Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
iPhone 5c Battery Replacement
Wat je nodig hebt
Video overzicht
  1. iPhone 5c Battery Replacement, Taping the display glass: stap 1, afbeelding 1 van 3 iPhone 5c Battery Replacement, Taping the display glass: stap 1, afbeelding 2 van 3 iPhone 5c Battery Replacement, Taping the display glass: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPhone's display until the whole face is covered.
    • Wear safety glasses to protect your eyes from any glass shaken free during the repair.
  2. iPhone 5c Battery Replacement, Removing the Pentalobe screws: stap 2, afbeelding 1 van 1
    • Before you proceed, discharge your iPhone battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Power off your iPhone before beginning disassembly.
    • Remove the two 3.8 mm P2 Pentalobe screws on either side of the Lightning connector.
  3. iPhone 5c Battery Replacement, Starting the iSclack Opening Procedure: stap 3, afbeelding 1 van 3 iPhone 5c Battery Replacement, Starting the iSclack Opening Procedure: stap 3, afbeelding 2 van 3 iPhone 5c Battery Replacement, Starting the iSclack Opening Procedure: stap 3, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    iSclack
    $24.99
    Koop
    • The next two steps demonstrate using the iSclack, a great tool for safely opening the iPhone 5c that we recommend for anyone doing more than one repair on an iPhone 5, 5s, or 5c. If you aren't using the iSclack, skip to Step 5.
    • Close the handle on the iSclack, opening the suction-cup jaws.
    • Place the bottom of your iPhone in between the suction cups, against the plastic depth gauge.
    • The top suction cup should rest just above the home button.
    • Open the handles to close the jaws of the iSclack. Center the suction cups and press them firmly onto the top and bottom of the iPhone.
  4. iPhone 5c Battery Replacement, Finishing the iSclack Opening Procedure: stap 4, afbeelding 1 van 2 iPhone 5c Battery Replacement, Finishing the iSclack Opening Procedure: stap 4, afbeelding 2 van 2
    • Hold onto your iPhone securely and close the handle of the iSclack to separate the suction cups, pulling the front panel up from the rear case.
    • The iSclack is designed to safely open your iPhone just enough to separate the pieces, but not enough to damage any cables.
    • Peel the two suction cups off your iPhone.
    • Skip the next three steps and continue on to Step 8.
  5. iPhone 5c Battery Replacement, Manual Opening Procedure: stap 5, afbeelding 1 van 1
    • Press a suction cup onto the screen, just above the home button.
    • Be sure the cup is completely on the screen to get a tight seal.
  6. iPhone 5c Battery Replacement, Start lifting the front panel assembly: stap 6, afbeelding 1 van 2 iPhone 5c Battery Replacement, Start lifting the front panel assembly: stap 6, afbeelding 2 van 2
    • Make sure the suction cup is firmly attached to the front panel assembly.
    • While holding the iPhone down with one hand, pull up on the suction cup to slightly separate the front panel assembly from the rear case.
    • Take your time and apply firm, constant force. The display assembly is a much tighter fit than most devices.
    • With a plastic opening tool, begin to gently pry the rear case down, away from the display assembly, while you pull up with the suction cup.
    • There are several clips attaching the front panel assembly to the rear case, so you may need to use a combination of the suction cup and plastic opening tool to free the front panel assembly.
  7. iPhone 5c Battery Replacement: stap 7, afbeelding 1 van 1
    • Pull the plastic nub to release the vacuum seal on the suction cup.
    • Remove the suction cup from the display assembly.
  8. iPhone 5c Battery Replacement, Opening up the phone: stap 8, afbeelding 1 van 2 iPhone 5c Battery Replacement, Opening up the phone: stap 8, afbeelding 2 van 2
    • Lift the home button end of the front panel up to gain access to the connectors near the top of the phone.
    • Open the display to about a 90º angle, and lean it against something to keep it propped up while you're working on the phone.
    • In a pinch, you can use an unopened canned beverage to hold the display.
    • Add a rubber band to keep the display securely in place while you work. This prevents undue strain on the display cables.
  9. iPhone 5c Battery Replacement: stap 9, afbeelding 1 van 1
    • Remove the two 1.6 mm Phillips #000 screws securing the metal battery connector bracket to the logic board.
  10. iPhone 5c Battery Replacement: stap 10, afbeelding 1 van 1
    • Remove the metal battery connector bracket from the iPhone.
  11. iPhone 5c Battery Replacement, Disconnecting the battery connector: stap 11, afbeelding 1 van 1
    • Use a spudger or a clean fingernail to gently pry the battery connector up from its socket on the logic board.
