Ga door naar hoofdinhoud
iPhone 16 Pro Charging Port Replacement
Wat je nodig hebt
  1. iPhone 16 Pro Charging Port Replacement, Prepare your phone for disassembly: stap 1, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Prepare your phone for disassembly: stap 1, afbeelding 2 van 2
    • Allow your phone's battery to drain below 25%, as a charged lithium-ion battery is a potential safety hazard.
    • Unplug any cables from your phone.
    • Hold the power and either volume buttons and slide to power off your phone.
  2. iPhone 16 Pro Charging Port Replacement, Tape over any cracks: stap 2, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Tape over any cracks: stap 2, afbeelding 2 van 2
    • If your screen or back glass is badly cracked, lay overlapping strips of packing tape over the glass to protect yourself and make disassembly easier.
    • Make sure there's a smooth area near the bottom edge that's big enough for a suction cup to stick to.
  3. iPhone 16 Pro Charging Port Replacement, Mark your opening picks: stap 3, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement, Mark your opening picks: stap 3, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement, Mark your opening picks: stap 3, afbeelding 3 van 3
    • If inserted too far, an opening pick can damage your device. Follow this step to mark your pick and prevent damage.
    • Measure 3 mm from the tip and mark the opening pick with a permanent marker.
    • You can also mark the other corners of the pick with different measurements.
    • Alternatively, tape a coin to a pick 3 mm from the tip.
  4. iPhone 16 Pro Charging Port Replacement, Remove the pentalobe screws: stap 4, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Remove the pentalobe screws: stap 4, afbeelding 2 van 2
    • Use a P2 pentalobe screwdriver to remove the two 7.4 mm‑long screws on either side of the USB-C port.
  5. iPhone 16 Pro Charging Port Replacement, Heat the bottom edge: stap 5, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Heat the bottom edge: stap 5, afbeelding 2 van 2
    • Apply a heated iOpener to the bottom edge of the back glass for two minutes.
    • Alternatively, you can use a hair dryer or heat gun to heat the bottom edge of the back glass until it's hot to the touch.
    • Be careful not to heat the phone hotter than this—the battery is susceptible to heat damage.
  6. iPhone 16 Pro Charging Port Replacement, Insert an opening pick: stap 6, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement, Insert an opening pick: stap 6, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement, Insert an opening pick: stap 6, afbeelding 3 van 3
    • Apply a suction handle to the bottom edge of the back glass, above the USB-C port.
    • Pull up on the handle with a strong, steady force to create a gap between the back glass and the frame.
    • Insert the tip of an opening pick into the gap.
  7. iPhone 16 Pro Charging Port Replacement, Back glass information: stap 7, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Back glass information: stap 7, afbeelding 2 van 2
    • As you slice the adhesive securing the back glass in the next steps, be careful of the following areas:
    • There's a delicate cable connecting the back glass to the phone, right next to the volume up button. Don't insert your pick here to avoid slicing the cable.
    • There are multiple spring contacts around the perimeter of the phone. Be extra careful not to insert your pick deeper than suggested in each step to avoid bending these contacts.
    • If you damage the spring contacts, gently bend them back with a spudger or opening pick so they align with their gold contact pads on the back glass.
  8. iPhone 16 Pro Charging Port Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement, Separate the bottom edge adhesive: stap 8, afbeelding 3 van 3
    • Don't insert your pick deeper than 5 mm on the bottom edge to avoid damaging the spring contact.
    • Slide your pick back and forth along the bottom edge to separate the adhesive.
    • Leave your pick inserted in the bottom right corner to prevent the adhesive from resealing.
  9. iPhone 16 Pro Charging Port Replacement, Heat the right edge: stap 9, afbeelding 1 van 1
    • Apply a heated iOpener to the right edge of the back glass for two minutes.
    • When using a hair dryer or heat gun, heat the back glass until it's hot to the touch.
  10. iPhone 16 Pro Charging Port Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Separate the bottom right corner adhesive: stap 10, afbeelding 2 van 2
    • Slide your pick around the bottom right corner and halfway up the right edge, or until you feel a hard stop at a clip securing the back glass.
    • Don't slice near the volume buttons to avoid damaging the wireless charging/flash cable.
    • Leave this pick inserted to prevent the adhesive from resealing.
  11. iPhone 16 Pro Charging Port Replacement, Heat the left edge: stap 11, afbeelding 1 van 1
    • Apply a heated iOpener to the left edge of the back glass for two minutes.
