Ga door naar hoofdinhoud
Inleiding
Follow the steps in this guide to replace the EMI shield backing the display on your iPhone 6s.
  1. Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.4 mm P2 Pentalobe screws on the bottom edge of the iPhone, next to the Lightning connector.
  2. Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Optionally, apply mild heat to the lower edge of the iPhone using an iOpener or hair dryer for about a minute.
    • Heat softens the adhesive securing the display, making it easier to open.
  3. Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Opening the display on the 6s separates a thin strip of adhesive around the perimeter of the display. If you prefer to replace the adhesive, have a set of new adhesive strips ready before you continue. It's possible to complete the repair without replacing the adhesive, and you probably won't notice any difference in functionality.
    • Apply a suction cup to the lower left corner of the display assembly.
    • Take care not to place the suction cup over the home button.
  4. Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case. Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pull up on the suction cup with firm, constant pressure to create a slight gap between the front panel and rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices and is held down with adhesive.
    • Pulling too hard may damage the display assembly. Apply just enough pressure to create a small gap between the display assembly and the rear case.
    • If you have any trouble, heat the front of the iPhone using an iOpener, hair dryer, or heat gun until it's slightly too hot to touch. This will help soften the adhesive securing the edges of the display.
  5. There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open. Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
    • There is a notch on the underside of the display, just above the headphone jack. This is the safest place to begin prying the phone open.
    • Place the flat edge of a spudger into the gap between the screen and rear case, directly above the headphone jack.
  6. Twist the spudger to widen the gap between the front panel assembly and the rest of the phone. Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
    • Twist the spudger to widen the gap between the front panel assembly and the rest of the phone.
  7. Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case. Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
    • Insert the flat end of the spudger on the left side of the phone, between the display assembly and rear case.
    • Slide the spudger up the side of the phone to separate the adhesive and pop the clips free.
  8. Remove the spudger and reinsert it on the bottom edge, where you pried the phone open. Slide the spudger to the right, along the bottom edge of the phone.
    • Remove the spudger and reinsert it on the bottom edge, where you pried the phone open.
    • Slide the spudger to the right, along the bottom edge of the phone.
  9. Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone. Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
    • Slide the spudger up the right side to continue separating the adhesive and popping the display clips free from the iPhone.
  10. Use the suction cup to open the display, breaking the last of the adhesive. Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
    • Use the suction cup to open the display, breaking the last of the adhesive.
    • Don't open the display more than 90º, as it is still connected at the top by three cables that may break if stretched.
  11. Pull up on the nub on the top side of the suction cup to remove it from the front panel. Pull up on the nub on the top side of the suction cup to remove it from the front panel.
    • Pull up on the nub on the top side of the suction cup to remove it from the front panel.
  12. Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge. Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone. Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • Gently grasp the display assembly and lift it up to open the phone, using the clips at the top of the front panel as a hinge.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
    • In a pinch, you can use an unopened canned beverage to hold the display.
  13. Android Fix Kits
    Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
    Nu winkelen
    Android Fix Kits
    Nu winkelen
    • Remove two Phillips screws securing the battery connector bracket, of the following lengths:
    • One 2.9 mm screw
    • One 2.2 mm screw
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your iPhone.
  14. Remove the battery connector bracket from the iPhone. Remove the battery connector bracket from the iPhone.
    • Remove the battery connector bracket from the iPhone.
  15. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board. Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
    • Use the point of a spudger to disconnect the battery connector by prying it straight up from the logic board.
  16. Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work. Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
    • Push the battery connector away from the logic board until it stays separated from its socket, so as to avoid any accidental connection to the battery while you work.
  17. Remove the following four Phillips screws securing the display cable bracket:
    • Remove the following four Phillips screws securing the display cable bracket:
    • Three 1.2 mm screws
    • One 2.8 mm screw
  18. Remove the display cable bracket. Remove the display cable bracket.
    • Remove the display cable bracket.
  19. Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board. Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
    • Use a spudger or a clean fingernail to disconnect the front camera flex cable by prying it straight up from its socket on the logic board.
