Ga door naar hoofdinhoud
iPhone 6 Screen Replacement
Wat je nodig hebt
Video overzicht
  1. iPhone 6 Screen Replacement, Pentalobe Screws: stap 1, afbeelding 1 van 1
    • Before disassembling your iPhone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.6 mm-long P2 Pentalobe screws next to the Lightning connector.
  2. iPhone 6 Screen Replacement, Tape over the display: stap 2, afbeelding 1 van 3 iPhone 6 Screen Replacement, Tape over the display: stap 2, afbeelding 2 van 3 iPhone 6 Screen Replacement, Tape over the display: stap 2, afbeelding 3 van 3
    • If your display glass is cracked, keep further breakage contained and prevent bodily harm during your repair by taping over the glass.
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
    • If the broken glass makes it difficult to get a suction cup to stick in the next few steps, try folding a strong piece of tape (such as duct tape) into a handle and lifting the display with that instead.
  3. iPhone 6 Screen Replacement, Anti-Clamp instructions: stap 3, afbeelding 1 van 3 iPhone 6 Screen Replacement, Anti-Clamp instructions: stap 3, afbeelding 2 van 3 iPhone 6 Screen Replacement, Anti-Clamp instructions: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Clamp
    $24.95
    Koop
    • The next two steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your iPhone.
    • Position the suction cups near the bottom edge of the iPhone just above the home button—one on the front, and one on the back.
    • Squeeze the cups together to apply suction to the desired area.
    • If you find that the surface of your iPhone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  4. iPhone 6 Screen Replacement: stap 4, afbeelding 1 van 3 iPhone 6 Screen Replacement: stap 4, afbeelding 2 van 3 iPhone 6 Screen Replacement: stap 4, afbeelding 3 van 3
    • Pull the blue handle forwards to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    • Insert an opening pick under the screen when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, rotate the handle a quarter turn.
    • Don't crank more than a quarter turn at a time, and wait a few seconds between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next three steps.
  5. iPhone 6 Screen Replacement, Manual Opening Procedure: stap 5, afbeelding 1 van 1
    Anti-Clamp
    $24.95
    Koop
    • If you don't have an Anti-Clamp, use a single suction cup to lift the front panel:
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is pressed securely onto the screen to get a tight seal.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
  6. iPhone 6 Screen Replacement: stap 6, afbeelding 1 van 1
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • Using a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while continuing to pull up with the suction cup.
    • There are several clips holding the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  7. iPhone 6 Screen Replacement: stap 7, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 7, afbeelding 2 van 2
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  8. iPhone 6 Screen Replacement, Opening up the phone: stap 8, afbeelding 1 van 3 iPhone 6 Screen Replacement, Opening up the phone: stap 8, afbeelding 2 van 3 iPhone 6 Screen Replacement, Opening up the phone: stap 8, afbeelding 3 van 3
    • Open the iPhone by swinging the home button end of the front panel assembly away from the rear case, using the top of the phone as a hinge.
    • Several clips along the top edge of the front panel form a partial hinge.
    • During reassembly, align the clips just below the top edge of the rear case. Then, slide the front panel upward until its top edge is flush with that of the rear case.
  9. iPhone 6 Screen Replacement: stap 9, afbeelding 1 van 3 iPhone 6 Screen Replacement: stap 9, afbeelding 2 van 3 iPhone 6 Screen Replacement: stap 9, afbeelding 3 van 3
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, an unopened canned beverage works well for this.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  10. iPhone 6 Screen Replacement, Removing the battery connector bracket screws: stap 10, afbeelding 1 van 1
    Magnetic Project Mat
    $19.95
    Koop
    • Remove the following Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
    • During your repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your phone.
  11. iPhone 6 Screen Replacement: stap 11, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
  12. iPhone 6 Screen Replacement, Disconnecting the battery connector: stap 12, afbeelding 1 van 1
    • Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
    • Take care to only pry up on the battery connector, and not the socket on the logic board. If you pry up on the logic board socket, you may break the connector entirely.
  13. iPhone 6 Screen Replacement, Removing the front panel assembly cable bracket screws: stap 13, afbeelding 1 van 1
    • Remove the following five Phillips screws securing the front panel assembly cable bracket:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
    • Incorrect placement of these screws during reassembly will cause permanent damage to your iPhone's logic board.
  14. iPhone 6 Screen Replacement: stap 14, afbeelding 1 van 1
    • Remove the front panel assembly cable bracket from the logic board.
