Ga door naar hoofdinhoud
iPhone 6 Plus Vervanging van de oorstukspeaker
Wat je nodig hebt
  1. iPhone 6 Plus Vervanging van de oorstukspeaker, Pentalobe schroeven: stap 1, afbeelding 1 van 1
    • Ontlaad, voordat je je iPhone uit elkaar begint te halen, je batterij tot onder de 25%. Een geladen lithium-ion batterij kan in brand vliegen en/of ontploffen als deze per ongeluk wordt doorboord.
    • Schakel je iPhone uit voordat je deze uit elkaar gaat halen.
    • Verwijder de twee 3.6 mm lange Pentalobe schroeven aan beide kanten van de Lightning-connector.
    I prefer to remove the SIM card as the very first step since it's safer to do so while the phone is fully assembled.
    estebanfallasf - Antwoord
    I stripped one of the two screws - at a dead stop.
    Margaret Patterson - Antwoord
    Before you even start: get the iOpener or hairdryer out. You’ll need it
    GPZ - Antwoord
    If a lightning connector won’t provide a charge or needs to be wiggled carefully to provide a charge, power off the device, then try using precision tweezers to scrape the innermost wall of the lightning jack in a pinching motion to check for lint buildup. Pocket lint or other debris can accumulate inside the jack, compacting each time a cable is inserted. This can prevent a lightning cable from seating fully. Clearing the lint may restore functionality without replacing the part.
    Andrew Dolan - Antwoord
    A few hints:
    * heating up the phone works great. I used a heating pad that you put in the microwave to heat sports injuries.
    * also, I made a sheet to help you keep track of the screws as you remove them. Print out the page, then place double sided tape below each color-coded listing of screws, and stick the screws to the tape as you disassemble. This helps prevent losing the screws and keeps track of what screws are what for easier reassembly. https://drive.google.com/file/d/1pLSvKvB...
    Paul Faulstich - Antwoord
    Additional hints, for anyone who needs them:
    * stick the screws to the tape in the same positions as they are shown in the guide. This will make it easier to identify them during reassembly.
    * if the screws get mixed together, the ‘mm’ (millimetre, millimeter) measurements given in the guide can be used to identify them. Compare the lengths of the threaded shafts to each other to determine which screw is which.
    Friendly Advice -
  2. iPhone 6 Plus Vervanging van de oorstukspeaker, Instructies voor de anti-klem: stap 2, afbeelding 1 van 3 iPhone 6 Plus Vervanging van de oorstukspeaker, Instructies voor de anti-klem: stap 2, afbeelding 2 van 3 iPhone 6 Plus Vervanging van de oorstukspeaker, Instructies voor de anti-klem: stap 2, afbeelding 3 van 3
    • De volgende twee stappen demonstreren het gebruik van de anti-klem, een handige tool die je helpt bij het openen van je toestel. Als je de anti-klem niet gebruikt, sla je drie stappen over voor een alternatieve methode.
    • Raadpleeg deze handleiding voor meer gedetailleerde instructies over het gebruik van de anti-klem.
    • Trek het blauwe handvat naar achteren om de armen van de anti-klem te ontgrendelen.
    • Schuif de armen over de linker- of rechterzijde van de iPhone heen.
    • Positioneer de zuignappen in de buurt van de onderkant van de iPhone en net boven de thuisknop. De ene zuignap komt aan de voorkant en de andere zuignap komt aan de achterkant te zitten.
    • Druk beide zuignappen aan zodat ze zich stevig vastzuigen.
    • Als het oppervlak van je iPhone te glad is voor de anti-klem, waardoor deze geen goede grip heeft, kun je wat tape gebruiken om het oppervlak wat meer textuur en grip te geven.
  3. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 3, afbeelding 1 van 3 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 3, afbeelding 2 van 3 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 3, afbeelding 3 van 3
    • Trek het blauwe handvat naar voren om de armen te vergrendelen.
    • Draai het handvat 360 graden met de klok mee, of totdat de zuignappen uit beginnen te rekken.
    • Zorg dat de zuignappen op één lijn zitten met elkaar. Als ze beginnen te schuiven, maak je ze weer los en zorg je dat ze weer op één lijn komen te zitten.
    • Als de anti-klem een opening heeft weten te creëren die groot genoeg is, breng je een openingsplectrum in de opening onder het scherm aan.
    • Als de anti-klem moeite heeft met het creëren van de opening draai je het handvat een kwartslag met de klok mee.
    • Draai het handvat nooit meer dan een kwartslag per keer, en wacht altijd een aantal seconden voordat je weer besluit te draaien. Laat de anti-klem het werk voor je doen.
