Ga door naar hoofdinhoud
iPhone 5c SIM Card Replacement
Wat je nodig hebt
  1. iPhone 5c SIM Card Replacement, SIM Card: stap 1, afbeelding 1 van 2 iPhone 5c SIM Card Replacement, SIM Card: stap 1, afbeelding 2 van 2
    • Shut your phone down completely before removing the SIM card and tray.
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray.
    • Press the SIM card eject tool inwards to eject the tray.
    • This may require a significant amount of force.
  2. iPhone 5c SIM Card Replacement: stap 2, afbeelding 1 van 1
    • Remove the SIM Card tray assembly from the iPhone.
    • During reassembly, ensure that the SIM card is in the proper orientation relative to the tray.
Conclusie
43 andere personen hebben deze handleiding voltooid.
2Gids Commentaar
How would you replace the sim card try if the tray is jammed? Is there a way to open up the phone and replace it internally?
Patricia Lovera - Antwoord
You can try opening the phone and removing the SIM eject lever, or seeing if its obstructed somehow, with this guide. good luck!
Sam Goldheart -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 24
Altijd: 17,945
