enough room to lift up, loosen this Phillips screw securing the logic board so that the board can give more wiggle room.
    • Be sure to re-tighten this screw during re-installation.
    • During re-installation, be sure to route the antenna cable underneath the logic board corner.
    • During re-installation, you can also re-insert the SIM card tray after re-routing the antenna cable.
    • If you feel any resistance, stop and make sure that the tray isn't snagging the antenna cable.
  7. Deze stap is niet vertaald. Help het te vertalen
    Remove the six Phillips screws securing the speaker to the rear case: One 2.5 mm screw
    • Remove the six Phillips screws securing the speaker to the rear case:
    • One 2.5 mm screw
    • Two 2.7 mm screws
    • One 1.5 mm screw
    • One 1.7 mm screw
    • One 2.6 mm screw securing the speaker to the bottom edge of the rear case.
  8. Deze stap is niet vertaald. Help het te vertalen
    Insert the flat end of a spudger between the long edge of the speaker module and the case wall. Pry gently to loosen the speaker module. Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
    • Insert the flat end of a spudger between the long edge of the speaker module and the case wall.
    • Pry gently to loosen the speaker module.
    • Once the module is loose, lift and remove the speaker module and the attached antenna cable from the phone.
Eindstreep
Arthur Shi
178.141 Reputatie
429 handleidingen geschreven
iFixit Lid van iFixit
Community
139 Leden
15.650 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 118