    • Sla de volgende drie stappen over.
    Use clear nontextured tape place that over the phone screen. Refer to any guide that addresses replacing a shattered screen
    Abigail Cherry - Antwoord
    I know it's tough with cracked glass. You just need enough to get in a plstic pry tool or guitar pick. Then you can pry it apart. Just be patient, I cannot stress that enough; the electronics are very, very small and fragile.
    Mike - Antwoord
  4. iPhone 6 Plus Vervanging van de oorstukspeaker, Voorste paneelmodule: stap 4, afbeelding 1 van 1
    • Gebruik een enkele zuignap om het voorste paneel uit de telefoon te tillen:
    • Druk een zuignap op het scherm, net boven de thuisknop.
    • Zorg dat de zuignap goed op het scherm gedrukt is om een sterke trekkracht te creëren.
    • Als je scherm gebarsten is, kun je het beplakken met een laag doorzichtige tape, waardoor de zuignap zich weer vast kan zuigen. Als alternatief kun je sterke tape gebruiken in plaats van de zuignap. Als niets daarvan lukt, kun je de zuignap aan je kapotte scherm vastlijmen met secondelijm.
    Avec la ventouse, l’ouverture est brutale, tout s’est déclipsé d’un seul coup. Faire attention.
    Paul Briffaut - Antwoord
    English Please!
    tom mozeleski -
    With the sucker, the opening is brutal, everything was cleared at once. Pay attention. (Paul’s comment translated by Google)
    Steve Schlotter - Antwoord
    May need to burp the sticker before it sticks. Need to let the air out. Once Idid that, no problem. Except it was still hard to get the cover to start up.
    Patricia Tucker - Antwoord
    Don’t waste your time with the suction cup - it doesn’t work! insert the blade of a box cutter just below the lower screen edge below the home button and gently pry just enough to start cracking the seal.
    Stephen Smith - Antwoord
  5. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 5, afbeelding 1 van 1
    • Trek, terwijl je de iPhone met een hand stevig vasthoudt, aan de zuignap om de voorste paneelmodule een stukje van de achterste behuizing te scheiden.
    • Neem je tijd en gebruik een stevige, constante kracht. De schermmodule zit steviger vast dan in de meeste toestellen.
    • Maak gebruik van een plasticen openingstool om de achterste behuizing naar beneden te duwen, weg van de schermmodule, terwijl je aan de zuignap blijft trekken.
    • Er is een aantal klemmen dat de schermmodule aan de achterste behuizing bevestigt. Het kan dus zijn dat je een combinatie van de zuignap en de plastic openingstool nodig hebt om de schermmodule los te krijgen.
    Be extra careful here. If you don’t take your time, your front panel may jerk back on you, causing you to overextend and break the front camera/mic flex cable; happened to me. Slowly peel back the front panel, opening it no more than 90º.
    Thomas - Antwoord
    watch out for the left side of the phone the adhesive bunches up around the inner clips, i didn’t realize it and the upper left of my screen cracked pretty bad. But this guide is awesome follow every direction to the letter
    Aaron Fitzpatrick - Antwoord
    Note: this comment is written for the iPhone 6 Plus, but may also apply to other models of iPhone.
    Disassembly:
    The clips in the rear case attach to small slotted shapes under the edges of the display assembly, and these attachment points alternate from one side to the other. Moving from bottom to top, gently pulling the rear case away at these points will help to separate the two halves without using too much force.
    Reassembly:
    Ensure that the plastic clips along the top edge of the front panel (shown in step 8) are fitted properly inside the rear case, then gently press the display assembly into the rear case at these points, moving from top to bottom. There may be a small click sound as the clips in the rear case engage with the slots on the display assembly, and the rear case should fit flush with the edges of the display assembly.
    Friendly Advice - Antwoord
    This was challenging. For me, the suction cup could only create a tiny bit of motion and at first, no actual gap at all. You might have to pull the suction cup away from the base a few times just to loosen things up a tiny bit. Eventually, I got my fingernail in, and then after a few minutes got the plastic tool in.
    Also, use the plastic tool to gently pry along the sides of the phone once there’s light there. I was afraid of using too much leverage and breaking the screen as per the other comments, but starting at the bottom and then going around the sides slowly worked for me.
    FixingMyiPhone - Antwoord
  6. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 6, afbeelding 1 van 2 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 6, afbeelding 2 van 2
    • Trek aan het kleine lipje op de zuignap om de vacuüm op te heffen.
    • Verwijder de zuignap van de schermmodule.
