Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Remove the following screws securing the Lightning connector and speaker enclosure assembly to the rear case:
One 2.5 mm Phillips screw
Two 3.3 mm Phillips screws
One 2.9 mm Phillips screw
Two 1.5 mm Phillips screws
One 2.8 mm Phillips screw
Use the flat end of a spudger to gently pry the Lightning connector and speaker enclosure assembly cables up from the rear case.
Remove the Lightning connector and speaker enclosure assembly from the rear case.
