Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Onderdelen & Gereedschap
Inleiding
Bezel Separating is an important link of Screen Refurbishing. We’ll take iPhone 6s Plus as an example to show you how to separate the bezel efficiently with the help of the Laser Machine.
Video overzicht
  1. Here we have an iPhone 6s Plus display assembly with a broken glass lens.
    • Here we have an iPhone 6s Plus display assembly with a broken glass lens.
    • First, check the bezel. The bezel is complete with high strength.
    • Run function test. All going well.
  2. Place the display assembly face up under the focus positioning probe. Press the ‘auto focus’ button on the panel.
    • Place the display assembly face up under the focus positioning probe. Press the ‘auto focus’ button on the panel.
    • With the focus length indicator on, place the display assembly face up on the operating panel.
  3. Nintendo Switch-kits
    Een snelle oplossing die je weer mee laat doen
    Koop Switchkits
    Koop Switchkits
  4. Run the matching program. Choose corresponding model and drawing. Get all parameters set.
    • Run the matching program. Choose corresponding model and drawing. Get all parameters set.
    • Click ‘Red Light’ to turn on laser aiming function. Click ‘Mark’ to scan the bezel space with the laser light.
  5. Once finished, we can separate the bezel from the screen with hands instead of using other assistant tools.
    • Once finished, we can separate the bezel from the screen with hands instead of using other assistant tools.
  6. Again, let’s get the display assembly installed and test. All going well.
    • Again, let’s get the display assembly installed and test. All going well.
    • Bezel Separating of iPhone series can be done quickly and efficiently with this magic machine. Check out the video now!
Conclusie
Phryne
7.562 Reputatie
58 handleidingen geschreven
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 144