    There is an adhesive strip all along the edge between the top and bottom of the phone. Is that just adhesive or is it wire of some sort?
    Larry Ingerling - Antwoord
    @lingerling The adhesive strip was introduced on the iPhone 6s and 6s Plus (one model year later than what’s shown on this page). Guides specific to each model can be found here—be sure to use the correct one for your particular phone. And yes, just adhesive, no wires. ;)
    Jeff Suovanen - Antwoord
  7. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 7, afbeelding 1 van 3 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 7, afbeelding 2 van 3 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 7, afbeelding 3 van 3
    • Trek de voorste paneelmodule, aan de kant van de thuisknop, weg van de achterste behuizing en maak daarbij gebruik van de bovenkant van de telefoon als scharnier.
    • Open het scherm in een hoek van ongeveer 90º en laat deze tegen iets leunen waardoor het rechtop blijft staan terwijl jij aan de telefoon werkt.
    • Gebruik indien nodig ook een elastiek om het scherm vast te maken aan het object waar het tegenaan leunt. Dit voorkomt ook dat er teveel druk op de schermkabels komt te staan.
    • Je kunt zelfs gebruik maken van een ongeopend blikje drinken om de telefoon tegenaan te laten leunen.
    Be careful If we leave the screen connected and set it to 90 degrees, the speaker / sensor flex may break. With an opening of 60 degrees it is convenient to completely disconnect the screen. The headset's flex is short, and if we put it at 90º, it can break. Guiding me from the images of iFixit, I have broken two cables.
    Español:
    Cuidado. Si dejamos la pantalla conectada y lo ponemos a 90 grados, el flex del altavoz/sensor puede romperse. Con una abertura de 60 grados es conveniente desconectar enteramente la pantalla. El flex del auricular es corto, y si lo ponemos en 90º , se puede romper. Guiándome de las imágenes de iFixit, se me han roto dos cables.
    txaukos - Antwoord
    At 60º the display will block access to all the screws and the phone would be practically unserviceable, so I’m having trouble making sense of this comment. The cables on a factory original display are pretty tough and designed with enough slack that a 90º angle is no problem. Same with any decent aftermarket display.
    If you look at the enlarged image, you can see how the flex cable from the camera / speaker is in tension. This is my opinion. Sorry for my bad English
    Si usted se fija en la imagen ampliada, puede ver cómo el flex cable de la cámara/altavoz está en tensión. Esta es mi opinión.
    Perdón por mi mal inglés
    txaukos - Antwoord
    your English isn’t the issue, it’s the proposed 60 degree opening space that doesn’t allow for the removal of the screws of the mounting plate where the connectors connect to the main pcb…
    if can make a recommendation here; it helps if the can is full and not refrigerated, the weight helps in keeping the phone where it should stay without adding additional tension to the ‘flex’ ribbon cable. it’s called flex for a reason people, if your breaking these the phones already been overheated too much, the cables become brittle and should also be replaced. i replaced my battery without disconnecting the screen, at 90 degrees with a rubber band around an empty beer can. pierced the orig. battery and caused sparks. albeit, i wasn’t in a hurry and it took me a good 30+ minutes, removal of the battery and stickers is by far the most challenging, especially when NOT disconnecting the screen…
    it’s not a race, take your time. move slowly but precisely with forethought and persistent force…
    circuitbender 477 - Antwoord
    Werkt dit ook voor iPhone 7(plus)?
    Christina Pegtel - Antwoord
    Werkt dit hetzelfde voor iPhone 7 (plus)?
  8. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 8, afbeelding 1 van 2 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 8, afbeelding 2 van 2
    • Een aantal klemmen aan de bovenkant van de telefoon functioneert gedeeltelijk als scharnier, waardoor je de schermmodule kunt openslaan als een boek.
    • Positioneer de klemmen, tijdens het weer in elkaar zetten van je telefoon, net onder de bovenkant van de achterste behuizing. Schuif het voorste paneel vervolgens naar boven tot de bovenkant van dit paneel op een lijn is gebracht met de achterste behuizing.
    I would recommend protecting the screen once the display is free and the suction cup has been removed. This will help avoid any possibility of accidental scratching of the display crystal while the remaining steps are being performed. I used an inexpensive screen protector then removed it after reassembling and testing are complete.
    anthonyspampinato - Antwoord
  9. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 9, afbeelding 1 van 1
    • Verwijder de volgende Phillips schroeven uit het plaatje over de batterijaansluiting:
    • Eén 2.3 mm lange schroef
    • Eén 3.1 mm lange schroef
    for the iPhone 6 Plus, all screws were Phillips #000
    Michael Adams - Antwoord
    I had difficulty removing the 3.1mm (iPhone 6 Plus / Phillips #000); had to give it significant downward pressure to get it started.
