Inleiding
iFixit: “ Siri,允许我们把你拆解给大家看吗? ”
iPhone 4s(Siri ) : “42”
iFixit的: “我没有问生命的意义, Siri......”
iPhone 4s(Siri) : “ 42是我启动自毁程序之前你还剩的秒数。”
iFixit: “收到。 ”
显然, Siri心里对于我们的请求很不是滋味,但是何时一个机器能阻挡iFixit的卓越团队?加入我们来深入研究新的iPhone 4s。
非常感谢MacFixit 澳大利亚慷慨借给我们,他们在墨尔本的办公室。他们拥有Mac和iPhone升级产品和零配件存货,还出售我们的iFixit工具包。
想要了解最新拆解动态?关注我们的新浪微博iFixit官网资讯、优酷频道、我们的脸书, Instagram, 或Twitter 了解维修世界最新动态。
另外,查阅MJ的新iPhone 4s的video评论 !
Wat je nodig hebt
你问,我们答!新的iPhone 4s进入了最盛大的阶段, iFixit马上就要给它曝光。
技术规格:
苹果的A5系统芯片: 1 GHz的双核处理器
800万像素后置摄像头(1080视频采集) + VGA前置摄像头
802.11 b/g/n + 蓝牙 4.0 (天噜啦!)
LED背光IPS TFT LCD Retina显示屏具有960× 640像素的分辨率
四频 GSM/GPRS/EDGE + 双频 CDMA/EV-DO 版本支持 (世界通用)
A new myth says volume buttons and mute switch on iPhone 4S are in a slighly different position, meaning current iPhone 4 cases does not fix, plus the supposedly fixed 4S antenna can not be used on the iPhone 4. Is this myth confirmed, plausibe or busted?
They're the same as the Verizon iPhone 4, but slightly different from the AT&T iPhone 4.
Biochao -
yes, I can confirm they are different than the att GSM iphone 4. As such, the bumpers will NOT fit correctly. The case partially occludes the vibrate switch and the volume buttons on the case are not hitting centered on the iphone buttons. Drilling out the hole for the mute switch to be slightly larger fixed the problem for me. The volume buttons work well enough.
拧下底部的两颗五角螺丝,你就可以轻易的取下后盖。iPhone 4也是同样的步骤,拆开之后就是EMI屏蔽盖。
Siri坚定地说:“不要,iFixit,不要,你不能这样,不要再往下拆了,我求你们了,你们没有被授权。”
遗憾地说,我们看到一个半透明的塑料拉条,上面写着标识“Authorized Service Provider Only” - 意思是“未成年人禁止入内”,开个玩笑,意思是“非授权提供商不得拆解”,看样子我们真的不能再往下拆了。
不能再往下拆了?!想都不要想!这条傻乎乎的标识以前从来没能阻止过我们,今天也不会例外。
You mean Psych?
Psych, Psyche, Sike? It's tough to determine the correct spelling for a slang word. We chose to go with "sike" simply because it looks cool and Urban Dictionary featured it as their word of the day on November 24, 2007. :)
Urban dictionary? Aside from the fact that anybody can write anything there, most of the entries agree that "sike" is a misspelling of "psych". And "psyche" is pronounced "sikee", and it's a different concept.
cityzen -
Thank you so much.
轻轻撬开电池排线接口,拉动塑料拉条就可以取下电池。
我们终于拆到在4s中受到高度赞誉电池。
近一点。。。再近一点。。。这就是了:比iPhone 4的电池要多0.05瓦小时!
4s 电池可以支持持续8小时3G通话,或者14小时2G通话(GSM网络),或者是200小时的待机。
和iPhone 4 作比较, iPhone 4S提供的多一个小时的3G网络通话时间,相同的2G网络通话时间,和不到100小时的待机时间。
考虑到自带的4S硬件升级,不过,其功耗也显得十分高效。
用一根小撬棒撬开摄像头排线接口后就可以取下后置摄像头。
这个一颗800万像素的摄像头。
我们从Chipworks得知制造商是Sony!
800万已然是很高的像素,但我们知道,像素并不代表一切,重要的是如何利用好它。很高兴,4S 知道怎样利用好它的每一个像素。
在弱光环境中,苹果使用“新一代的背光”增加了73%的光。想要更快照相?此照相机比之前快大约33%,并可以在一秒左右捕捉多张照片。
如果仅仅是照片不能满足你的话,那么30帧每秒,1080P的高清摄像怎么样?
A lot of people are asking, will this plug up to an Iphone 4, and will the Iphone 4 hardware support 8mp picture taking?
Not compatible.
Anyone know what the Audio Chip is?
are you sure both triquint chips are power amps/ some are saying one is just a filter??
ski3938 -
Are there any changes to the GPS chip in the iPhone 4S compared to iPhone 4? I noticed in the iPad 2 tear down you labeled it's GPS chip as a "monolithic". Is that monolithic vs. assisted GPS?
来一个苹果A5芯片的特写怎么样? 1 GHz双核处理器,512 MB DDR2内存... 哇咔咔。
我们怎么知道它是512 MB?看看这个标记,特别是E4E4,标记着两个2GB LPDDR2芯片,总共4 Gb-或512 MB的。谢谢,Anandtech!
嘿,这是什么?据Chipworks公司称,我们的德国iPhone(红色标记)的三星DDR2内存,而澳州的iPhone 4S的(黄色标记),包含Elpida DDR2内存!
如果Siri的有一个地址,那就是这个了。尽管iCloud的整合可在任何的iOS 5设备上使用,Siri的只适用于双核配备iPhone 4S的。
拜托了,Siri现身吧。我们不想伤害你。我们只是想谈谈。
Chipworks 公司是太酷了,为我们提供了A5处理器的芯片照片。
The iPhone 4S's A5 is clocked at 800 MHz.
