Ga door naar hoofdinhoud
Inleiding
Internal prerequisite.
Onderdelen
Geen onderdelen opgegeven.
  1. Remove the following screws securing the dock connector cable cover to the logic board: One 1.5 mm Phillips screw
    • Remove the following screws securing the dock connector cable cover to the logic board:
    • One 1.5 mm Phillips screw
    • One 1.2 mm Phillips screw
    • Remove the metal dock connector cable cover.
  2. Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
    • Use the edge of a plastic opening tool to pry the dock cable up from its socket on the logic board.
  3. Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
    • Peel the dock connector cable off the adhesive securing it to the logic board and the side of the speaker enclosure.
  4. Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board. De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
    • Use the edge of a plastic opening tool to pry the cellular antenna cable up from its socket on the logic board.
    • De-route the cellular antenna cable out from under the metal fingers attached to the logic board.
  5. Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
    • Remove the two 2.4 mm Phillips screws securing the speaker enclosure assembly to the outer case.
  6. Remove the small black spacer that was under the Phillips screw near the vibrator.
    • Remove the small black spacer that was under the Phillips screw near the vibrator.
  7. Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna. Remove the speaker enclosure assembly. Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Use a plastic opening tool to lift the speaker enclosure assembly out of the case, being sure not to damage the EMI fingers on the attached Wi-Fi antenna.
    • Remove the speaker enclosure assembly.
    • Before reinstalling the speaker enclosure assembly's screws, be sure the Wi-Fi grounding fingers are installed below the lip in the iPhone's metal case as seen in the third picture.
    • Before reassembly, be sure to clean all metal-to-metal contact points between the grounding fingers of the Wi-Fi antenna and the case of the iPhone with a de-greaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to cause wireless interference issues.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 708