    Allen Matheson - Antwoord
    stripped the 2.3mm screw attempting to remove, had to use excessive force to successfully remove
    Matthew Gao - Antwoord
    The Phillips bits provided in the kit would not engage the Phillips heads enough to loosen them. Luckily I had my own small screwdriver set that worked like a charm.
    David Davis - Antwoord
    Same issue. Could not remove the screw. Dead in the water.
    Tiffany - Antwoord
    Agree with above comments regarding the supplied Phillips bit. It is not the correct size.
    Use a Phillips #000.
    bobgottner - Antwoord
    Phillips #000 is what’s included in the kit. As others mentioned above, firm downward pressure is key. The phone is not that delicate; just press hard and crank it.
    Jeff Suovanen -
    Is this step necessary ?\
    Asianay - Antwoord
    @asianay0129 Yes, disconnecting the battery is necessary. You can sometimes get away with skipping it, at the risk of destroying something important and potentially bricking your phone. Not a wise gamble for the sake of skipping two screws.
  10. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 10, afbeelding 1 van 1
    • Verwijder het metalen plaatje over de batterijaansluiting uit de iPhone.
    Was not able to remove the battery connector bracket as one of the cable connectors was glued/stuck to the underside. Instead moved the bracket out of the way to disconnect the battery. Care should be taken not to over bend/stretch the ribbon cable.
    dwtan - Antwoord
    That may be just the foam connector adhering to the bracket. If you pull up gently and twist slightly it should separate.
    Evan Noronha -
    It was the foam connector, and it did twist free with a gentle pull
    Al Taylor - Antwoord
  11. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 11, afbeelding 1 van 1
    • Gebruik je nagel of de zijkant van een openingstool om de batterijaansluiting op subtiele wijze uit het contact op het logic board omhoog te duwen.
    • Zorg ervoor dat je enkel de batterijaansluiting en niet het contact op het logic board omhoog duwt. Als je het contact op het logic board omhoog probeert te duwen, loop je het risico de volledige aansluiting te beschadigen.
    you may consider placing a thin non-conductive item between the connector and the socket like a bit of rubber band to prevent any power flowing during this procedure
    It was too close to other parts to pry up with either end of plastic tool. Finally used 1 tine of tweezer to lift edge. Came free easily
    J’ai pris une loupe pour bien observer l’endroit où placer l’outil.
    Magnification is key for many tasks and this is certainly one.
    Kenneth Gilbert - Antwoord
    I couldn’t use the iFixit blue opening tool to pry that battery connector. I used the top of the black spudger near the hole where the 3.1mm screw was in step 9-10 to easily pry it open!
    Alyssa Sayuki - Antwoord
    The blue plastic board breaker can easily cause damage here. Professionals would recommend using the human fingernail as the ideal tool for this job.
    Jessa Jones - Antwoord
  12. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 12, afbeelding 1 van 1
    • Verwijder de volgende Phillips schroeven die het plaatje over de kabel van de schermmodule bevestigen:
    • Drie 1.2 mm lange schroeven
    • Eén 1.5 mm lange schroef
    • Eén 2.9 mm lange schroef
    • Probeer geen langere schroeven in de met rood gemarkeerde schroefgaten te draaien. Doe je dit wel, dan kan dit permanente schade aan het logic board veroorzaken.
    There's an other panel with one screw in the middle.........
    Herbert - Antwoord
    Sounds like you have an iPhone 6s Plus, rather than a 6 Plus. Be sure to use the correct guide! And make sure you’ve ordered the correct part, as they’re not cross-compatible.
    Jeff Suovanen -
    I _love_ the color coding of screws. I know this is a little OCD, but it would be incredibly useful if there were an 8.5 X 11 you could print with indicated homes for where to drop items from each step of disassembly. That is, in the box for step 9, little colored circles for where to place each screw type. As long as you don't jostle the paper, it would make it a lot easier to know exactly where you are in reassembly.
    cscarlson47shop - Antwoord
    I have done the exact same thing. Created a sheet where each screw goes.
    Chris Murphy -
    I used the 000 bit from the ifixit 54 piece kit.
    hhandh - Antwoord
    Actually you don’t need to do steps 12 to 18 if you attach the display panel to the iPhone box as shown in step 7 and handle your iPhone with care during the replacement. I didn’t disconnect the display panel mainly because the more you work on the interior of your phone the higher is the chance you break something.