  12. iPhone 16 Pro Charging Port Replacement, Separate the left edge adhesive: stap 12, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Separate the left edge adhesive: stap 12, afbeelding 2 van 2
    • Insert a second opening pick at the bottom edge.
    • Slide the second pick around the bottom left corner and along the left edge of the screen to separate the adhesive and release the metal clips.
    • You'll hear and feel the metal clips release as you pass them.
    • Leave this pick inserted at the top left corner to prevent the adhesive from resealing.
  13. iPhone 16 Pro Charging Port Replacement, Heat the top edge: stap 13, afbeelding 1 van 1
    • Apply a heated iOpener to the top edge of the back glass, angled to include the volume buttons, for two minutes.
  14. iPhone 16 Pro Charging Port Replacement, Separate the top edge adhesive: stap 14, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Separate the top edge adhesive: stap 14, afbeelding 2 van 2
    • Don't insert your pick deeper than 3 mm along the top edge to avoid damaging the spring contacts.
    • Slide your opening pick across the top edge and around the top right corner to the volume up button to separate the adhesive.
    • You'll hear and feel clicks as the top two clips release.
  15. iPhone 16 Pro Charging Port Replacement, Swing open the back glass: stap 15, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Swing open the back glass: stap 15, afbeelding 2 van 2
    • Don't try to fully remove the back glass just yet—it's still attached with a delicate ribbon cable. Follow the next few steps to remove it safely.
    • If the back glass doesn't swing open easily, don't force it—go back around the perimeter with your pick to check for missed sections of adhesive or stuck clips.
    • You may need to lift the back glass up slightly before swinging it open to fully disengage the clips.
    • Gently swing open the back glass towards the volume buttons.
    • Support the back glass with a clean, sturdy object like a small box to avoid straining the cable.
    • Remove the opening picks.
    • Consider using polyimide tape to protect the rear camera lenses while you're working inside the phone. Don't push against the lenses to avoid damaging the delicate stabilizers.
  16. iPhone 16 Pro Charging Port Replacement, Disconnect the battery: stap 16, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Disconnect the battery: stap 16, afbeelding 2 van 2
    • Use a tri-point Y000 screwdriver to remove the three screws securing the lower connector cover:
    • Two 1.2 mm‑long screws
    • One 1.0 mm‑long screw
  17. iPhone 16 Pro Charging Port Replacement: stap 17, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 17, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 17, afbeelding 3 van 3
    • Use tweezers or your fingers to pick up and remove the lower connector cover.
  18. iPhone 16 Pro Charging Port Replacement: stap 18, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 18, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 18, afbeelding 3 van 3
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, align the connector carefully over its socket and press down with your fingertip or the flat end of a spudger—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
  19. iPhone 16 Pro Charging Port Replacement, Disconnect the back glass: stap 19, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Disconnect the back glass: stap 19, afbeelding 2 van 2
    • Use a tri-point Y000 screwdriver to remove the four screws securing the upper connector cover:
    • Two 1.0 mm‑long screws
    • One 1.2 mm‑long screw
    • One 1.6 mm‑long screw
  20. iPhone 16 Pro Charging Port Replacement: stap 20, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 20, afbeelding 2 van 2
    • Use tweezers or your fingers to pick up and remove the upper connector cover.
  21. iPhone 16 Pro Charging Port Replacement: stap 21, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 21, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the back glass press connector.
  22. iPhone 16 Pro Charging Port Replacement, Remove the back glass: stap 22, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Remove the back glass: stap 22, afbeelding 2 van 2
    • Lift the back glass off the frame and remove it.
    • During reassembly:
    • This is a good point to test your repair before sealing up your phone. Temporarily reconnect the battery and back glass (before replacing the adhesive), power on your phone, and make sure it works as expected. Power it back down, disconnect the battery, and continue reassembly.
    • Use this guide to reapply adhesive and install your back glass.
  23. iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine cover: stap 23, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine cover: stap 23, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the three screws securing the Taptic Engine cover:
    • One 3.0 mm‑long screw
    • Two 1.7 mm‑long screws
  24. iPhone 16 Pro Charging Port Replacement: stap 24, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 24, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 24, afbeelding 3 van 3
    • Use tweezers or your fingers to lift the top edge of the Taptic Engine cover.
    • Once the bottom edge unlatches from the frame, remove the Taptic Engine cover.
    • During reassembly, make sure the bottom edge of the cover latches properly to the frame.