Even if Apple has limited the chip's performance, the A5 is still a 1 GHz processor.
让我们来看看有什么在另一边。 Siri, 麻烦翻个身... 谢谢。
高通MDM6610 芯片组 (从 iPhone 4's MDM6600有升级)
据Chipworks公司说,苹果338S0973,这似乎是一个电源管理IC。
从另一个角度阅读覆盖芯片表明“PM8028”,这是高通的电源管理IC.
Audio chip is still Cirrus Logic as you can tell by Apple 338S0973 chip that ChipWorks thinks is a Power IC. Its not ..its the Codec.
和 iPhone 4 一样,采用 960 x 640 Retina屏幕。
虽然和上一代的 iPhone 采用相同的视网膜屏,但图像表现力依然极其出色,而且新的 A5 处理器能在一定程度上提高其图像表现力。
我们注意到,Verizon和AT&T的iPhone4的显示组件有不同的安装卡的位置。虽然大多数4S已经类似于CDMA版iPhone4,显示组件第一眼看上去和GSM版本中类似。遗憾的是,还是不一样。
这似乎是环境光传感器和红外LED的接近传感器从显示屏组件拆掉了。
Can you see which company makes the ambient light sensor?
显示屏电缆下有神秘的标记为FA111107174M0816-0420054676837.91032 GZ MB,或者更通常被称为“来自北方的黎明攻击。”
真棒!我们已经挑起了柔性带状电缆连接器! 退后!他们似乎是守护C1113320826DJGHT-A1MOXF的标记......可能是为了解锁魔法代码?
The barcode decodes to
FA111107174MO816-0420057684637.91032GZMB
(all on one line).
马达拆出来了。 看上去苹果使用了Verizon iPhone 4当中的 线性马达 ,作为对比,AT&T使用旋转电动平衡重量马达。
跟平衡重量马达比起来,这个线性振动马达更为安静、柔软、噪音更小。
The new vibration motor is know as an Linear Resonant Actuator (LRA) : http://www.precisionmicrodrives.com/vibr...
Gereedschap gebruikt in deze stap:P2 Pentalobe Screwdriver iPhone$5.99
Is the back glass more break proof (Gorilla glass perhaps) than the previous generation?
Bought 4s just 3 days ago and this evening it fell on the ground and to my surprise the screen turn white.I love the phone.Dont know what to do now.Can any one advice?
Where is the internal storage?
Met dank aan deze vertalers:
100%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
28 opmerkingen
Is that true? Do we know for sure that the A5 is under clocked to 800? (yes i know about the geekbench scores, but I wasn't sure if that was a test model or a final product)
If its a 1000 Ghz chip, will it be possible (without jailbraking) the phone to increase the frequency to its native clock speed?
It will likely be possible, through jailbreaking, to increase the clock speed. But, this will be at the expense of reduced battery life. Furthermore, once you see the speed of this phone you likely won't see a need to increase the clock speed.
Noel -
Yes, that has been confirmed and, again, 1GB of RAM would have resulted in far less battery life. A Microsoft employee has recently blogged about how the increased RAM on their phones would have severely reduced battery life as the RAM has to be kept active even when not in use.
Apple is very deft in making sure they can keep the battery life up while still providing an extremely enjoyable user experience and acceptable speed (in fact, much increased speed in this device over the iPhone 4). Remember, it's about the total user experience, not individual specs.
Noel -
You said the the Retina Display is the same as the iPhone 4, but I've read in some reviews that the display is exhibiting less contrast, with blacks being washed out more than the previous iteration. Can you confirm that the display has the same manufacturer or is in any way different SKU/part#?
Did Apple end up going with Sony for the camera, or is it still by Omnivision?
The front camera is made by Omnivision, but the main camera is made by Sony.
So, The iphone 4 screens can be used on the the iphone 4S, is that correct?
Can someone give a list of parts that are not interchangable please. so far i see:
Front Camera
Back Camera
Battery
Back Glass (markings)
any more?
PS: I'm not a fan of the attempted humour on this teardown, simple facts and not milked SiRi jokes would be better appreciated I feel.
I didn't see any mention in the iPhone 4S teardown about the proximity sensor.
I've had my iPhone 4 replaced 3 times, first for the proximity sensor problem, then for the yellow screen, finally because it wouldn't install IOS 5.
The second replacement phone also had intermittent problems where my ear would put the phone on mute, or start 'dialing' while I was on a call.
I'm really interested to find out if they did anything about this with the new phone.
Thanks for the teardown, brilliant as usual. But I'm wondering about the new antenna configuration. On the 4, the antenna was two isolated pieces - as shown here http://images.anandtech.com/reviews/gadg... - but on the 4S it seems to be three isolated pieces. Which of these are antennas, and for which radios? I'm wondering what they've done to address the "death grip" problem.
Are the Verizon iPhone 4 backplates compatible with the iPhone 4S (all carriers)?
I would like to know if the full opening procees does affect warranty provided for the terminal / smartphone, there are some seals around that must not be broken until the device goes on an authoryzed service and i have some questions about some technical issues found here on the iPhone 4s reviews in the reviewing area and specifications...
Thanks for sharing this info. Now I know how to unlock my Iphone!
bryanflake1984| http://www.aceofdiamonds.com.au/engageme...
Hello, I've got 2 parts of my iphone 4s that I don't know where they belong. The parts can be viewed at http://eyecatchdesign.be/iphone4s.jpg. Can somebody help me out and give me directions where they belong. Thanks
# 1 is battery connection cover clip, ( goes under battery connector on top screw. # 2 is front facing camera clip, ( holds selfie camera in place)
i have a iphone 4s does anyone know how to delete the os on it?
