Ga door naar hoofdinhoud
iPhone 6 Pentalobe Screws Replacement
Wat je nodig hebt
  1. iPhone 6 Pentalobe Screws Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
Conclusie
100 andere personen hebben deze handleiding voltooid.
8 opmerkingen
What size screwdriver do I need to remove these screws?
ronrola - Antwoord
P2 Pentalobe Screwdriver
sbrown9615 -
really? follow these steps in reverse to reinstall? it already is laughably short...
beautron7 - Antwoord
also how is this moderate difficulty?
I have the correct screwdriver, but after taking out the original pentalobe screws, they will not screw back into the iPhone. Really bizarre. Do these screws get easily stripped?
dcs Bu - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 6
Afgelopen 7 dagen: 38
Afgelopen 30 dagen: 136
Altijd: 64,512