  25. iPhone 16 Pro Charging Port Replacement, Disconnect the lower assembly cable: stap 25, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Disconnect the lower assembly cable: stap 25, afbeelding 2 van 2
    • Use the point of a spudger to pry up and disconnect the lower assembly cable press connector from the logic board.
  26. iPhone 16 Pro Charging Port Replacement: stap 26, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 26, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 26, afbeelding 3 van 3
    • Use the point of a spudger to pry up and disconnect the two press connectors near the bottom right edge of the frame.
  27. iPhone 16 Pro Charging Port Replacement: stap 27, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 27, afbeelding 2 van 2
    • Use a tri-point Y000 screwdriver to remove the 1.0 mm‑long screw securing the lower assembly cable.
  28. iPhone 16 Pro Charging Port Replacement: stap 28, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 28, afbeelding 2 van 2
    • Use an iOpener or hair dryer to heat up the lower assembly cable section on top of the Taptic Engine until it's hot to the touch.
  29. iPhone 16 Pro Charging Port Replacement: stap 29, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 29, afbeelding 2 van 2
    • Slide an opening pick under the lower assembly cable to separate it from the Taptic Engine.
    • Carefully bend the cable out of the way so you can access the Taptic Engine.
  30. iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine: stap 30, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Remove the Taptic Engine: stap 30, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 1.9 mm‑long screw securing the Taptic Engine.
  31. iPhone 16 Pro Charging Port Replacement: stap 31, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 31, afbeelding 2 van 2
    • Slide the tip of an opening pick along the top edge of the Taptic Engine to separate the plastic buffer strip adhered to it.
  32. iPhone 16 Pro Charging Port Replacement: stap 32, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 32, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 32, afbeelding 3 van 3
    • Use the point of a spudger to pry up the Taptic Engine from its top-right corner.
    • Be careful not to pry against the battery.
    • Remove the Taptic Engine.
  33. iPhone 16 Pro Charging Port Replacement, Remove the loudspeaker: stap 33, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Remove the loudspeaker: stap 33, afbeelding 2 van 2
    • Remove the four screws securing the loudspeaker:
    • Two 1.6 mm‑long Phillips screws
    • One 2.0 mm‑long Phillips screw
    • One 1.3 mm‑long tri-point Y000 screw
  34. iPhone 16 Pro Charging Port Replacement: stap 34, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 34, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 34, afbeelding 3 van 3
    • Insert the point of a spudger underneath the loudspeaker's bottom-right screw hole.
    • Pry up and remove the loudspeaker.
  35. iPhone 16 Pro Charging Port Replacement, Battery adhesive information: stap 35, afbeelding 1 van 1
    • Your iPhone's battery is secured with three stretch release adhesive strips. The next four steps show how to remove them and free your battery.
    • Be careful not to dent or puncture the battery. Even with its metal enclosure, the battery can catch fire if damaged.
  36. iPhone 16 Pro Charging Port Replacement, Remove the battery: stap 36, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement, Remove the battery: stap 36, afbeelding 2 van 2
    • Insert the tip of angled tweezers under one of the black pull tabs.
  37. iPhone 16 Pro Charging Port Replacement: stap 37, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 37, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 37, afbeelding 3 van 3
    • Use your tweezers to slice through the black tab and peel the tab off the top of the battery.
    • Don't try to pull the tab out from under the battery just yet.
  38. iPhone 16 Pro Charging Port Replacement: stap 38, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 38, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 38, afbeelding 3 van 3
    • Use tweezers or your fingers to grab the pull tab and pull it down so it's flat against the frame.
    • Slowly pull the adhesive out from under the battery at as low of an angle as possible.
    • Give the strip plenty of time to stretch and re-grip it as necessary. When the strip becomes too long, wrap it around your tweezers and continue pulling.
    • If the strip breaks off, try to retrieve it from under the battery. If you can't retrieve it, move onto the next strip.
  39. iPhone 16 Pro Charging Port Replacement: stap 39, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 39, afbeelding 2 van 2
    • Repeat the procedure with the two remaining adhesive strips.
    • Carefully bend the lower assembly cable out of the way as needed to access the adhesive strips.
  40. iPhone 16 Pro Charging Port Replacement: stap 40, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 40, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Stretch Release Battery Adhesive
    $3.99
    • If you removed all three stretch release adhesive strips, congratulations! Lift and remove the battery.
    • If one or more adhesive strips broke, skip to the next step to remove them with isopropyl alcohol.