    Dany Castillo - Antwoord
    Since this guide is for DISPLAY replacement, I don’t see how you can skip the steps for disconnecting and removing the DISPLAY.
    Jim Bateman -
    That's what I was thinking.
    The Wizard - Antwoord
    I skipped this series of steps too. I was very careful when removing the battery and never had an issue with the screen leaning back against the box that this battery shipped in. I even broke half of the third strip of adhesive but used a plastic card to slide under the battery and it slowly lifted out without applying heat.
    mark - Antwoord
    I'm having trouble with one screw not wanting to come out. Any suggestions to keep from stripping the head and getting it?
    Patric - Antwoord
    which screws are which sizes cause i ordered new ones and cant figure it out
    MONsterHEIT - Antwoord
    I also did not see the need to remove the display assembly for this repair. However I did place a can of corn against the vertically positioned display and then secured the display to the can with a rubber band.
    whiteshephard - Antwoord
    I recommend removing the display assembly, I didn’t and somehow damaged the home button cable. At least remove the cover to ease the tension on the cables.
    I played around with different screwdrivers to get certain screws out. I made sure I wasn’t applying heavy pressure so I wouldn’t strip the head. Apple is crazy for doing this to us lol.
    Anyways invest in a magnetized mat to organize your screws. It was really difficult to keep things organized and still, especially with these tiny screws…
    Jeffrey Robinos - Antwoord
    what happens if i forgot to put the ribbon cable shield back on? the phone is now working but i forgot to put the shield back on and i am missing 2 screws. can i leave the shield off?
    Fred ticoman. - Antwoord
    @ticoman12 It’ll work without the shield, but the connectors may pop out unexpectedly.
    Jeff Suovanen -
    Just be really careful remembering which screw is which. I drew a quick sketch of the bracket, then put the screws in the relevant places. There’s no way I would have been able to figure them out otherwise - my eyes can’t see the difference between a 1.2 and 1.5mm screw!
    Paul Johnson - Antwoord
    The most fiddly part of the job.
    Much easier if you put the screwdriver head on the screw and then insert it into the opening. The slight magnetism will hold it in place. Don’t fully tighten a screw until all the screws are in place. Much like installing lug nuts on a car.
    GPZ - Antwoord
    I also skipped steps 12-18 as Danny had suggested. It made this repair quite easy, so thank you and others for suggesting this. I was also very careful to allow the battery to discharge before starting the process.
    Bruce Platt - Antwoord
    I question whether Steps 12-18 (separating the display from the case) is actually necessary? The battery can be removed/replaced with the display connected (but standing upright, as displayed in Step 7.
    Leaving the display attached obviates the most difficult steps (re-connecting the various control ribbons — 3/4 of ‘em!
    I followed this manual completely and the repair was successful. But if I had this to do over, I’d leave the display connected.
    Dana Smith - Antwoord
    I skipped the steps 12-18 as well and thank goodness I did so I won’t have to worry about issues with any of the cables.
    my panel is different from what is pictured anyway ‘cause I have one screw in the middle like what Herbert said on the first comment.
    Maria Filamor-Robinson - Antwoord
    I realized too late just how handy the magnetic mat is that they have in their shop. So I organized the screws with a piece of clear packing tape. On the smooth side, use a sharpie to draw spacious circles with “R” “O” and “Y” inside each circle to represent the color coded screws and then use the sticky side to keep the screws in place. I found that using the tweezers to take them off the screwdriver helps you stick them head first to the tape better.
    Selena Castillo - Antwoord
  13. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 13, afbeelding 1 van 1
    • Verwijder het plaatje over de kabel van de voorste paneelmodule op het logic board.
  14. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 14, afbeelding 1 van 2 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 14, afbeelding 2 van 2
    • Zorg dat je, in de volgende vier stappen, enkel en alleen de kabelaansluitingen en niet de contacten op het logic board omhoog duwt.
    • Gebruik, terwijl je het voorste paneel ondersteunt, een nagel of de zijkant van een openingstool om de kabelaansluiting van de naar voren gerichte camera en de oorstukspeaker los te koppelen.
    Why does the screen need to come off?
    Sterling Coffey (N0SSC) - Antwoord
    Because the cables are delicate, and following steps are easier if phone halves are not flopping around together, especially for amateurs.
    Matthew Goheen - Antwoord
    I don't know if anyone will see this but here it goes: for the life of me I can't get the front-facing camera and earpiece speaker connector to seat. Everything else went back together fine but this one connector will not go in. Sometimes it seems like it's in even though it doesn't really pop in and it'll kinda sit there for a sec and then it pops out.
