Inleiding
This guide is for replacing the metal portion of the volume buttons, not the electronic switches.
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Use a pair of tweezers to remove the small strip of tape covering the back of the volume buttons.
85 andere personen hebben deze handleiding voltooid.
