Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the single 2.8 mm Phillips #00 screw securing the plastic clip to the logic board.
Remove the single 1.3 mm Phillips #00 screw recessed against the top of the rear case.
Use a pair of tweezers to firmly grasp the plastic clip and remove it from the iPhone.
Remove the single 1.6 mm Phillips #00 screw securing the antenna clip to the rear case.
Carefully grasp the antenna clip with a pair of tweezers and remove it from the iPhone.