    • To install a new battery:
    • Clean your frame with isopropyl alcohol and a lint-free or microfiber cloth. Wait for the alcohol to fully evaporate before installing the new battery.
    • Before applying adhesive, place it in its recess to check if it fits and that the cable reaches its socket on the logic board. Don't reconnect the battery yet.
    • If your new battery doesn't have adhesive installed, follow this guide to apply new stretch release adhesive strips, or use thin, double-sided tape to secure it. We recommend using stretch release adhesive for easier removal.
  41. iPhone 16 Pro Charging Port Replacement, Alternate method to remove the battery: stap 41, afbeelding 1 van 1
    • The next two steps show how to remove the battery if the adhesive strips broke.
    • Lift the bottom edge of the frame to tilt your phone.
    • Use a pipette or a syringe to apply 2–3 drops of high concentration (>90%) isopropyl alcohol along the bottom edge of the battery, close to where each broken adhesive strip came out.
    • Wait one minute for the isopropyl alcohol to flow under the battery and soften the adhesive.
  42. iPhone 16 Pro Charging Port Replacement: stap 42, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 42, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 42, afbeelding 3 van 3
    $3.99
    • Insert the tip of an opening pick between the bottom of the battery and the frame.
    • Insert a second opening pick between the left edge of the battery and the frame. Use this pick to pry the battery upwards slowly with steady force. Work your way up the edge of the battery, giving the adhesive time to release.
    • Don't bend or crease the battery. If it feels stubborn, apply a few more drops of isopropyl alcohol and try again.
    • Once the adhesive loosens, grab and remove the battery.
  43. iPhone 16 Pro Charging Port Replacement, Remove the charging port: stap 43, afbeelding 1 van 1
    • Use a standoff screwdriver to remove the 3.6 mm‑long screw securing the charging port to the frame.
  44. iPhone 16 Pro Charging Port Replacement: stap 44, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 44, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 44, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the two 3.4 mm‑long screws securing the charging port to the frame.
    • These screws are tight and can be difficult to reach. Angle your screwdriver at as shallow of an angle as you can.
    • When you're installing the charging port, temporarily install the two external P2 pentalobe screws to help with port alignment. Once it's aligned, secure the port with its Phillips screws.
    • Remove the pentalobe screws after this, or they'll block you from installing the back glass.
  45. iPhone 16 Pro Charging Port Replacement: stap 45, afbeelding 1 van 1
    • Use a tri-point Y000 screwdriver to remove the 1.3 mm‑long screw securing the charging port to the frame.
  46. iPhone 16 Pro Charging Port Replacement: stap 46, afbeelding 1 van 2 iPhone 16 Pro Charging Port Replacement: stap 46, afbeelding 2 van 2
    • The charging port has an adhesive gasket that seals it against the bottom and edge of the frame. It's also tucked behind two prongs, which prevents you from pulling the port away from the frame.
    • Insert the point of a spudger under one side of the charging port.
    • Pry up gently to separate the gasket and lift the port up.
  47. iPhone 16 Pro Charging Port Replacement: stap 47, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement: stap 47, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement: stap 47, afbeelding 3 van 3
    • Don't pull the port directly away from its cut-out in the frame. There are two prongs holding it in place.
    • Pull the charging port away from the microphone.
    • Remove the charging port.
  48. iPhone 16 Pro Charging Port Replacement, Reassembly tips: stap 48, afbeelding 1 van 3 iPhone 16 Pro Charging Port Replacement, Reassembly tips: stap 48, afbeelding 2 van 3 iPhone 16 Pro Charging Port Replacement, Reassembly tips: stap 48, afbeelding 3 van 3
    • During reassembly, note the following:
    • The two screw posts underneath the charging port contain grounding clips. During reassembly, make sure they're still clipped in place. The clips should face towards the bottom edge of the iPhone.
    • Make sure the two black prongs are standing straight up. If they were bent when you removed the port, use the point of a spudger to carefully straighten them.
    • Remove all of the original adhesive securing the port to the frame before replacing it.
Conclusie
To reassemble your iPhone, follow these instructions in reverse order.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our iPhone 16 Pro Answers community for help.
Één andere persoon heeft deze handleiding voltooid.
Nick Schultz
19.642 Reputatie
114 handleidingen geschreven
iFixit Lid van iFixit
Staff
120 Leden
20.086 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 7
Afgelopen 7 dagen: 55
Afgelopen 30 dagen: 275
Altijd: 613