    • Be very careful to only pry up on the battery connector itself and not the socket on the logic board. If you pry up on the logic board socket or the board itself, you may destroy the socket or damage nearby components on the board.
  12. iPhone 5c Battery Replacement: stap 12, afbeelding 1 van 1
    • Remove the following Phillips #000 screws securing the front panel assembly cable bracket to the logic board:
    • Two 1.3 mm screws
    • One 1.7 mm screw
    • One 3.25 mm screw
    • It is especially important to keep track of your screws in this step for reassembly. Accidentally using the 3.25 mm screw or the 1.7 mm screw in the bottom right hole will result in significant damage to the logic board causing the phone to no longer boot properly.
    • Be careful not to over-tighten the screws. If they don't fit easily when you are securing them, they may be the wrong size—don't force them.
  13. iPhone 5c Battery Replacement: stap 13, afbeelding 1 van 1
    • Remove the front panel assembly cable bracket from the logic board.
  14. iPhone 5c Battery Replacement, Disconnecting the front panel assembly cables: stap 14, afbeelding 1 van 2 iPhone 5c Battery Replacement, Disconnecting the front panel assembly cables: stap 14, afbeelding 2 van 2
    • Use a plastic opening tool or a fingernail to disconnect the front-facing camera and sensor cable connector.
    • Be sure to only pry up on the connector, and not on the socket on the logic board.
  15. iPhone 5c Battery Replacement: stap 15, afbeelding 1 van 3 iPhone 5c Battery Replacement: stap 15, afbeelding 2 van 3 iPhone 5c Battery Replacement: stap 15, afbeelding 3 van 3
    • Make sure the battery is disconnected before you disconnect or reconnect the cables in this step.
    • Use a plastic opening tool or a fingernail to disconnect the LCD cable connector.
    • The LCD and Digitizer connectors are on the same cable assembly, so prying the LCD connector up should disconnect both connectors. Double check that the two cables are fully disconnected before removing the display.
    • When reassembling your phone, the LCD cable may pop off its connector. A blank screen, or white lines on the display could be caused by a loose connection. Should this happen, reconnect the cable and power cycle your phone. The best way to power cycle your phone is to disconnect and reconnect the battery.
  16. iPhone 5c Battery Replacement, Separating front panel assembly and rear case: stap 16, afbeelding 1 van 1
    • Remove the front panel assembly from the rear case.
  17. iPhone 5c Battery Replacement, Battery: stap 17, afbeelding 1 van 3 iPhone 5c Battery Replacement, Battery: stap 17, afbeelding 2 van 3 iPhone 5c Battery Replacement, Battery: stap 17, afbeelding 3 van 3
    • Run the tip of a spudger between the battery and the headphone jack to unfold the battery adhesive tab.
  18. iPhone 5c Battery Replacement: stap 18, afbeelding 1 van 1
    • Pull the battery adhesive tab away from the phone.
  19. iPhone 5c Battery Replacement: stap 19, afbeelding 1 van 2 iPhone 5c Battery Replacement: stap 19, afbeelding 2 van 2
    • Cut the black battery adhesive tab between the two white adhesive strips, separating them.
  20. iPhone 5c Battery Replacement: stap 20, afbeelding 1 van 2 iPhone 5c Battery Replacement: stap 20, afbeelding 2 van 2
    • Try to keep the strips flat and unwrinkled during this procedure; wrinkled strips will stick together and break instead of pulling out cleanly.
    • Slowly pull one of the battery adhesive strips away from the battery, toward the bottom of the iPhone.
    • Pull steadily, maintaining constant tension on the strip as it slips out from between the battery and the rear case. For best results, pull the strip at a 60º angle or less.
    • Guide the strip carefully around the corner and up the side of the battery. Be careful not to snag it on any of the other internal iPhone components.
    • The strip will stretch to many times its original length. Continue pulling, re-grabbing the strip near the battery if necessary, until the entire strip comes free.
  21. iPhone 5c Battery Replacement: stap 21, afbeelding 1 van 2 iPhone 5c Battery Replacement: stap 21, afbeelding 2 van 2
    • Repeat to remove the second strip.
  22. iPhone 5c Battery Replacement: stap 22, afbeelding 1 van 1
    • Remove the battery from your iPhone.
    • If one, or both, of the adhesive strips tears, and you are unable to retrieve it with a set of tweezers, do not pry the battery out of the phone. Continue on to the next steps to safely remove your battery.
