Ga door naar hoofdinhoud
Onderdelen
Geen onderdelen opgegeven.
  1. Deze stap is niet vertaald. Help het te vertalen
    Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
    • Remove the two 2.4 mm Phillips screws from the sides of the speaker enclosure assembly.
  2. Deze stap is niet vertaald. Help het te vertalen
    Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
    • Remove the small plastic bracket that was installed under the screw closest to the dock connector cable.
  3. Deze stap is niet vertaald. Help het te vertalen
    Remove the speaker enclosure assembly from the iPhone. Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
    • Remove the speaker enclosure assembly from the iPhone.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the second picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Eindstreep
3 andere personen hebben deze handleiding voltooid.
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,464
