Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Video overzicht
Deze stap is niet vertaald. Help het te vertalen
Power off your iPhone before beginning disassembly.
Your iPhone 4 rear cover may have either two #000 Phillips screws or Apple's 5-Point "Pentalobe" screws (second image). Check which screws you have, and ensure you also have the correct screwdriver in order to remove them.
Remove the two 3.6 mm Pentalobe or Phillips #000 screws next to the dock connector.
Push the rear panel toward the top edge of the iPhone.
Pinch the rear panel with your fingers and lift it away from the iPhone. Alternatively, use a Small Suction Cup .
Remove the single 2.5 mm Phillips screw securing the battery connector to the logic board.
Use a plastic opening tool to gently pry the battery connector up from its socket on the logic board.
Remove the metal clip covering the antenna connector.
Use the clear plastic pull tab to gently lift the battery out of the iPhone.
If there's any alcohol solution remaining in the phone, carefully wipe it off or allow it to air dry before installing your new battery.
Before reconnecting the battery connector, be sure the contact clip (shown in red) is properly positioned next to the battery connector.
Use a SIM card eject tool or a paperclip to eject the SIM card and its holder.
Remove the SIM card and its holder.
Remove the following two screws:
One 1.2 mm Phillips
One 1.6 mm Phillips
Remove the thin steel dock connector cable cover from the iPhone.
Use an iPod opening tool to gently pry the dock cable connector up off the logic board from both short ends of the connector.
Carefully peel the dock ribbon cable off the logic board and the lower speaker enclosure.
Use a plastic opening tool to pry the lower antenna connector up off its socket on the logic board.
Remove the 1.9 mm Phillips screw securing the bottom of the logic board to the inner case.
Remove the following five screws securing the Wi-Fi antenna to the logic board:
One 2.3 mm Phillips
Two 1.6 mm Phillips
One 1.4 mm Phillips
One 4.8 mm Phillips
Use an iPod opening tool to slightly lift the top edge of the Wi-Fi antenna away from the logic board.
Use the tip of a spudger to pull the Wi-Fi retaining clips away from the inner frame.
Remove the Wi-Fi antenna from the iPhone. Make sure you don't lose the metal clips on the top of the cover where the 4.8mm screw attaches or the 4.8mm screw. That's the primary reason for abnormal Wi-Fi performance after the reassembly.
Use an iPod opening tool to carefully lift the rear camera connector up off its socket on the logic board.
Remove the rear camera.
Remove the small circular white sticker (warranty sticker and water indicator) covering the screw near the battery pull tab.
Remove the 2.4 mm Phillips screw that was hidden underneath the sticker.
Use the edge of a plastic opening tool to gently pry the following connectors up and out of their sockets on the logic board:
Digitizer cable (pry from bottom)
LCD cable (pry from bottom)
Headphone jack/volume button cable (pry from top)
Top Microphone/sleep button cable (pry from top)
Front camera cable (pry from top)
Gereedschap gebruikt in deze stap:Standoff Screwdriver for iPhones$5.49-
Remove the 4.8 mm standoff screw near the headphone jack.
Without this part, the motherboard could damage the ribbon cables around it.
Carefully remove the logic board from the iPhone, minding any cables that may get caught.
295 andere personen hebben deze handleiding voltooid.
15 opmerkingen
I did a thorough surgery of mine today. Ppl couldn't hear me at all, so I had to get to the logic board.it was not challenging at all. One has to be careful with the antenna area so as not to apply to much force thereby damaging it. However,if u couldn't clip it back,just use a paper tape to hold it down b4 placing the battery plate on it. I recoupled the phone and everything work excellently. Ppl can hear me clearly now