  15. iPhone 6 Screen Replacement: stap 15, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 15, afbeelding 2 van 2
    • In the next four steps, take care to pry up only on the cable connectors, and not on their sockets on the logic board.
    • Use a spudger or a fingernail to disconnect the front-facing camera and sensor cable connector.
  16. iPhone 6 Screen Replacement: stap 16, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 16, afbeelding 2 van 2
    • Use a spudger or a fingernail to disconnect the home button cable connector.
  17. iPhone 6 Screen Replacement: stap 17, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 17, afbeelding 2 van 2
    • Make sure the battery is disconnected before you disconnect or reconnect the cable in this step.
    • Use a spudger or a fingernail to disconnect the display data cable connector.
    • When reassembling your phone, the display data cable may pop off its connector. This can result in white lines or a blank screen when powering your phone back on. If that happens, simply reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery connector.
  18. iPhone 6 Screen Replacement: stap 18, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 18, afbeelding 2 van 2
    • Use the flat end of a spudger to disconnect the digitizer cable connector.
    • When reconnecting the digitizer cable, do not press the center of the connector. Press one end of the connector, then press the opposite end. Pressing in the center of the connector can bend the component and cause digitizer damage.
  19. iPhone 6 Screen Replacement, Separating front panel assembly and rear case: stap 19, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
  20. iPhone 6 Screen Replacement, Home Button: stap 20, afbeelding 1 van 1
    • Remove the two 1.9 mm Phillips screws securing the home button bracket.
  21. iPhone 6 Screen Replacement: stap 21, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 21, afbeelding 2 van 2
    • Remove the home button bracket from the front panel.
  22. iPhone 6 Screen Replacement: stap 22, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 22, afbeelding 2 van 2
    • Use the point of a spudger to disconnect the home button cable connector by pushing it up and away from the home button.
  23. iPhone 6 Screen Replacement: stap 23, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 23, afbeelding 2 van 2
    iOpener
    $19.99
    Koop
    • The rubber membrane surrounding the home button is very thin and tears easily.
    • Apply mild heat (with an iOpener, heat gun, or hair dryer) to soften the adhesive securing the home button membrane.
    • Using your fingertip, apply firm, constant pressure on the home button from the front side of the display assembly, until the membrane starts to separate from the front panel.
    • Do not push the home button all the way through—you only need to get a corner free so that you can pry it free with a spudger.
  24. iPhone 6 Screen Replacement: stap 24, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 24, afbeelding 2 van 2
    • Peel the home button the rest of the way off of the display by prying gently with a spudger.
  25. iPhone 6 Screen Replacement: stap 25, afbeelding 1 van 2 iPhone 6 Screen Replacement: stap 25, afbeelding 2 van 2
    iOpener
    $12.99
    Koop
    • Use the point of a spudger to carefully separate the home button cable from the adhesive securing it to the front panel.
    • If the cable doesn't separate easily, apply heat using an iOpener or hair dryer to soften the adhesive, and try again. Be careful not to damage the cable.
  26. iPhone 6 Screen Replacement: stap 26, afbeelding 1 van 1
    • Once all the adhesive has been separated, remove the home button from the front panel.
    • If you are replacing a broken front panel, there may be glass shards stuck to the home button. Carefully remove any remaining glass before transferring your home button to a new display.
    • Your replacement part may come with an extra Phillips screw already installed left of the Home Button. Remove the unnecessary screw so that you can reinstall the home button bracket.
Conclusie
2428 andere personen hebben deze handleiding voltooid.
185 opmerkingen
Its a good advice to remove the battery power before mounting the flex-cables.
There is power on the second logic-board (even if the phone is turned off) connector from top, misplacing it while assembly can cause short circuit.
peter - Antwoord
Will the short circuit damage the logic board or the camera / earpiece assembly? I'm worried just encountered this very issue even though the phone was off. FF camera and earpiece not functioning.
Eagle Micro -
Battery assembly is one of the important procedures working with manual is the best way to repair an iphone 6 screen
Electronics nano -
Good advice two: When removing the LCD back shield plate have in mind that the home button connector attached to the shield plate is Very fragile. Its adhered to the screen. Use very little force and do not heat the adhesive too much because then it become even More fragile.
I use ifixits metal spudger without heat but one small mistake and it can be teared.
peter - Antwoord
I have now changed two of these on my phone from different suppliers and both haven't worked!
Could it be that both have been defective products or am I doing something wrong!?!?
Kieran -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 64
Afgelopen 7 dagen: 452
Afgelopen 30 dagen: 1,776
Altijd: 2,145,153