    Any insight would be greatly appreciated, thank you
    Droopy Caledonia - Antwoord
    Try starting at one end instead of in the middle. It's to easy to bend a connector and this way, I can get a safe start and go from there.
    Rongwey - Antwoord
  15. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 15, afbeelding 1 van 2 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 15, afbeelding 2 van 2
    • Koppel de kabelaansluiting van de thuisknop los.
  16. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 16, afbeelding 1 van 2 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 16, afbeelding 2 van 2
    • Zorg dat de batterij los is gekoppeld voordat je begint met het loskoppelen of weer aansluiten van de kabel in deze stap.
    • Gebruik een plastic openingstool om de aansluiting van de schermdatakabel los te koppelen.
    • Bij het hermonteren van je telefoon kan het zijn dat de schermdatakabel loskomt van de aansluiting. Dit kan leiden tot witte lijnen of een zwart scherm bij het inschakelen van je iPhone. In dat geval moet je de kabel weer aansluiten en je iPhone "power cyclen", wat je kunt doen door de batterijaansluiting los te koppelen en weer aan te sluiten.
    The piece of advice about power cycling the phone by disconnecting and reconnecting the battery proved crucial to the success of my repair (camera and lens replacement). At first when charging the phone after closing it, I got a dark, blank screen with an intermittent buzzing noise. After re-opening the phone and making sure all cables had been properly reconnected, I ignored the advice to power cycle the phone. Still all I got was a dark, blank screen (and intermittent buzzing if charging t). Then I opened it a third time (leaving the screen connected and attached at a 90 degree angle) and I only disconnected and reconnected the battery. Voila! When I closed the phone and powered it up, I got the screen to light up!
    Gianni - Antwoord
    how did you disconnect and reconnect the battery?
    Teresa Trevino - Antwoord
    If you’ve been following the guide, you already disconnected it in this step. To reconnect it, just line up the connector and press it into place.
    Jeff Suovanen -
    After replacing the battery, the phone seems dead. I thought it just needed recharging so I left it charging all night. Still dead in the morning. Now I think it might be because the display data cable is off, and I should open the phone and check it. But the battery might be on full power in that case, and they don’t advice to open the phone when battery if full. What can I do?
    Ila Awasthi - Antwoord
    The advice aims at avoiding battery fire. Just be careful.
    Katherine Williams - Antwoord
  17. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 17, afbeelding 1 van 2 iPhone 6 Plus Vervanging van de oorstukspeaker: stap 17, afbeelding 2 van 2
    • Koppel ten slotte de kabelaansluiting van de digitizer los.
    • Druk, bij het weer aansluiten van de digitizerkabel, niet op het midden van de aansluiting. Druk in plaats daarvan eerst op een kant van de aansluiting en druk dan op de andere kant. Druk in het midden van de aansluiting kan ervoor zorgen dat de pinnetjes buigen en er permanente schade wordt veroorzaakt.
    some images and guidance regarding reassembly would be helpful. You don't need to use the spudger to get them back on: fingers are better because there's a really subtle click you feel when you get them seated properly.
    When you're reassembling, a note that this is the step where you should test for proper screen function would be really useful. First time I reassembled, I didn't seat something properly, got all the screws back together and then realized the screen wasn't functioning properly. Had to disassemble back down to step 14 and then re-reassemble.
    I am having this issues right now! I have unplugged and plugged in these cables at least 20 times and each time I get white lines. I finally have it to where there are only 4 white lines and I am almost willing to live with it. Any suggestions?
    mattmay002 -
    Clean the screen connectors incase they are not making a clean connection
    Karen Jones - Antwoord
    I'm having nightmares with the digitizer connector. Simply can't get it to work unless I'm applying some pressure on the connectors. Everything seems almost microscopically clean. Any suggestions friends?
    Henry A -
    could it be the replacement screen? test with your old screen and see if you have the same problem.
    Charles - Antwoord
    To ++mattmay002++  Did you power cycle the phone? Check out the comments on the previous step for a how to.
    Robert Liles - Antwoord
    I had issues with it too. When connecting this cable, make sure to rock finger side to side after connecting. It’s a wide connector so try to listen for 2 clicks on this one connector. That’s how I fixed mine
    Albert Einstein - Antwoord
    Re-attaching this cable is the only tricky part to replacing the battery on my 6+. It had a bow on the middle that I had to flatten out before pressing the connector on with finger first on one edge and then on the other. I had white tire tracks on the screen and no touch screen until I connected it correctly. The front has to rest in just the right place on the back while attaching this thing so the cables aren’t strained the front doesn’t fall down. Small fingers would be a plus at this step.
    richard - Antwoord
    Reseating these connectors on reassembly is definitely the most difficult part of this repair. It took me several attempts before the lowermost connector would seat properly and I did accidentally bend it slightly in the process. Fortunately I was able to get it straight again and get it to click in. The other three went in fine though and no lasting damage seems to have been done.
