Ga door naar hoofdinhoud
iPhone 5c SIM Card Replacement
Wat je nodig hebt
  1. iPhone 5c SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 2 iPhone 5c SIM Card Replacement, SIM Card: stap 1, afbeelding 2 van 2
    • Shut your phone down completely before removing the SIM card and tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press the SIM card eject tool inwards to eject the tray.
    • This may require a significant amount of force.
  2. iPhone 5c SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the SIM Card tray assembly from the iPhone.
    • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
Conclusie
42 andere personen hebben deze handleiding voltooid.
2 opmerkingen
How would you replace the sim card try if the tray is jammed? Is there a way to open up the phone and replace it internally?
Patricia Lovera - Antwoord
You can try opening the phone and removing the SIM eject lever, or seeing if its obstructed somehow, with this guide. good luck!
Sam Goldheart -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 42
Altijd: 17,213
