Inleiding
This repair is for an Apple iPhone 5. This process works on all iPhone 5 carriers and colors.
The display assembly includes the home button assembly, front camera assembly, earpiece speaker, and the LCD shield plate.
Wat je nodig hebt
Take the 5-Point Pentalobe screwdriver to remove two 3.6 mm Pentalobe screws next to the Lighting Connector (Charging Port).
Extend the blade 2mm from closed position.
Place blade between the display assembly and the phone housing.
Push down between the display assembly and the phone housing until you see a gap. Once you see the gap, pry up using the blade to keep the gap.
Now that there is a fixed gap, use your plastic pry tool to pry around the display assembly, to separate the screen from the phone.
Gently lift the display assembly away from the phone, and make a 90 degree angle with respect to the horizontal.
Locate the Connector Protective plate, it is at the top right of the phone. Along the side of the power button.
Take your #000 Phillips head screwdriver to unscrew three Phillip screws holding the Connector Protective plate to the logic board.
Once all the Phillips screws and removed, remove the Connector Protective Plate from the phone.
Locate three cables that link from the back of the display assembly to the logic board.
Now that the three cables are disconnected, remove the old Display Assembly and store it safely.
Using compressed air specifically for electronics, blow away any dust and trash from the phone.
13 andere personen hebben deze handleiding voltooid.