    Andy Gibbons - Antwoord
    Another thing - These cables can become overlapped in the wrong way and make you think they are in a different order than they should be. Eg. it’s easy to mix up the ones from step 15 and 17. You can actually unravel the cables and re-layer them on top of each other in any order, so remember this! They look like they’re one solid mass but they’re not.
    domarius - Antwoord
    I never removed the last digitizer connctor. I removed the first three connectors, left the screen propped at 90 deg tied to a box and removed the battery, there is minimal movement. In fact when I reattached the connectors, only the first and maybe second connector feels taut, so it’s necessary to only remove the first connector if you can be gentle with it. Less headache. And my guess why so many people had issues is that micro dust gets into the connectors and cause connection loss. You be surprised how little dust can cause havoc.
    darrcc - Antwoord
    And forgot one thing, keep a can of air duster woth you to remove as must dust as you can see. A camera air blower will also do nice.
    darrcc - Antwoord
    I haven’t removed my screen in past battery replacements, I found it easier. However, this time I followed the instructions because my old battery was very stuck, and I needed the screen gone to get the battery out…
    When I replaced the screen, at first it wouldn’t even boot/start up. (Yes, I inserted my own testing step, as someone here suggested, before final reassembly).
    The screen would just show a fuzzy image, and the board that all the cables attach to would heat up, then it would turn itself off. I tried reconnecting them carefully 3 times, and even made sure to get a little “click”, all to no avail.
    The final try, I used my fingernail to really press down on the back side of the digitizer cable. I heard more clicking, though I thought I might be tearing the cable too. With nothing left to lose, I continued across the back, and heard several more clicking/tearing sounds.
    This worked, and it booted after that. It still had white lines, but those faded away overnight.
    Morgan Giddings - Antwoord
    About the digitizer connector: its flat cable is so short that the when I attempted to seat the next connector, its flat cable pressed on the digitizer cable, which can pull on the connector and dislodge it. That happened several times for me before success.
    Robert Bernard 27 Nov 19
    Robert H Bernard - Antwoord
    Nous n’apercevons pas bien les nappes et l’ordre dans lesquelles elles doivent être replacer
    Patrick AZOULAY - Antwoord
  18. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 18, afbeelding 1 van 1
    • Verwijder de voorste paneelmodule van de achterste behuizing.
    Never remove the screen without disconnecting the battery. It's possible the back light can be blown and that's a even more difficult repair. Always, ALWAYS, disconnect battery before repairing items. (Unless it's not possible.)
    Marvin Ballard - Antwoord
    How do you disconnect the battery from the screen?
    Shamil Bhatti -
    The Step 11 disconnects the battery :)
    jeffxtechs - Antwoord
    I think you mean Step 8 :)
    Jeff Suovanen -
    I tried it once and
    Brian - Antwoord
    And what? I tried it once and here’s a million dollars?
    Oh I get it… they got him! :(
    https://www.youtube.com/watch?v=UlznqpBg...
    domarius -
    When disassembling the iphone at this point note the cables, and there placement/orientation.
    GERARD SZAREK - Antwoord
    Be really careful with the step after this. Do not commence until you have read all the comments. You need to get a good hold of the plastic strips preferably before they double over on themselves. You have to avoid puncturing the battery at all costs. Slowness and caution here will save you a lot of long term pain.
    Laura Houghton - Antwoord
  19. iPhone 6 Plus Vervanging van de oorstukspeaker, Oorstukspeaker: stap 19, afbeelding 1 van 1
    • Verwijder de volgende Phillips schroeven, die het bovenste plaatje bevestigen:
    • Twee 2.3 mm lange schroef
    Nice move, which can stop the bracket from falling down.quite detailed instruction. but you should choice an excellent front facing camera and sensor before the replacement.
    William - Antwoord
    Attempted this repair and my touch screen completely stopped working. Great walkthrough, but not sure what I did wrong in the repair to cause my issue.
    surfincubus86 - Antwoord
    Hi I've had exactly the same problem, what was your solution to this? would be very helpful!
    Iona -
    I had the same issue. My screen quit working and I could feel heat coming through my phone at the earpiece. I took the phone apart again and realized that the data cable for the screen had come loose. When I reattached the data cable and starting working steps 12-18 backwards to replace the shield, as noted in the very last step, I see that youhave to keep the screen at an inclinewhen replacing the shield over the cables. Otherwise, you stretch the display data cable and it can come loose. My screen works fine now and there is no heat coming from my earpiece.
