Ga door naar hoofdinhoud
iPhone 6 Plus SIM Card Replacement
Wat je nodig hebt
  1. iPhone 6 Plus SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 2 iPhone 6 Plus SIM Card Replacement, SIM Card: stap 1, afbeelding 2 van 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press to eject the tray.
    • This may require a significant amount of force.
  2. iPhone 6 Plus SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the SIM Card tray assembly from the iPhone.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
Conclusie
35 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
This granny jammed the SIM card into unlocked iPhone 6s + without the metal slide Is it possible to retrieve it?
Bee Ring - Antwoord
Hi Bee Ring! If you’re not having any luck shaking the phone to get it out, try inserting a piece of tape in to the slot, double-sided if possible, to try to grab the card, you can also try long thin tweezers. You might also take it down to your provider and see if they have any tricks. If it’s absolutely not coming out, you may need to open the phone, you can follow this SIM eject lever guide, you should need to remove the screen, just open it and look at step 21. You can try to push the SIM card out of the slot with a toothpick, you may need to remove that eject lever. Best of luck!
Sam Goldheart -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 52
Altijd: 26,127