  20. Disconnect the digitizer cable by prying it straight up from its socket on the logic board. When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
    • Disconnect the digitizer cable by prying it straight up from its socket on the logic board.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  21. Make sure the battery is disconnected before you disconnect or reconnect the cable in this step. Disconnect the display cable by prying it straight up from its socket on the logic board.
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Disconnect the display cable by prying it straight up from its socket on the logic board.
  22. Remove the display assembly.
  23. Remove the following three Phillips screws securing the earpiece speaker bracket:
    • Remove the following three Phillips screws securing the earpiece speaker bracket:
    • Two 2.3 mm screws
    • One 1.3 mm screw
  24. Lift up and remove the earpiece speaker bracket, peeling up the bracket gasket as you go. Peel up the gasket carefully, as it is thin and can tear easily. Peel up the gasket carefully, as it is thin and can tear easily.
    • Lift up and remove the earpiece speaker bracket, peeling up the bracket gasket as you go.
    • Peel up the gasket carefully, as it is thin and can tear easily.
  25. Use the flat end of a spudger to nudge the front-facing camera from its housing. Use the flat end of a spudger to nudge the front-facing camera from its housing.
    • Use the flat end of a spudger to nudge the front-facing camera from its housing.
  26. Pull back the front-facing camera to access the earpiece speaker. Remove the earpiece speaker.
    • Pull back the front-facing camera to access the earpiece speaker.
    • Remove the earpiece speaker.
    • Be careful not to touch the golden contacts as you remove and replace the speaker. Oil from your skin can interfere with the contacts interrupt the connection. If you accidentally touch them with your skin, wipe them off with a little isopropyl alcohol (rubbing alcohol) before reinstalling them.
  27. Holding the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel. Holding the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
    • Holding the front-facing camera out of the way, use the point of a spudger to push the ambient-light sensor up out of its recess in the front panel.
  28. Fold the front-facing camera and sensor cable up to allow access to the microphone. Fold the front-facing camera and sensor cable up to allow access to the microphone.
    • Fold the front-facing camera and sensor cable up to allow access to the microphone.
  29. Use the flat end of a spudger to gently break up the adhesive securing the microphone to the front panel. Use the flat end of a spudger to gently break up the adhesive securing the microphone to the front panel.
    • Use the flat end of a spudger to gently break up the adhesive securing the microphone to the front panel.
  30. Remove the front-facing camera and sensor cable.
    • Remove the front-facing camera and sensor cable.
  31. Remove the following seven 1.3 mm Phillips screws: Three screws each on the left and right edges of the display panel. A single screw recessed 1.5 cm from the right edge of the screen.
    • Remove the following seven 1.3 mm Phillips screws:
    • Three screws each on the left and right edges of the display panel.
    • A single screw recessed 1.5 cm from the right edge of the screen.
  32. Prepare an iOpener and lay it over the top edge of the phone to loosen the tape connecting the EMI shield to the front panel. After a minute, insert an opening pick between the tape and display data cable. Push the pick downwards until it is flush with the upper edge of the EMI shield.
    • Prepare an iOpener and lay it over the top edge of the phone to loosen the tape connecting the EMI shield to the front panel.
    • After a minute, insert an opening pick between the tape and display data cable.
    • Push the pick downwards until it is flush with the upper edge of the EMI shield.
  33. Use a pair of tweezers to peel up the piece of tape from the EMI shield, near the front camera housing. Use a pair of tweezers to peel up the piece of tape from the EMI shield, near the front camera housing.
    • Use a pair of tweezers to peel up the piece of tape from the EMI shield, near the front camera housing.
  34. Remove the EMI shield. When installing the EMI shield, orient it so that the metal cutout (shown at bottom center) lays over the top of the display cable assembly, while the piece of tape slides behind it.
    • Remove the EMI shield.
    • When installing the EMI shield, orient it so that the metal cutout (shown at bottom center) lays over the top of the display cable assembly, while the piece of tape slides behind it.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Evan Noronha
178.163 Reputatie
177 handleidingen geschreven
iFixit Lid van iFixit
Community
108 Leden
9.444 handleidingen geschreven
Één commentaar
Al cambiar la pantalla todo funciona correctamente excepto que tiene una sensibilidad excesiva al 3D Touch ¿a que se debe?
Gracias
jmgonzalez - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 2,165