    Angela Hall -
    Just completed this repair. My front facing microphone next to the ear piece had gone bad causing siri to not hear me and front facing videos had no sound. Definitely reccomend getting replacement parts from ifixit. Have had good experiences with all their parts unlike many other suppliers on the internet. Hate to admit it (don't want them to raise prices) but even though you pay a little bit more, you save frustration not getting DOA parts from cheaper sources. All of ifixit's parts are top quality and they even pack them in anti-static packaging. That says alot. Thanks ifixit!
    sherwood7 - Antwoord
    Great instructions save the later steps. The ear speaker piece having to bend 180 degrees for the installation needs more clarification.
    howchewdoin - Antwoord
    After this repair, my screen quit working and I could feel heat coming through my phone at the earpiece. I took the phone apart again and realized that the data cable for the screen had come loose. When I reattached the data cable and starting working steps 12-18 backwards to replace the shield, as noted in the very last step, I see that you have to keep the screen at an incline when replacing the shield over the cables. Otherwise, you stretch the display data cable and it can come loose. My screen works fine now and there is no heat coming from my earpiece.
    Angela Hall - Antwoord
    The middle screw, listed as a 2.3mm was actually a 2.9mm in my iPhone 6 Plus
  20. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 20, afbeelding 1 van 1
    • Til het plaatje over het oorstuk omhoog en verwijder deze uit de schermmodule.
  21. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 21, afbeelding 1 van 1
    • Gebruik het platte einde van een spudger om de naar voren gerichte camera en de schermkabels omhoog en naar de zijkant de duwen.
  22. iPhone 6 Plus Vervanging van de oorstukspeaker: stap 22, afbeelding 1 van 1
    • Gebruik een pincet om de oorstukspeaker stevig vast te pakken en uit de schermmodule te verwijderen.
    can you put Earpiece iPhone 6s plus in iPhone 6 plus
    ahmad xd - Antwoord
Conclusie
Om je toestel weer in elkaar te zetten, volg je deze instructies in omgekeerde volgorde.
91 andere personen hebben deze handleiding voltooid.
Met dank aan deze vertalers:
en nl
100%
Thomas Keulemans helpt ons de wereld te herstellen! Wil je bijdragen?
Begin met vertalen ›
7 opmerkingen
Dropped my iphone and the speaker stopped working.
Expected that it was a connector that was lose.
Used this guide to fix it.... Thanks :)
henriklotstrand - Antwoord
My son was chewing on my phone and the speaker was real quiet afterwards. I purchased your product above and installed but nothing changed. Not sure what else it could be, don't want to purchase a 100$ display only to have that not fix the issue either. And of course since I've already opened it Apple sent it back to me :D
Jacob Carrillo - Antwoord
After dropping my iPhone from the car, the speaker stopped working. Thankfully using this guide I was able to reseat the connector and all was good again. Make sure the four cable are attached properly to the board when reassembling as I had to take the protective covers back off again and reseat them.
Overall I feel confident that I would be able to do it again.
On a separate note I would highly recommend a decent precision set to carry out any repairs on these small devices. The screws are tiny and magnetised tools are a must.
Thanks iFixit!
Sam Colbear - Antwoord
phone worse off, smh, well i did as it said, i even bought all the tools from them that i needed, now my phone stuck on apple logo, did reset holding power and home button, went back in disconnected reconnect display connection and power cycled disconnecting battery connector, and still stuck on apple logo. followed everything, was careful, dont know if i went wrong, or what
tony ny - Antwoord
UPDATE been 20 min finally went to home screen but charging port not working, tried 3 different usb cords, will keep u updated while i try figure this $@$* out
tony ny - Antwoord
UPDATE: so the charging port didnt get fixed, took it to a cell phone place , he said its charging IC got messed up, whatever that means, took to best buy they said to get apple to fix i since i opened up, they would charge me another 40$ on top of fee to fix, and fee to fix would cost almost as much as phone. took to apple traded in broken phone towards new one, they didn't realize it wasnt working, it turns on screen works fine, just took forever to turn on and the port doesn't recognize any connection, they gave me 185$ towards new one, so all in all i probably should have just learned to just use the speaker or headphones smh. hope others had better luck
tony ny - Antwoord
Everything worked perfectly!!! Should have bought the magnetic mat though. I think I’ll be getting that next time. Thank you IFIXIT!!!
rwpaine - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 39
Altijd: 76,757