  23. iPhone 5c Battery Replacement, Battery removal with latent adhesive: stap 23, afbeelding 1 van 1
    • Follow our iOpener heating instructions or use a hair dryer to heat the adhesive securing your battery to the rear case.
    • Lay the iOpener flat on the backside of the iPhone to the right of the camera. Smooth it out so that there is good contact between the back of the iPhone and the iOpener.
    • Let the bag sit on the iPhone for approximately 90 seconds before attempting to remove the battery.
    • If using a hair dryer or heat gun, heat the back of the iPhone until it's slightly too hot to touch.
    • Do not apply heat directly to the battery.
  24. iPhone 5c Battery Replacement: stap 24, afbeelding 1 van 2 iPhone 5c Battery Replacement: stap 24, afbeelding 2 van 2
    • Carefully wedge a plastic card under the battery on the side nearest the logic board.
    • Do not pry against the logic board or you may damage the phone.
    • Avoid prying near the top edge of the battery, or you may damage the upper component ribbon cable.
    • Slide the card from the top of the battery to the bottom, pushing toward the edge of the case.
    • If you still trouble, apply some isopropyl alcohol (90% or greater) under the battery and let it flow around the adhesive to help weaken it. High concentration isopropyl alcohol acts as a solvent and dries without leaving any residue, so it will not hurt your iPhone.
    • If necessary, repeat the same procedure with the case side of the battery.
  25. iPhone 5c Battery Replacement: stap 25, afbeelding 1 van 1
    • Lift and remove the battery from the iPhone.
    • There should be no resistance. If the battery remains stuck, reheat the iOpener and pry again.
    • If your replacement battery came in a plastic sleeve, remove it before installation by pulling it away from the the ribbon cable.
    • If your new battery doesn’t have adhesive preinstalled, refer to this guide to replace the adhesive strips.
    • Perform a hard reset after reassembly. This can prevent several issues and simplify troubleshooting.
Conclusie
494 andere personen hebben deze handleiding voltooid.
49 opmerkingen
I am disappointed with the guide - not up to iFixit's usual standards. I got the iPhone open and the battery out just fine, but there were *three* missing hints that would have cut a half-hour from my re-assembly:
1) The connector cover has three short screws and one long one. The video doesn't show which is the long one, so I had to farble around to get the screws back. (The long one is the top-right one, near the hinge on the right side of the phone)
2) There are no hints on the video or in the box about putting the adhesive strips back in. I was trying to get the tab to fold over, but got all wrapped up in the strips. It took a lot of time to fix it, and I still don't know if it's important to fold the tab over or not.
3) There is no information about whether to retain the clear cellophane wrapper that comes on the battery. I took it off - hope that's right.
That said, all the tools were included in the kit, they work as advertised. And the phone's back together, and we'll see how it works...
richbhanover - Antwoord
In reference to your #1 point, this is very good example of why a SCREW-MAT or iCracked Part Chart come in very handy!
Especially in repairs like the 5s ... some screws look the same, but are .01" different ... enough to scratch/break the trace underneath on the logic board .... adding another $100 (and a week travel time by mail, if you cannot do the repair yourself), to your repair - to have it micro-soldered.
With Screw-Mats or iCracked Part Charts, every screw is placed on it's corresponding marker, so you know exactly which screw is which.
If you are in a pinch, and do not have a Screw Mat, you can draw little diagrams on a piece of paper or a dry erase surface, and mark out where each and every screw goes, as sometimes there is that .01" difference in screw sizes, that can really screw up (no pun intended) your repair.
Cheers!
iBroke -
They did mention the screw size in the guide here by color coding the MM. I agree with point two, but that's nitpicking. Lastly (the reason I commented), you did it right. The plastic should be removed so it is just like the orig battery, if you would leave the cellophane on, the adhesive would be stuck to it instead of the battery and making for a poorly secured battery.
Overall, the parts and kit were good, but this phone is not my favorite iPhone to work on. Getting that old battery out was extremely annoying compared to the 4, 4s, 5, and 5s that I've all done in the past.
On a side note, this is the first ifixit branded battery I've received and I've ordered a lot of parts from them over the years. They used to source what looked line 100% orig batteries. I avoid non original batteries like the plague, I don't care if it's a phone, laptop, or even my APC UPS devices. Ifixit has earned my trust over the years with all the parts and tools so I went ahead and installed it, I'm sure it's good.
trssho91 - Antwoord
Apple doesn’t sell original batteries to outsiders.
If you are buying an Apple-branded battery, it’s either a fake or used.
toni -
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 17
Afgelopen 7 dagen: 119
Afgelopen 30 dagen: 437
Altijd: 359,470
