Ga door naar hoofdinhoud
iPhone 6s 五角螺丝更换
Wat je nodig hebt
  1. iPhone 6s 五角螺丝更换, 五角螺丝: stap 1, afbeelding 1 van 1
    • 在拆卸iPhone之前,请将电池放电至25%以下。 充电的锂离子电池如果意外被刺破可能会着火和/或爆炸。
    • 在开始拆卸之前请将你手机关机。
    • 将位于Lightning数据口两侧(处于iPhone底部边缘)的2颗3.4 mm的五角螺丝拧下。
Conclusie
如要组装你的设备,按照以下步骤反向操作就行(正向操作是拆解过程)
39 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en zh
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Evan Noronha
223.594 Reputatie
168 handleidingen geschreven
2 opmerkingen
I noticed both my pentalobe screws wouldn’t screw in last time. Upon checking the little components that the screws fix into were loose inside. Not a major drama but they also seem to hold the charger cable in place… or at least I’ve noticed cables are loose on my iPhone 6 since then. Is there a part I can buy to fix this issue, does anyone know please?
justingrisbrook - Antwoord
I have an iPhone 6s plus, but I got a new phone recently so I put my 6s plus in my side table and went back to it a couple of weeks later just to see that the pentalobe screws are missing and the phone will no longer charge, I also realized that when I plug the charger in its a bit loose. There was also nothing wrong with the phone before it worked perfectly fine.
Simoneil Ming - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 175
Altijd: 25,060
